Old 09-03-2010, 10:14 AM   #5491
M-Technic's Avatar
Trader Rating: 15 (100%+)
Going to post the setup sheet this weekend, I got side tracked last night and I won't be around tonight.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 09-03-2010, 11:19 AM   #5492
Korey Harbke's Avatar
Originally Posted by san. View Post
Korey, which ESC did you use when took 3rd at the USA Electric 17.5 Paved Nationals?
That was a Team Orca ESC, but I no longer run for them. I should be taking my maiden voyage on Speed Passion equipment on Wednesday
-Korey
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 09-03-2010, 12:44 PM   #5493
Trader Rating: 16 (100%+)
-Korey
See...and I could have made you a "T Special" at the Nats...You could have WON! LOL
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 09-03-2010, 01:03 PM   #5494
zrxrxr's Avatar
Hey quys quick question. Is the latest firmware for stock with timing advance and SC, V2.0_100422STOCK? If not how do I go about getting a newer version? Thanks
zrxrxr is offline   Reply With Quote
Old 09-03-2010, 01:31 PM   #5495
M-Technic's Avatar
No, it's 528_STOCK and you can download it from Speed Passion's web site.
Old 09-03-2010, 03:22 PM   #5496
irgo's Avatar
Default Speed Passion Stock Firmware mid 2010
acctually there was 2 type of Stock Software from Speed Passion
1) is Stock based Advanced Dynamic Timing (only) (3ver).
2) Stock Software Advanced Dynamic TIming with Supercharge (Timing)
with 2 type of Firmware 100422 and 100528. 2010/04/22 and 2010/05/28.
Quark Force
irgo is offline   Reply With Quote
Old 09-03-2010, 03:34 PM   #5497
zrxrxr's Avatar
KK I found it under downloads for my speed control. It says this one the download though:
Program
Speed Passion USB Interface software V1.33 and software #100528
This for GT2.1 Prostock only !
You must use the new PC interface V1.33
Not being one to worry much, I threw it on my speedo anyways. It updated fine, should I be concerned or will it work fine?
PS: I have the gt2.0 LPF
Old 09-03-2010, 04:33 PM   #5498
marcel p's Avatar
Send a message via MSN to marcel p
try to ask again
has sombody tryed the gm motors 13.5t on the sp speedos with stock software.
or do you now motors that didnt work on stock software.
i dith test the team powers 13.5 and it was not great.
alot of heat in it. had to turn down the setings and it was not fast with the setings down but cooler.
with the same setings as with my 13.5 sp motor it was fast but hot after 2 min.
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 09-03-2010, 04:55 PM   #5499
zrxrxr's Avatar
I'm using a Fantom 17.5 and I can put all the boost settings on high max punch and everything with a 25/75 gearing with a 2:6:1 ratio and it runs perfect.
Old 09-03-2010, 07:16 PM   #5500
Fred Hubbard's Avatar
Originally Posted by altreyx View Post
Done!
I released it some days ago, just forgot to put it online
Sorry.
PS: under the SC Punch (#15) i just added the voice that i read on the LCD program card, so should be more easy now read the value.
altreyx whenever I try to print from this pdf it generates an error message about the file being encryted and just creates a log file. I put the contents of the log file into a word document since this forum doesn't allow the attachment of .log files. Thanks
File Type: doc test.doc (263 Bytes, 102 views)
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 09-03-2010, 10:23 PM   #5501
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by marcel p View Post
try to ask again
sounds to me you might want to drop #15 1 or 2 and/orlower fdr
and the only motors that ive heard dont sc sp is lrp vector x11/x12 havent heard of any others
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 09-03-2010, 10:39 PM   #5502
Program
Fear not, it's okay to use it on that speedo. Since I primarily run Mod I've got GT 2.0's in both my cars and I'm using 528Stock on one of them for IIC. Been running 528Stock for about 3 weeks not without any issues.
Old 09-04-2010, 12:25 AM   #5503
altreyx's Avatar
my sheets are encrypted, i don't know the program that you are using (distiller??) Try to use Acrobat Reader 9.xx or Foxit Reader 4.1. I have both and both are working. Foxit is free and very small respect Acrobat Reader. Sheets are build for to be compatible with the 9,xx version of Acrobat reader or above. A friend of mine had a similar problem with a PC...and with the exactly the same software on another pc was working. I suggest you to try Foxit , it is small about 10Mb and is full compatible. Hoping this can help you otherwise contact me by pm and will try to solve this issue
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 09-04-2010, 12:31 AM   #5504
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Default SC Punch #15
.. found the answer
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 09-04-2010, 01:25 AM   #5505
now betraying my memory ..
What was it now. the solder to the capacitor esc. it was red to battery ( + ) and black to the battery ( - ) ?
Zooberg is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
