Like Tree46Likes
Old 10-13-2010, 08:15 AM   #5776
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by tha Beast View Post
anyone know where i can get the new 2.1ex?? i need one asap
Check out the LHS that made the pre-order from us last month...the current batch were all sold out, but checkout the LHS and other online dealers...
Also...I am hoping you are not going to use it on your TCX....it is not suppose to be use on 2S TC.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 10-13-2010, 08:22 AM   #5777
Solara's Avatar
Originally Posted by Magnet Top View Post
Thanks, I grabbed the only 10.5 one there is. It is for a Novak on asphalt , but it'll get me started.
Cheers
Yes...please do gear down alot since you are running a small CARPET track. The one on SP site is from Jimmy Stegen and the track was a 125 x 275 1/8th on road track...hugh different in gearing.
I would guess (again, if I am the one running) using 8.2 final drive, then use Jimmy's setup...adjust your #14 to 0.1s or so and leave the rest the same as Jimmy's setup should be a good start. Temp your motor and compare your lap time and adjust gearing....
#4, #14 and #15 should be the area that you should adjust.
Let us know your finding and I can have that posted on the SPEED PASSION website.
Old 10-13-2010, 08:29 AM   #5778
Originally Posted by Solara View Post
That is awesome BLAKE............BLAKE is our junior drivers that actually kicked my butt in indoor carpet almost all the time, if he said his V2 can run around 180, then it is the truth....and his car is one of the fastest SPEC car amoung all the other big boys.
As a matter of fact...you should send me your club spec setup so I can post it on SP site...so does your OPEN 17.5 setup. Not bad for a 10 years old....
He whipped my Tekin butt last night again, , no more set up help for you!
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 10-13-2010, 10:12 AM   #5779
Vicko's Avatar
Trader Rating: 14 (100%+)
So what version sofewear is the use for the roar stock spec. The 1 with no boots and timing?
Vicko is offline   Reply With Quote
Old 10-13-2010, 10:34 AM   #5780
defcone's Avatar
Trader Rating: 15 (100%+)
There should a version you can choose which has NO TIMING next to it on the upgrade tab.
defcone is offline   Reply With Quote
Old 10-13-2010, 10:35 AM   #5781
Fred Hubbard's Avatar
EDIT: It will read 508 No Timing.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 10-13-2010, 11:17 AM   #5782
Solara's Avatar
Well, you are using the wrong ESC, thats why...
BTW....208 is no longer legal for spec racing. Just for you to know....
Old 10-13-2010, 11:19 AM   #5783
Solara's Avatar
The full name is 508_no_timing (thanks Freddy).........that is the software name, if you are planning to use the ROAR sportsman rule software.
We are submitting the CLUB SPEC ESC, the GT2.1 Prostock and GT2.1 EX to ROAR for the Sportsman Rule...hopefully these ESC's name will be up there soon.
Old 10-13-2010, 12:02 PM   #5784
StarrRacing's Avatar
Default Help
Howard..?? Anyone..??
Hope that you and yours are well.
I won a Speed Passion ESC at the Asphalt Assault Race.
I already had a Speed Passion 17.5 Motor (New In Box)
at home...
I tried to hook them up in my son's SC10 with a
Traxxas 2.4 Radio and Rcvr....
It programs "exactly" the way the Directions say,
seems fine, and I get steering but No Motor function.
I have tried different motors, and different receivers.
Any ideas?
Jeff Starr
U.S. Coast Guard (Retired)
Traxxas 4x4 (x2), Associated SC10,
XRay T3 '009 (VTA), XRay T3 '10 (USGT), Tamiya M05 (Mini),
Tekin, Spektrum.
StarrRacing is offline   Reply With Quote
Old 10-13-2010, 05:23 PM   #5785
mr crum's Avatar
Send a message via Yahoo to mr crum
at home...
Any ideas?
did u try changing the sensor wire
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 10-14-2010, 05:07 AM   #5786
Default ESC
Thank you for your response.
Yes, I tried different sensor wires also...
Jeff Starr
Tekin, Spektrum.
Old 10-14-2010, 06:30 AM   #5787
TAMAK's Avatar
Trader Rating: 28 (100%+)
Smell it, if it smells funky it did what mine did.
TAMAK is offline   Reply With Quote
Old 10-14-2010, 07:05 AM   #5788
Solara's Avatar
at home...
Any ideas?
Please check PM...thanks
Old 10-14-2010, 06:43 PM   #5789
trackrat3
Guest
Posts: n/a
Here you go Howard this is my spec Speed Passion setup.
Car is a 07 Corally PHI
Speed Passion Cirtix ESC with Speed Passion V2 17.5 motor
Setting 1 is 9=100% ABS Braking
Setting 2 is 4=30% Drage Brake
Setting 3 Off Thermal
My final drive is a 4.4
Thanks Eric at Harbor Hobbies for the setup help.
Old 10-14-2010, 08:40 PM   #5790
I tried to upgrade from the 528 stock to the 508 and a note popped up saying I could not upgrade to that software. Any ideas? Will the SC have the same performance if I set 9 and 12 to setting 1 with the 528 as it would with the 508? I have the GT 2.0 LPF and previously loaded the 528 software using the same computer. Thanks
Don Skaggs
RCMaster1 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
