Old 08-17-2010, 08:31 AM   #5206
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by Joel Lagace View Post
our club is talking about running a boost free 17.5 class( )
What is the best way for a SP or HW user running boost now to unboost there ESC? Can the boost settings be set to 1 or 0 or off? Or would a flash to a "MOD" software be more effective... IF both work which will leave the user with the best performance?
with the new software there is a non boost software you can add to your current speedo or you can run the cirtix esc from speedpassion
Old 08-17-2010, 08:37 AM   #5207
Joel Lagace's Avatar
thanks ill check it out.. seems backwards to be turning it off! LOL
But a flash back is cheaper then a new ESC
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 08-17-2010, 10:10 AM   #5208
Send a message via MSN to geubes
Originally Posted by Marcos.J View Post
what are your settings?
4: 8
9: 7
12: 9 (max)
13: 1
14: 5
15: 4
geubes is offline   Reply With Quote
Old 08-17-2010, 10:17 AM   #5209
Super Moderator
Marcos.J's Avatar
Originally Posted by geubes View Post
4: 8
9: 7
12: 9 (max)
13: 1
14: 5
15: 4
whats the timing on the motor?
Old 08-17-2010, 10:22 AM   #5210
5 degrees from zero mark (half a small notch)
Old 08-17-2010, 10:37 AM   #5211
Try 10 degrees on the motor.
Mike
ixlr8nz is offline   Reply With Quote
Old 08-17-2010, 10:51 AM   #5212
Super Moderator
Marcos.J's Avatar
Go down 1 tooth from the 5.5 FDR then drop #15 to #2 try that. I have a setup posted a page back or so for a 17.5(Speedpassion ) but try it out
Mike
adding more timing on the motor will just add more heat to the motor and the motor will fade at the end of the run. It will sound faster but slower lap times.
Old 08-17-2010, 12:12 PM   #5213
The Capacitor is included in The box is that best or is it best to change that? I have never seen the factory team use it?????
Zooberg is offline   Reply With Quote
Old 08-17-2010, 12:19 PM   #5214
Super Moderator
Marcos.J's Avatar
I have been using the stock capacitor with no issues , it may just be a preference what cap they use.
Old 08-17-2010, 12:34 PM   #5215
Send a message via AIM to Astro1418
what should i have the voltage cutoff for a 3300mah lipo for a speed passion v1.1 ?
Astro1418 is offline   Reply With Quote
Old 08-17-2010, 01:02 PM   #5216
Hi,
I was reading through the 'Basic Starting Setups for Supercharger Software' and it says,
AMTS is also in effect (combined with physical motor advance) when the Supercharger is not active (low rpm/high load). Generally 13.5 “likes” a total of about 15deg in this state
I'm also using the SP motors, so does this mean I could set the motor timing to 0deg and then the timing on the esc to option 5 (15,00) or could I also leave the the motor at 5deg and the speedo to option 4 (11,25) giving approximately 15deg is this still the same thing ?
Sorry but trying to understand more about timing and all these esc settings
S.A.W is offline   Reply With Quote
Old 08-17-2010, 03:44 PM   #5217
Certainly not true at my local track. 10 degrees is noticeably faster in 13.5, I bet in 17.5 it would make an even bigger difference to mid range/ top speed.
Mike
Old 08-17-2010, 04:07 PM   #5218
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Mike
I agree Mike as that is what we determined as well, but it all depends on your ESC settings. Those that like to run 5.XX FDR's do not utilize the timing as it generates heat, while those that gear for RPM use all the timing they can. Your track / driving style will dictate what works best.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 08-17-2010, 07:06 PM   #5219
M-Technic's Avatar
Trader Rating: 15 (100%+)
Mike
It really depends on a lot of things. There is such a thing as "too much timing," so you usually have to balance it out one way or another.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-18-2010, 07:04 AM   #5220
Boz
Trader Rating: 23 (100%+)
Default Using a fan on the ESC
I'm just building a B4 and was wondering if you could get away with not using a fan on the ESC (GT 2.0 Pro)? I'll be running a V3.0 motor (8.5)
Chris Bozich
Xray XB4 and XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
