Like Tree3Likes
Old 09-04-2010, 01:20 AM   #5506
Fred Hubbard's Avatar
Originally Posted by altreyx View Post
my sheets are encrypted, i don't know the program that you are using (distiller??) Try to use Acrobat Reader 9.xx or Foxit Reader 4.1. I have both and both are working. Foxit is free and very small respect Acrobat Reader. Sheets are build for to be compatible with the 9,xx version of Acrobat reader or above. A friend of mine had a similar problem with a PC...and with the exactly the same software on another pc was working. I suggest you to try Foxit , it is small about 10Mb and is full compatible. Hoping this can help you otherwise contact me by pm and will try to solve this issue
I'm using AA9 Pro. The wierd thing is I have no issues printing PDF's from other templates it's just this one form. Thanks
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 09-04-2010, 03:38 AM   #5507
marcel p's Avatar
Send a message via MSN to marcel p
Originally Posted by mr crum View Post
sounds to me you might want to drop #15 1 or 2 and/orlower fdr
and the only motors that ive heard dont sc sp is lrp vector x11/x12 havent heard of any others
had 15 at 6
timing back to 15deg
fdr from 6 to 7.5.
maybe gear under 6 to lower the constant high rpm .?
like the gm users do to keep it cooler even to 4.6 fdr with sc setings on
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 09-04-2010, 09:23 AM   #5508
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by marcel p View Post
had 15 at 6
fdr from 6 to 7.5.
the 528 does like higher fdr but you have to be carefull
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 09-04-2010, 09:44 AM   #5509
zrxrxr's Avatar
Originally Posted by Fred Hubbard View Post
Fear not, it's okay to use it on that speedo. Since I primarily run Mod I've got GT 2.0's in both my cars and I'm using 528Stock on one of them for IIC. Been running 528Stock for about 3 weeks not without any issues.
Awesome thanks
zrxrxr is offline   Reply With Quote
Old 09-04-2010, 02:57 PM   #5510
Vicko's Avatar
Trader Rating: 14 (100%+)
anyone here have an good speedo setting for the 528 sofewear??
Vicko is offline   Reply With Quote
Old 09-04-2010, 03:36 PM   #5511
qcrc's Avatar
Marcos and Jimmy both have some good setups. They can be found a few pages back.
Schumacher Cars
Speed Passion Powered
qcrc is offline   Reply With Quote
Old 09-04-2010, 09:38 PM   #5512
tc3 racer sc's Avatar
Originally Posted by tc3 racer sc View Post
i ran charlie set up on my cyclone it was a lot of power but toward the end of race it seems to die off my motor was about 170 or so i ran the 17.5 gt 2.0 set up but did not gear it the way he had it i think i was in the 6.0 to 6.5 range plse help thxs and what a good gearing on my cyclone tc
i guess no help on my question can any one help
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 09-05-2010, 06:55 AM   #5513
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
end RPM...
I looked at some of the .pdf which you can download from this thread...
The end RPM can be anything from 8k to 20k difference
Can anyone shed light on which makes for a better setup??
short end RPM range or a long end RPM range?
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 09-05-2010, 08:07 AM   #5514
zrxrxr's Avatar
How exactly do you set the end rpm?
I know a longer range will result in a smoother feel.
Old 09-05-2010, 10:48 AM   #5515
Vicko's Avatar
so with the speedpassion motors where do you guys run the timing on the motors at
Old 09-05-2010, 04:32 PM   #5516
I run mine at 10 degrees. Victor, send me your email address and I will send you my setup for indoor racing. It will be to your liking.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 09-05-2010, 04:57 PM   #5517
second that, 10 degrees is fastest with the current software.
Mike
ixlr8nz is offline   Reply With Quote
Old 09-05-2010, 05:08 PM   #5518
Me_MrTyson's Avatar
The Formula is like this.. (just put it into a excel file quick and easy)
END RPM = Item#13 DMTS Timing Start RPM + (Item #9 DMTS Timing + Item #12 Super Charger Timing ) * Item #15 Super Charger Timing Punch
The breakdown is the lower the start RPM (#13) higher the Super Charger punch (#15) the longer the end RPM.
Old 09-05-2010, 05:16 PM   #5519
=FLIP='s Avatar
Trader Rating: 24 (100%+)
arghh i see you are using hobbywing now bd no good eh?
--------------------------HOBBYWING----------PROAMP LIPOS----------------------------
-EAD- Racing NEED SPEED GET SOME EAD-
=FLIP= is offline   Reply With Quote
Old 09-05-2010, 08:48 PM   #5520
tha Beast's Avatar
Trader Rating: 100 (99%+)
good luck you gotta know someone here to get some help i have asked so many questions on this thread and ive got help once!!!! so i tend to just take the long way and figure it out myself takes longer but i figure it out eventually......good luck
tha Beast is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
