Like Tree34Likes
Old 08-24-2010, 10:55 AM   #5371
Originally Posted by irgo View Post
FDR based on Motor Manual only for non Stock Software.
(too Low)
Marcos said 5.4-6.0, that's not much difference to the SP motor instructions
S.A.W is offline   Reply With Quote
Old 08-24-2010, 11:01 AM   #5372
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
its weird but with the new software the ratios are pretty close to what they were with the non supercharge software, the speeds are ballistics and the heat is low
Old 08-24-2010, 12:27 PM   #5373
John.C's Avatar
Trader Rating: 36 (100%+)
You can only adjust the settings with the program card, you need the LCD program box to update the software.
Yes, I wasn't clear. A local racer who has the LCD program box will be upgrading the software. I was wondering if all of the items and values will remain the same after the upgrade to version 528. My program card has a slider with the chart for the various items and values. I'm wondering if this is going to change.
Thanks.
John
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 08-24-2010, 12:32 PM   #5374
Thanks.
John
I'm pretty sure that when you load a new software it loads the default settings, but you can save upto 3 profiles on each software version, think that's right.
Old 08-24-2010, 03:29 PM   #5375
Thanks guys, (Charlie b and irgo) I`ll give it a shot!!!
asfastasu is offline   Reply With Quote
Old 08-24-2010, 04:18 PM   #5376
skypilot's Avatar
Trader Rating: 14 (100%+)
Thanks.
John
when upgrading from 422 to 528 the max AMTS, OR DMTS timing as it is called thats item #9 I believe, is lowered from a max of 26.25 to 21.0
the rpm values in rpm delay is also changed, I don't remember what they are.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 08-24-2010, 05:17 PM   #5377
san.'s Avatar
Trader Rating: 59 (100%+)
I will post pics of all the official and current values.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 08-24-2010, 05:37 PM   #5378
san.'s Avatar
AMTS Values (use to be called DMTS):
0* - 21*
Boost Level:
Off - Stage 8 (Max)
Start RPM aka RPM Delay:
4000 - 12000
Throttle Delay:
0.0s (aka Off) - 0.8s
Punch:
Max - (-6)
Hopefully the screen shots of the official source will clear any confusion.
Old 08-24-2010, 05:51 PM   #5379
san.'s Avatar
altreyx, you think we can get a revised ESC Setup Sheet to reflect the new RPM Delay range?
Thank you in advance.
Old 08-24-2010, 06:36 PM   #5380
irgo's Avatar
right because for 13.5T :
motor manual FDR for non stock is : 4.8~6.0 >6cell
SC SUGGESTED SETTINGS FDR : 6.5~7.0 >6cell
so 5.4~6.0 is in range for NoTiming & 205, but never use it for Stock Soft SC.
Quark Force
irgo is offline   Reply With Quote
Old 08-25-2010, 12:27 AM   #5381
altreyx's Avatar
Done!
I released it some days ago, just forgot to put it online
Sorry.
PS: under the SC Punch (#15) i just added the voice that i read on the LCD program card, so should be more easy now read the value.
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 08-25-2010, 12:29 AM   #5382
Ok thanks, out of interest for the 10.5 they suggest 5.5-6.0 is that correct, ?I thought you need to gear it down for the lower turn motors ?
Old 08-25-2010, 01:48 AM   #5383
irgo's Avatar
for 10.5T :
motor manual FDR for non stock is : 5.2~6.2 >6cell
SC SUGGESTED SETTINGS FDR : 5.5~6.0 >6cell {with condition Lower DMTS #9(5) 12}
Quark Force
Old 08-25-2010, 03:03 AM   #5384
razzor's Avatar
The suggested gearing sheet/manual provided with the motor is for non Supercharged software. These documents have not been updated in years and are applicable to the original non SC firmware and in some cases even the older V1 esc.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-25-2010, 03:54 AM   #5385
Skitee's Avatar
Originally Posted by altreyx View Post
Done!
Sorry.
Do you by any chance have one available for 528 MOD ?
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
