Like Tree12Likes
Old 08-18-2010, 10:52 AM   #5221
marcel p's Avatar
Send a message via MSN to marcel p
Originally Posted by Boz View Post
I'm just building a B4 and was wondering if you could get away with not using a fan on the ESC (GT 2.0 Pro)? I'll be running a V3.0 motor (8.5)
no problem to 6.5t
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 08-18-2010, 10:55 AM   #5222
marcel p's Avatar
dith one off you tryed to use the 528 stock software on the gt2.0 pro speedo.
the site says only for 2.1 prostock.?
PR racing
Absima /vr racing
Old 08-18-2010, 11:18 AM   #5223
Originally Posted by S.A.W View Post
Hi,
I was reading through the 'Basic Starting Setups for Supercharger Software' and it says,
I'm also using the SP motors, so does this mean I could set the motor timing to 0deg and then the timing on the esc to option 5 (15,00) or could I also leave the the motor at 5deg and the speedo to option 4 (11,25) giving approximately 15deg is this still the same thing ?
Sorry but trying to understand more about timing and all these esc settings
Tried using the settings and instructions today from 'Basic Starting Setups for Supercharger Software' with my SP 13.5t
found them very hard to understand and the car was soo slloooww no mater what I geared it too, so decided to follow the 'Word' guide can't remember the name but that suggests a gearing of 7.0 - 6.5 which I found worked very well.
What confused me on these instructions was for 10.5t it suggests 5.5 - 6.0fdr, I thought it would need to be geared higher eg 7.0 - 8.0 for the lower turn motors
S.A.W is offline   Reply With Quote
Old 08-18-2010, 12:04 PM   #5224
mr fit's Avatar
yes i used it and it works great. just make sure you update your LCD progamer before anything.
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 08-18-2010, 12:17 PM   #5225
marcel p's Avatar
oke
i have now v1.06-100617
PR racing
Absima /vr racing
Old 08-18-2010, 05:08 PM   #5226
How do I update my LCD Programmer?
Rob...........
*Restructuring* :)
Robio is offline   Reply With Quote
Old 08-18-2010, 05:14 PM   #5227
mr crum's Avatar
Send a message via Yahoo to mr crum
Rob...........
go to speedpassion site look for lcd programmer in products then u will see the download 1.33
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 08-18-2010, 08:13 PM   #5228
RCHR Racer's Avatar
no problem to 6.5t
Yes No Problem at all ! I run an 8.5 and the motor is barely 80 degrees and speedo close to same! And I use a 2.1 speedo, yours should run smoother for Mod.
Speed Passion USA Team / SpeedPower Lipos / Radio Control Hobbies and Raceway
RCHR Racer is offline   Reply With Quote
Old 08-19-2010, 03:54 AM   #5229
mr crum's Avatar
ive been running 528 since its release on a 2.0 no problems
TEAM B.R. RACING
Old 08-19-2010, 10:06 AM   #5230
marcel p's Avatar
thanks
one more thing
wat is the bigest diferents from stock 422 to 528 stock.
PR racing
Absima /vr racing
Old 08-19-2010, 12:03 PM   #5231
mr fit's Avatar
thanks
one more thing
a little bit more punch and cooler motor temps. other than that i havent noticed any difference.
Old 08-19-2010, 12:16 PM   #5232
marcel p's Avatar
thanks.
wil try it
PR racing
Absima /vr racing
Old 08-19-2010, 04:33 PM   #5233
mr crum's Avatar
thanks
one more thing
better mid range and as said before i cooler temps
TEAM B.R. RACING
Old 08-20-2010, 02:31 AM   #5234
Hi is it possible to run the Stock 2.1 without the cooling fan when running 13.5?
008-Racer is offline   Reply With Quote
Old 08-20-2010, 03:55 AM   #5235
RCHR Racer's Avatar
yes. i run an 8.5 with a 2.1 , and no cooling fan. But it does depend on your settings, where I run offroad and not alot of timing as onroad. Just keep an eye on your temps as usual with any combination.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
