Old 10-02-2010, 03:24 PM   #5686
zrxrxr's Avatar
Originally Posted by Solara View Post
Speed Passion will display their own APP at I-Hobby Show in Chicago for all the Speed Passion ESC control. It has a lot of feature more then just gearing chart....1st stage is for all I-phone, Ipad, Ipod Touch...then it will spread to MS mobile, Droid and HTC....
It does software upload and ESC adjustment, plus alot more feature that can be use for RC racing. We can all leave the netbook at home.
Stay tuned...
Sounds awesome, now what will it cost... Better be free if you already have a lcd program card...
zrxrxr is offline   Reply With Quote
Old 10-02-2010, 04:18 PM   #5687
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by Tha Skinny View Post
How is it possible to test the Hal sensor? Is this in the sensor end of the motor?
yes if you have another sensor wire try that first if that dont fix it try another motor also try resetting the speedo to your radio
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 10-02-2010, 09:36 PM   #5688
tha Beast's Avatar
Trader Rating: 100 (99%+)
noob question but WTH is a HAL wire im having the same problem as Tha Skinny just doesnt seem to rev up
REFLEXRACING
MIKES HOBBY SHOP PORTER TX
tha Beast is offline   Reply With Quote
Old 10-03-2010, 03:20 AM   #5689
sosidge's Avatar
A Hall sensor is what is used within the motor to detect the rotor position. They are mounted on a little removeable board in there. I don't personally know of any way to test them independently of running them.
If you have rough throttle response or slow motor speeds, it's probably a sensor problem. You can try cleaning the Hall sensor in the motor (because of the open slots in the v3 motor, I once had a problem with it because of fluff), or you can try replacing the sensor board and sensor wire with known good ones.
If that doesn't work, it might be a sensor problem within the ESC, which is not realistically repairable at home.
Old 10-03-2010, 03:47 AM   #5690
Just about to try a Duo2 13.5 with a 2.1 does anyone have a speedo setting they are willing to share and a gearing rec. for a 30m straight with flowing infield?
008-Racer is offline   Reply With Quote
Old 10-03-2010, 09:04 AM   #5691
Solara's Avatar
Trader Rating: 16 (100%+)
I downloaded the 10.5 stock profile from the website and have nothing bit problems. Same gearing and all. 50c thunder power lipo.
Yes...motor sensor went bad. Very typical when running SC on stock motor. Open up the can and carefully remove the sensor, then brush it off...alot of time, it is some little dirt or things that cause the circuit screw up. Alot of the time after this clean up...will solved the problem.
Try it....if not working, then you will need a new sensor board. Contact your shop and see they can order one or contact our office to place the order.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Solara is online now   Reply With Quote
Old 10-03-2010, 09:12 AM   #5692
Solara's Avatar
Go email Steve Job...I bet his reply is " LEAVE US ALONE"....LOL
To be honest, I don't even have a I-Phone nor any Apple products...I don't even know what is a typical APP cost for end user...
I am a PC and everything is almost FREE....
Old 10-03-2010, 09:15 AM   #5693
Solara's Avatar
This is the piece that I am talking about....try to reseat, clean it first...if all failed, this need to replace.
Old 10-03-2010, 09:16 AM   #5694
Solara's Avatar
Try here....between 17.5 and 13.5 is mainly gearing, 13.5 geared taller then 17.5, like 2-3T smaller pinion.
http://www.speedpassion.net/us/escsetup.asp
Old 10-03-2010, 09:26 AM   #5695
zrxrxr's Avatar
Exactly. I'm a PC person too but with an Iphone. Most apps cost a buck but generally you can get them free after they get popular enough. Who doesn't have a jailbroken Iphone nowadays?
Anyways, Any details to how the app will interface with the speedo? Will we still need to program card? Second, are you guys are also going to need to sell another cable or something to use with the app because the way I see it theres no way to connect to the device with the current hardware.
my 2c
Old 10-03-2010, 11:29 AM   #5696
The app sounds amazing, sure would beat spending 200 on a notebook!
Cocoon is offline   Reply With Quote
Old 10-03-2010, 03:09 PM   #5697
Trader Rating: 8 (90%+)
I'm am not running a sp motor. I will however try this and hope it works. Thank you.
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris Totcky@facebook.com
Tha Skinny is offline   Reply With Quote
Old 10-03-2010, 03:22 PM   #5698
Also.... When my my motor is in it's neutral position is the only time I get the blinking green light. On throttle and off throttle there is no light.
Houston,Texas
Serpent 733 EVO
Old 10-03-2010, 07:52 PM   #5699
tc3 racer sc's Avatar
Default GT PRO 2.0 cutting my power out to my lipos
i notice last cpl of days my lipo were losing power due to the wiring on my esc i think their touching at the bottom of the esc i moved the wire around it was fine i notice when i hit a bump or get hit it seems to lose the power /boost so what i need to do
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 10-03-2010, 07:55 PM   #5700
what up skinny this reggie i found why i was losing power my wire were touching at the bottom of esc how houston
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
