Old 10-17-2010, 11:03 PM   #5806
Racecrafter's Avatar
Trader Rating: 25 (96%+)
All "Spec"/"No timing" classes mean no boost timing ESC's.
Motors are still legal to twist timing into.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 10-18-2010, 12:00 AM   #5807
Originally Posted by RCMaster1 View Post
I tried to upgrade from the 528 stock to the 508 and a note popped up saying I could not upgrade to that software. Any ideas? Will the SC have the same performance if I set 9 and 12 to setting 1 with the 528 as it would with the 508? I have the GT 2.0 LPF and previously loaded the 528 software using the same computer. Thanks
Anyone?
Don Skaggs
RCMaster1 is offline   Reply With Quote
Old 10-18-2010, 02:15 AM   #5808
sosidge's Avatar
Anyone?
Did you try re-flashing the software again? The system quite often says the update failed, but trying again will make it work.
No idea whether running minimum settings will make 528STOCK run the same as 508_No_Timing.
Old 10-18-2010, 08:01 AM   #5809
san.'s Avatar
Trader Rating: 59 (100%+)
Even if you turn down/off the timing settings in 528Stock, it will not be legal for the "No Timing Stock" class. It must have a blinking LED to pass tech.
Like sosidge stated, try reflashing a again, or try another USB port.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 10-18-2010, 08:22 AM   #5810
I've tried that before, by running the 528 software with all boost settings to 1 you get the same performance as running the 508 no timing software.
Of course is not legal, since there's no blinking led.
Fastfreddy74 is offline   Reply With Quote
Old 10-18-2010, 12:01 PM   #5811
Solara's Avatar
Trader Rating: 16 (100%+)
Anyone?
No...if your track asking for the ROAR no timing rule, you have to run the 508_no_timing software. Even turning off all the setting from 528 down to 1 is still has the advantage over the 508 "somehow"....and you will have a lot of explaining to do if someone is questioning you about the software that you use and where is the blinking light.
I have tried alot of time helping others uploading software from 528STOCK to 508_no_timing without any problem...check your computer, I bet it is the VISTA or Win 7 thing...I used Window XP just so I don't have to deal with all the new bugs.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 10-18-2010, 12:05 PM   #5812
Solara's Avatar
Originally Posted by KELVIN KHNG View Post
Hi Guys...
Any idea what is the difference between the Cirtix version 2 and the stock cirteix esc? I plan to get one for VTA... any recommendations?
Kelvin...there is no such thing is Cirtix version 2, very much all the cirtix club spec ESC at the shop now are NOVAK/LRP competable.....if not, let SP USA knows and they will take care of you.
Like Blake said...the newer batch should have the USVTA logo on the box and inside the box there should be extra USVTA DECAL for you to place it on the ESC and convert it to USVTA edition club spec ESC.
You can see that at the upcoming I-hobby Expo this weekend.
Old 10-18-2010, 03:59 PM   #5813
KELVIN KHNG's Avatar
Trader Rating: 15 (100%+)
Sounds Good... Will there be esc's available at the Ihobby? Cos I will definitely be going and I hope to get ahold of a piece of the Cirtix...
KELVIN KHNG is offline   Reply With Quote
Old 10-18-2010, 10:57 PM   #5814
Thanks to everyone for trying to help. I can't even get my LCD to talk to my computer now. I even tried it on my older computer with XP rather than Vista. I think my track will be ok with the 528 with 9 and 12 set to 1 as long as I can confidently tell them that is that is no timing. I think that is what I am still hearing here. Otherwise I'll just go back to using one of my v1.1 LPFs with #9 set to zero degrees.
Don Skaggs
Old 10-19-2010, 10:43 AM   #5815
Solara's Avatar
We are not allow to do sales at the show. But please do stop by and we can show you how to get the ESC....you can try buy me DINNER first.
Old 10-19-2010, 10:44 AM   #5816
BoneCrusher's Avatar
Not sure if it has been asked but is there any word on when or if the 2.1 with the 508 software or the Cirtix speedo will qualify for Roar Sportsman Speed Control approval.
Thanks,
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 10-19-2010, 10:46 AM   #5817
Solara's Avatar
Make sure your LCD get the latest update....go to the SP interface and under device, choose LCD programmer, then upload the latest software there.
Hope you can get that connected.........otherwise, blaim STEVE JOB or BILL GATES.
Old 10-19-2010, 10:51 AM   #5818
Solara's Avatar
Thanks,
Ivan
IVAN....ROAR is re-doing (re-inspection) the no timing specification and inspection right now, we are planning to submitting the CLUB SPEC, GT2.1 ProSTOCK and GT2.1 EX ESC with no timing software installed for ROAR approval. We are confident enough that our ESC and software are qualified to be LEGAL for the ROAR sportsman class....
We are doing the 2010 I-hobby Expo this week, so everything will be submit sometime next week...and we are hoping the above ESC and software will be legal in NOVEMBER.
Old 10-19-2010, 11:48 AM   #5819
Any ideas when the new 1S range of motors will be available in Europe ??
i would like a 13.5 version for my Tekin powered 1/12th
sidecarphil1 is offline   Reply With Quote
Old 10-19-2010, 12:19 PM   #5820
marcel p's Avatar
Send a message via MSN to marcel p
phil .mail toni
think he has them or wil get them soon.
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Yolks_r55
SEO by vBSEO 3.5.0
