Like Tree12Likes
Old 08-10-2010, 07:12 PM   #5146
Originally Posted by g12314 View Post
The Speed Passion Thread
I have an EXCEL calculator file built to allow me to input my ESC settings and show the RPM window. I'll post it later tonight when I get home from work.
Jimmy
Jimmy,
do you have a good starting set up point for 17.5 on road?
thanks in advance,
Richard
gdcopbdcop is offline   Reply With Quote
Old 08-10-2010, 08:20 PM   #5147
irgo's Avatar
Here is the EXCEL file I use to calculate the Start & End RPM points for the 528 software release.
http://www.rctech.net/forum/attachme...c_528_v1.0.zip
Jimmy
That's a good work,..
in September you will not have to guess RPM under load,
because SP engineer will release the new PC Interface RPM Log history,
and if this combined with the Custom RPM Start,
would be very precisions.
resulting max torque. and faster acceleration.
Quark Force
irgo is offline   Reply With Quote
Old 08-11-2010, 10:36 AM   #5148
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by mr crum View Post
u hace to run receiver pack i havent tried a booster but last friday nite my wgt was a rocket pullin tekins down the straight will fill out pdf now and post it
Thanks Harrold...will have that post on SP site as well. Please email me a copy and detail information about setting up in 1S.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 08-11-2010, 12:17 PM   #5149
Originally Posted by Marcos.J View Post
try these settings
it says 100422 software but its a typo the settings are for the 100528
Tried these settings today with the SP 13.5 at 5.81fdr and it work really well so thought I'd try a SP 10.5 at 5.65fdr and it went really well just wondered what I need to adjust on the speedo to get a little more punch with the 13.5 ? I'm running the standard 5deg timing on both motors.
Also what sort of fdr is a good starting point for the 10.5 ?
Should I be gearing the SP motor/speedo's higher eg. 6.0-7.0 ?
Thanks.
S.A.W is offline   Reply With Quote
Old 08-11-2010, 12:34 PM   #5150
Super Moderator
Marcos.J's Avatar
Trader Rating: 174 (100%+)
Thanks.
you could go down on the delay and also on #15 but it may add more heat. You can always play with the gearing.
for the 10.5 i would start around a 6.2- 6.5.
6.0 to 7.0 for a 13.5?? i havent yet, dont need to
Old 08-11-2010, 01:14 PM   #5151
Thanyou.
Did try a larger then a smaller pinion but didn't really make much difference apart from more heat.
which one, #13 or #14
Think I went the wrong way at 5.81 to 5.65 with 10.5 I'll try dropping pinion and do some laps and get temp reading.
Old 08-12-2010, 02:17 AM   #5152
irgo's Avatar
Jimmy
Jimmy your Calc for 528 is need correction.
1) at "DMTS Start RPM" it's not 528 but it's 422.
528 is :
4000,5000,6000,7000,8000,9000,10000,110000,12000
2) "DMTS START RPM" supposed to change as DMTS Timing Change.
and DMTS START RPM is defined before SC Timing is Activated,
and timing and end rpm change again.
3) "DMTS Timing" has no relation to Supercharge Timing Punch. (miss calculate)
4) "SC Timing" has no relation to SC Timing Punch. (miss calculate)
5) "SC Timing Punch" has no relation to SC Timing Punch either DMTS Timing. (miss calculate)
i'm sorry but your calculator is all wrong.
Quark Force
Old 08-12-2010, 02:20 AM   #5153
defcone's Avatar
Trader Rating: 15 (100%+)
Will we need to use a laptop to tune that?
defcone is offline   Reply With Quote
Old 08-12-2010, 02:31 AM   #5154
irgo's Avatar
right for the PC Interface, because you may think not change
the 8130 rpm manually with programmer button right,
simply type it.
laptop will do.
Quark Force
Old 08-12-2010, 03:00 AM   #5155
defcone's Avatar
simply type it.
laptop will do.
Just have it so you set every digit seperatley, Thousands, hundreds, tens..etc
Old 08-12-2010, 04:22 AM   #5156
altreyx's Avatar
Irgo can you write from where are arriving these info? inside the last SP firmwares we have this document (se the attached file) but i'm sure you know this but what you are saying to us is complete different, so just for to understand better is possible have more info?
The calculator is right for what I/we know
Thank you
528 is :
File Type: doc InstructionsofSTOCKSoftwareGT2_April23th2010.doc (82.5 KB, 203 views)
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 08-12-2010, 07:38 AM   #5157
M-Technic's Avatar
I got my setup dialed in a bit last night. Adding a half tick of timing to my Duo2 17.5 and dropping a tooth really helped. I'm geared at a 6.30 and I might try dropping one more tooth. Temps were about 170 after 7 minutes which might be a little bit too hot considering it was cool night and our races start in the afternoon.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-12-2010, 08:04 AM   #5158
Trader Rating: 8 (90%+)
Originally Posted by Tha Skinny View Post
Hey guys, can I just get a switch from so USA. Mine came off ofctje chassis this weekend and I lost the top part to it. Is this something I need to send I'm my speedo for?
Bueller???? Bueller????? Anyone???
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris Totcky@facebook.com
Tha Skinny is offline   Reply With Quote
Old 08-12-2010, 08:12 AM   #5159
Solara's Avatar
Email Speed Passion USA: attn Albert, usasupport@king-golden.com or give him a call 1-888-928-1328
Old 08-12-2010, 08:38 AM   #5160
Originally Posted by Solara View Post
Email Speed Passion USA: attn Albert, usasupport@king-golden.com or give him a call 1-866-369-0636
Number is no longer in service.
Houston,Texas
Serpent 733 EVO
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
