The Speed Passion Thread
#5191
Anyone have a good starting gearing for the 528 stock software wil 17.5 for a kyosho 2wd buggy.
#5192
After our main this weekend I decided to test out a completely off the wall gear ratio (for me at least). I went up 8 (!) teeth, from about a 6.5 to a 5.2. Car was every bit as fast, with less fade, and was actually about 10* cooler!
Talk about a huge gearing window with this ESC.
#5193
Super Moderator
#5197
Power decrease as temperature decreases?
Hi all,
I'm running a 3.5T v3 in my TC car, and it seems a bit slower (less rip) than it used to be. Recently I also installed a fan that pulls air out of the motor, instead of blowing onto it, the setup is made by Team Powers (aluminum version).
The motor usually comes off the track at about 155F, I think it used to come off closer to 170 or 175F.
Sorry, if this has been asked and answered, but I couldn't find anything in my initial search.
Thanks.
Ethan
Thanks.
Ethan
#5198
Hi all,
I'm running a 3.5T v3 in my TC car, and it seems a bit slower (less rip) than it used to be. Recently I also installed a fan that pulls air out of the motor, instead of blowing onto it, then setup is made by Team Powers.
Thanks.
Ethan
Thanks.
Ethan
Could you post a picture maybe of how you mounted it if you have not struggled the way we did with ours, because the idea is fantastic and we would love to see one working.
Cheers
#5199
We are running duo2 17.5 at 6.1 on a small technical track with about a 20m straight and they are uncatchable and about 165f. Tried gearing up to 5.5, no change in temperature, but slower lap time and not as much rip
#5200
Any body tried using the new boost softwares (528) with the x12 range of motors?
In particular the 13.5 x12?
#5201
Hi there we played with the TP fan shroud and had terrible problems with heat, with no actual way of securely mounting it we had one actually melt into a motor in use, obviously the motor was a write off after this so not too certain if they are actually up to the job or not. They are made from Lexan and would work well if moulded from Alloy to act as a combination Heatsink and fan holder.
Cheers
Cheers
Steve
#5202
Any input from anyone on the heat versus performance issue? If the motor runs cooler, can that imply a loss in power?
#5203
Can i use speedpassion prostock 2.1 in mod whit mod softw.?
What is a good start setup in 17.5 stock.whit New superstock soft w.?
#5205
our club is talking about running a boost free 17.5 class( )
What is the best way for a SP or HW user running boost now to unboost there ESC? Can the boost settings be set to 1 or 0 or off? Or would a flash to a "MOD" software be more effective... IF both work which will leave the user with the best performance?
