Like Tree32Likes
Old 08-23-2010, 07:22 PM   #5356
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Tha Skinny View Post
Ok... Thats what I thought. How does 1s run comparing the 422 and the 528 ?
I've only ran it in TC and quite truthly running the same settings I couldn't tell a difference.
defcone is offline   Reply With Quote
Old 08-23-2010, 07:29 PM   #5357
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Originally Posted by defcone View Post
That 528_STOCK can be run on the 2.0
Yup, ran it on my 2.0 LPF in MOD TC (10.5 for me) last weekend without any problems.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 08-23-2010, 11:04 PM   #5358
I`m running the LPF Gran Turismo 2.0 in my crawler and was hopin someone could tell me the best software version to run for max. runtime. Not interested in any boost features whatsoever, just plain old fashioned runtime. I run a Novak 17.5 in it. Thanks.
asfastasu is offline   Reply With Quote
Old 08-23-2010, 11:16 PM   #5359
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Run the 205 and have the DDRS at 1(#4) and AMTS(#9) at 1. U should run for a gazillion hours!
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 08-23-2010, 11:51 PM   #5360
irgo's Avatar
Default Speed Passion Crawlers Settings.
Specially for Crawlers already great For SP GT2.0 pro or LPF
with 205G
and for SP GT2.1Pro requires to change it's firmware to 205G,
after that #4 DRRS is free (1 to 9) since it has very high ratio.
#9 AMTS you can try (1) for 0 timing.
Then Specially for Crawlers, you can try Vestigial Running mode
set settings #1(3) with these you don't need to brake on Crawlers
Forward and Reverse directly without delay,
This method, will help you to do the Dig, on a mud etc.
and Crawl up and down, as soon as possible to change your articulation
when facing a Rock.
Good Luck!
Quark Force
irgo is offline   Reply With Quote
Old 08-24-2010, 12:15 AM   #5361
Originally Posted by sosidge View Post
If yours is a V3 motor, leave the timing in the middle of the slot to start with, gear it, and race it.
DO NOT use a gear ratio from a no-timing software on the supercharger software. It will cook the motor very quickly. There is some discussion on recent pages about which documentation to use for gearing advice with the supercharger.
Ok thanks. So for NO timing software gearing on 13.5t should be around 4.8-6.0 as per the motor instructions ? that's just a starting guide right ?
and for the supercharger software I have two suggested gearings 6.75-7.5 md/lrg tracks, 6.25-7.0 very large tracks and on another set up guide I have 6.5-7.0.
Is that correct ?
S.A.W is offline   Reply With Quote
Old 08-24-2010, 12:46 AM   #5362
sosidge's Avatar
Is that correct ?
Those are the starting points, yes.
Old 08-24-2010, 12:50 AM   #5363
Cheers, which do you find the better supercharger instructions the 'SP GT2' ones or the 'Basic starting setups for supercharger software'
both give very different guides to gearing and setting the speedo
Old 08-24-2010, 01:01 AM   #5364
sosidge's Avatar
I can only reply with another
Documentation from SP is TERRIBLE.
Old 08-24-2010, 07:12 AM   #5365
san.'s Avatar
Trader Rating: 59 (100%+)
I would suggest to start with the basic recommendations (safer). If motor and esc temps allow, then use the "Suggested Settings" on the 2nd page of the MS Word doc.
Please note, the basic recommendations were written for the very first public beta release and is outdated.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 08-24-2010, 10:15 AM   #5366
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
Is that correct ?
with the supercharge software (528) you should be fine with a fdr for the 13.5 between 5.4 to 6.0 .with the fdr 6.5 to 7.0 you will be undergeared ( from what i have found out)
Old 08-24-2010, 10:30 AM   #5367
John.C's Avatar
Trader Rating: 36 (100%+)
Hi guys,
I recently picked up a GT2.1 ProStock ESC and the V3 17.5 motor. I'm planning on upgrading to the 528 software. Would I be able to use the program card that came with the ESC? Will all of the items and values stay the same?
Thanks.
John
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 08-24-2010, 10:40 AM   #5368
So is the 'Basic Starting Setups for Supercharger Software' document not worth using, is this the out of date one. Is it best to go by the document that comes with the GT2.1 (Ver: 4232010Stock) but gear it according to the SP motor instructions ?
Someone really needs to write an updated SP supercharger manual.
Old 08-24-2010, 10:42 AM   #5369
Originally Posted by double_green View Post
Hi guys,
Thanks.
John
You can only adjust the settings with the program card, you need the LCD program box to update the software.
Old 08-24-2010, 10:50 AM   #5370
irgo's Avatar
FDR based on Motor Manual only for non Stock Software.
(too Low)
Quark Force
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
