Like Tree46Likes
Old 10-11-2010, 09:58 AM   #5746
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by GerwinGood View Post
I wanna try gt2.0 with The 528 software and THE 13,5 v3 speedpassion motor.
Now im searching for ŗ good indoor carpet setup. Could anyone maybe give me an start example and what i maybe can try.
Thx all.
Plenty of those on SPEED PASSION website...go check it out.
13.5 is very much the same as 17.5 ESC setup....you just have to use higher gearing for 13.5 compare to the 17.5....ESC setup is very much the same or adjust alittle per your own perference.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 10-11-2010, 09:59 AM   #5747
Solara's Avatar
Originally Posted by Scrad View Post
Guys looking for some advice on a very smooth offroad profile for 2wd buggy.
I'm currently running a 13.5, but might go down to a 10.5 later. I had the 110 stock on it and it was too aggressive and the throttle curve hit too hard in the midrange. I just wasn't smooth.
I just flashed the esc to 508 no timing. Any suggestions other suggestions for 2wd buggy. Other wise I was thinking of the 205 mod.
Stay away from those old software like 110...
Use 205g if SUPERCHARGER is not something you can take advantage of...otherwise, use 528MOD.
Speed Passion website has plenty of off road setup for you to use.....please check it out.
Old 10-11-2010, 10:02 AM   #5748
Solara's Avatar
Originally Posted by san. View Post
Jimmy, doh...human error. I got it to work. Thanks again.
Not trying to pull your leg....what was the problem? I would like to know so I can record it for future customer reference...you can PM me. Thanks.
Old 10-11-2010, 10:11 AM   #5749
san.'s Avatar
Trader Rating: 60 (100%+)
I was calibrating my radio as I would for the Super Charger firmware. I was setting my Throttle EPA to 95%, calibrate, then put it back to 100%. Using this method would not allow the LED to blink. It started working once I set the EPA back to 100% before starting the calibration sequence.
I'm sure this fixed it, or I must be on some heavy fluids...lol
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 10-11-2010, 10:12 AM   #5750
Solara's Avatar
Originally Posted by prorace View Post
Should I gear a Ultra sportsman 2 13.5 on the same ratio as a 13.5 V3?
The recommended ratio on the datasheet included with a v3, are for touring, 2wd....???
Which rollout Should I use on a 17.5/13.5 2s F1?
Sorry for my poor english
Yes...13.5 are the same, just V3 can adjust timing...but V2, you should not adjust the timing...you can gear the same. But depends on which ESC you are using and what software....like TURBO/SUPERCHARGER or not...
Recommended final drive on the manual is for 13.5 motor with standard timing advance...it is for 13.5 motor in general, not necessary for what type of car you are using...
For F1..is that rubber tires or foam..? It really depends on your tires size...I used 1.75" rollout on 13.5 before...but you have to really check it out yourself.
Old 10-11-2010, 10:15 AM   #5751
Solara's Avatar
Im in the process of switching to sp gt 2.0pro esc + sp 3.0 9.5r motor and im in need of a esc setup for mixed asphalt running rubber. Also a tip on where to start on the fdr for the 3.0 9.5r would be appreciated.
Anyone got a suggestion?
(1) Try 528MOD software if you want supercharger...otherwise, use 205G....using 528STOCK on 9.5 is a risk, you need to know what you are doing...
(2) Checkout speed passion webiste, you can try some 10.5 setup and gear down by 1-2 tooth and check temp.
(3) If using supercharger, I would think gear at 8 or so on final drive.
Old 10-11-2010, 10:17 AM   #5752
Solara's Avatar
Seriously...that is good to know.
Since you are doing NO TIMING software...yes, there is no reason to use 95% and back up to 100% TURBO/SUPERCHARGER throttle EPA setting like when we are using 528STOCK or 528MOD.
Good luck....
Old 10-11-2010, 10:35 AM   #5753
lorider75's Avatar
i have a gt 2.0 lpf esc that has been used for 1/12 with 4 cell and i have noticed that there is a ton of software updates available for the esc. How does one install these updates?? i know with my tekin i needed the hotwire but i dont really see anything like that on speed passion's website. any help would be greatly appreciated.
thanks,
anthony
Team High Torque * Extremercmods.com
lorider75 is offline   Reply With Quote
Old 10-11-2010, 10:37 AM   #5754
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
thanks,
anthony
you will need the LCD programming box and a computer
RACE OPT USA
Bartolo Racing R/C
Old 10-11-2010, 11:24 AM   #5755
Did run quite a few runs on sunday with 528STOCK using Marcos.J settings for 13.5 asphalt. FDR was 6.56. Motor temp was never above 65c and esc was just about cold to the touch.
The car felt like it had good punch in the start but lacking some midrange and top speed. Was hoping to beat my old personal best from when running tekin rs and lrp 9.5.
XRAY T3 2012 | Speed Passion GT V2.0 Pro | Competition MMM 10.5R
minifo is offline   Reply With Quote
Old 10-11-2010, 02:09 PM   #5756
peter george's Avatar
Trader Rating: 351 (100%+)
Originally Posted by TRXRACER99 View Post
capacitor maybe or loose connections to the battery
Thanks so much, I dont think that there is anything wrong with the speedo so you may be right.Thanks.
I donít always talk smack but when I do itís 99% spot on
peter george is offline   Reply With Quote
Old 10-11-2010, 02:11 PM   #5757
Originally Posted by robk View Post
Remove the low voltage protection. You may be bumping on the low voltage protection when you rip the throttle.
Thank you.Once again all the help is much apriciated,I never used a speedo with boost or timing before but I am sure I will get used to it.
Old 10-11-2010, 02:25 PM   #5758
M-Technic's Avatar
Trader Rating: 15 (100%+)
Go up a few more teeth.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-11-2010, 03:32 PM   #5759
mr crum's Avatar
Send a message via Yahoo to mr crum
Angry
Club spec has only 3 options to adjust, and cannot be use with the USB interface.....USB is for the rest of the CIRTIX series ESC except club spec.
One of the design for club spec is.....we don't want it to be able to connect to any computer for TRUE SPEC racing. One of the rule on USVTA is, no computer or software upgradable ESC....Club spec is exactly one of those ESC that the USB interface will not be able to work. It is not something we cannot do on the ESC, it is something we are trying to do purposely so it can work with the true SPEC ESC rule.
You use only the plastic LED box for the club spec ESC adjustment.
the plastic box is what i tried to buy and al said this one is better so know i have a adapter and a usb wire that i cannot use at all
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 10-11-2010, 04:06 PM   #5760
Trader Rating: 8 (90%+)
Are there any software updates in the near future?
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris [email protected]
Tha Skinny is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
