Like Tree3Likes
Old 09-05-2010, 09:00 PM   #5521
irgo's Avatar
Default SP GT 2 DMTS UPDATES
there is something wrong with the dmts on
firmware that i detect,
old stock firmware and the stock sc firmware.
Since the stock sc(super charge) firmware is based on first stock firmware.
And this is what i found
as i turned off the supercharge, and works with dmts only,
it just can't beat the super stock brushed
with gt7 , with equal motor turn.
With same timing and fdr, the dmts will just fail and loosing alot of max torque, no matte we max out the drrs to level 9.
And we found the reason,...
It's because DMTS is working with DRRS throught throotle,
and don't have start rpm.
It change the timing too early there, when throtle is just at about 50
what speed passion have to do is
add start rpm on DMTS
and let the timing at zero until the edge rpm reach.
SP GT2 must have
2 start rpm:
1.DMTS RPM START
2.SC RPM START
the result will be a better cornering!
We need comment about this.
Quark Force
irgo is offline   Reply With Quote
Old 09-06-2010, 07:28 AM   #5522
Originally Posted by tc3 racer sc View Post
i guess no help on my question can any one help
You need to use the setup completely. With the same FDR also.
On another note. I've tried to attach my set sheets and it tells me they are to large. How do you down size them?
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 09-06-2010, 08:02 AM   #5523
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
anyone need a LCD USB Professional Programmer??
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-06-2010, 08:48 PM   #5524
tc3 racer sc's Avatar
email it to me reginald67@yahoo.com
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 09-07-2010, 01:47 PM   #5525
Hey guys, when adjusting the timing on a V3.0 Competition 17.5 brushless, should the timing/sensor be able to move without loosening the can bolts. Mine can be pushed either direction when the bolts are still tight? Is this normal.
Secondly, what timing level, 0-10, do you guys recommend (I'll keep an eye on temps) for an SC10 on a fairly tight track? I'm running a Associated SXX-Competition ESC; should I leave the timing on the motor alona an just use my ESC? What settings/power levels do you run on your ESC?
Thanks!
BestNThDez is offline   Reply With Quote
Old 09-07-2010, 02:54 PM   #5526
Send a message via MSN to geubes
@Speed Passion
Any new firmware due for release soon?
528_Stock has been out a fair while now, maybe you guys have had some more time to play with it to squeeze out a little more performance?
or are you waiting for the competition to take the advantage?
geubes is offline   Reply With Quote
Old 09-07-2010, 09:17 PM   #5527
Solara's Avatar
Originally Posted by geubes View Post
@Speed Passion
New software (stock and modified) testing @ TITC the last couple of weeks. They have to make sure the new software won't burn motors within minute before releasing....stay tune.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 09-07-2010, 09:28 PM   #5528
defcone's Avatar
Trader Rating: 15 (100%+)
Wasn't TITC ages ago?
defcone is offline   Reply With Quote
Old 09-07-2010, 11:11 PM   #5529
skypilot's Avatar
Trader Rating: 14 (100%+)
just so were all clear on the question...charlie gave you a setup, but you decided to not run the gearing for that setup, and your wondering why your car faded and the motor got hot. Is that the question?
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 09-08-2010, 02:28 AM   #5530
irgo's Avatar
willson said this month.
Quark Force
Old 09-08-2010, 02:33 AM   #5531
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Is this update more a refind of current software or a complete new setup?
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 09-08-2010, 03:18 AM   #5532
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
You know, i did about 90-95% of the testing for the 100422 and 100528 for Speedpassion on a Cyclone. What magic answer are you looking for? You didn't even try everything i suggested.....
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 09-08-2010, 03:23 AM   #5533
Azr
Azr's Avatar
Send a message via Yahoo to Azr
Originally Posted by kschu View Post
Is it compatible with the 1st version ESC?
Azr is offline   Reply With Quote
Old 09-08-2010, 05:24 AM   #5534
Default 7.5T
I'm running a photon with a 7.5T on a medium sized outdoor track with a straight of about 30 meters.
What software (and settings), and FDR do you guys recommend?
help appreciated.
Sam
sammies is offline   Reply With Quote
Old 09-08-2010, 07:43 AM   #5535
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Solara are you in charge of the Speedpassion website? If so can you make sure that my set up is posted along with Harolds?? mine is posted on here but I can send you a copy if you need it.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
