Old 08-14-2009, 09:26 AM   #526
Born2Run's Avatar
Males sounds good to me. Have you checked the rotor diameter?
Whatever
Born2Run is offline   Reply With Quote
Old 08-14-2009, 09:47 AM   #527
abailey21's Avatar
Trader Rating: 36 (100%+)
12.3
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 08-14-2009, 10:03 AM   #528
Born2Run's Avatar
Adam thanks for the info.
Whatever
Old 08-15-2009, 12:50 PM   #529
Super_Roo's Avatar
Got a question about the voltage cutoff on the GT2. I've got an old GT1 and the voltage just stops supplying power to the motor when I hit cutoff, my friend with the V2 it seems to continue to power the motor when it hit cutoff but at a very reduced speed.
Is this correct or is there something wrong with his GT2?
When his does this we check the battery with dvm and it shows the voltage at well below the 3.4v/c cutoff.
Super_Roo is offline   Reply With Quote
Old 08-15-2009, 05:39 PM   #530
cyanyde's Avatar
Yes. This allows you to get your car back to the pits intead of stopping in the middle of the track. It starts at exactly 3.4v/c.
cyanyde is offline   Reply With Quote
Old 08-17-2009, 09:12 AM   #531
tfrahm's Avatar
Send a message via AIM to tfrahm
Originally Posted by Shawn Palmer View Post
Hi Benny,
Any physical advance already on the motor is a static baseline the software works off of. As for exactly how we're manipulating the timing within the ESC to get better top end and punch while still retaining runtime and keeping the motor cool - that's a secret
Shawn -- I understand "trade secrets", but I have been trying to do my research on the SpeedPassion products and I found a quote from you on an old thread (about the 1.1 version?);
Speedpassion GT ESC
To clarify the manual and motor timing:
The manual recomends running the physical timing on the motor itself (if adjustable) at zero.
In truth - REGARDLESS of what BL motor you're running, the GT ESC alone controls timing advance, because it's switching into sensorless mode almost immediately after the motor starts turning ("Hybrid Drive"). Therefore - any timing advance positions on the motor (which are sensor-based) aren't being used anymore.
Obviously a BIG tuning advantage if your motor itself has no adjustable advance.
Is this information ONLY for the earlier version, or is this also true for the GT 2.0? I ask because althought I currently have an SP13.5R 'UltraSportsman' motor connected to my GT 2.0 LPF, I will also be trying it with a Novak SS13.5Pro and I don't want to "smoke" something by cranking the timing on the ESC and finding out it is ADDED to the ESC setting...?
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 08-17-2009, 09:30 AM   #532
Shawn Palmer's Avatar
Hi Tom,
That does not apply to the 2.0. the total advance is equal to the ESC plus the motor advance.
Super-Roo:
The 2.0 speedos were ment to reduce speed as a warning for voltage (and also for excessive heat if applicable). When you see it slow down, head for the pits immediately.
It still does keep the voltage at a safe level though. What voltage were you seeing on your friend's car after it engaged, and how long did he continue to drive it after the slowdown?
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Old 08-17-2009, 09:34 AM   #533
To Pablo Diablo:
I haven't had much time to be here lately, and Adam isn't as up to speed on the advance stuff and intricate inner ESC workings as I am.
What specific questions have yet to be answered for you? I'd be happy to help.
Shawn Palmer
Old 08-17-2009, 09:53 AM   #534
tfrahm's Avatar
Hi Tom,
GREAT! Thanks for the update -- I needed to be sure...
That does raise a quick follow up -- Novak has said their Ballistic 13.5's are set at 30 degrees "actual" timing at the factory... What is the built in timing on the SP UltraSportsman 13.5R motor? (This will help me know how much of a change to make when switching back and forth during testing.)
Thanks in advance...
Old 08-17-2009, 10:07 AM   #535
Other than Novak, most all other motors come with around 11-13deg of factory advance if they aren't adjustable.
Shawn Palmer
Old 08-17-2009, 11:54 PM   #536
auzzy_mate's Avatar
Default Speed Passion 17.5
Hello All,
I am just writing to say hello, my name is Ben and I am new to the Speed Passion family.
I have previously ran a Novak 17.5 but due to an "unfortunate schmelting accident" I now run a Speed Passion 17.5. I will admit I was very apprehensive at first, having run the 'other' motor for so long, but I am now a very happy racer with SP power.
My question is to do with gearing (I know, always a tough one).
I ran the gearing at FDR 3.5 (rollout 56.5mm) and got temperatures up around 110deg 'f' on an indoor carpet track which was high grip.
In your experience what sort of rollouts / ratios have people run (LRP Stock Spec ESC factory settings) with the 17.5?
Ben
auzzy_mate is offline   Reply With Quote
Old 08-18-2009, 12:07 AM   #537
Originally Posted by auzzy_mate View Post
Hello All,
Ben
Gear for lap times ben.. And keep an eye on temps. As long as you are not too hot you can go up if it improves your lap times.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-18-2009, 12:53 AM   #538
razzor's Avatar
I have found my cars gearing to limit me with 17.5.
I have gone up to 57mm on new foam tyres at 65mm diameter.
definately can gear up as each time i changed to a bigger pinion the car got faster and motor has just gotten over 60 deg/c. Need to find smaller spur gears now.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-18-2009, 01:52 AM   #539
Giorgio's Avatar
I know...it will be a silly question...
I've a Speedpassion 2.0 4.5 turn motor.
I open for clean it and didn't mark the endbell position, which was factory setted.
Reassemble everything and... which was the timing from factory?
Can some one tell me which is the correct position? The endbell cna be moved by an huge amount of travel...
Giorgio is offline   Reply With Quote
Old 08-18-2009, 03:52 AM   #540
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
V3.0 stock motor adjustable timing right ?
Give the best while u can !
kschu is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Possum
