Old 08-07-2010, 10:42 AM   #5101
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by MikeXray View Post
What to do on the 2.0 with non translucent case, I put on the stock software looked for a blinking LED and realized I couldn't see any of them, lol.
Give SP USA a call...they will get that clear undercover send over to you.... Please specific which GT2, color and is that LPF or Pro...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 08-07-2010, 07:47 PM   #5102
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Kevin K View Post
Hows everything working out?
not good, can't get it fast, I did mount a team powers fan on it, it mounts on the motor and sucks the heat out, works amazing well, I ran your setup and the motor was only 122 after 4 minutes (limited practice time) but was getting pulled like crazy everywhere, infield and straight, didn't have a chance to mess with gearing. Its turned into a testing a weekend, instead of a race weekend. At the reedy I was top 10 easy, even with running only one set of tires all weekend, at Nats, these same guys are ballistic, my driving is off from the Reedy but still, its crazy fast here.
even thou I loved this boost stuff when it first came out, I'm starting to think its quickly becoming more work then its worth. especially for us weekend warriors without a full time track.
I have some re thinking and soul searching to do on which products I use. All of them.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 08-07-2010, 10:36 PM   #5103
corallyman's Avatar
Trader Rating: 97 (100%+)
I am also at the Nat's with Ritchie and all the NW racers. It is crazy fast and I have blown up 3 motors this week. One of them was brand new too but that was my fault. Oh well I am still having fun but it's sad to see what a bad series of breaks Ritchie's had to deal with.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 08-08-2010, 12:52 AM   #5104
Guys I am having a problem....Blowing up 2 sp17.5 motors!!! I am using 528 software,having trouble keeping up (not top end but more so out of corners) with the bloody tekins.Both times the motors smoked they felt like I had lots of drag brake programed in...but there was none!!!then within one to two laps they blew.the program I had in when the second motor blew was not far off the tekins but came in hotter than the previous program(that was not fast enough... .5sec per lap)...motor came off at 90 degrees...previously 68/70 degrees
settings
1/1
2/1
3/4
4/8
5/4
6/4
7/2
8/1
9/8
10/1
12/9
13/1
14/2
15/1
FDR5.73
I would call it a med to large track
What am I doing wrong?
Motor timing at max
Barger is offline   Reply With Quote
Old 08-08-2010, 01:11 AM   #5105
settings
1/1
2/1
3/4
4/8
5/4
6/4
7/2
8/1
9/8
10/1
12/9
13/1
14/2
15/1
FDR5.73
Motor timing at max
Try 14 at 5. That is what hobbywing recommends for 17.5 motors. Does any of the competition have gear diffs? That can make some difference in acceleration especially if your diff is slipping a little
Mike
ixlr8nz is offline   Reply With Quote
Old 08-08-2010, 04:43 AM   #5106
Hello,
can you Help me for ESC Setup for German Masters?
I Drive a GT2.0 with a 17.5 Corally Engine. The Software is 422(give it a newer Software?).
The Corally Engine had 30 internal Timing and the Max FDR in this Race is 5,0.
My Car is a TRF416X with Spec-R Gear Diff. I Have a second Spec-R Diff what i will Test in front and rear.
It is the Home Track from Marc Rheinard, in this Year the Track of the German Masters.
The Speed Passion Thread-cr398136_gr.jpg   The Speed Passion Thread-img_2159.jpg
kiloolli is offline   Reply With Quote
Old 08-08-2010, 09:36 AM   #5107
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
settings
1/1
2/1
3/4
4/8
5/4
6/4
7/2
8/1
9/8
10/1
12/9
13/1
14/2
15/1
FDR5.73
Motor timing at max
I see two things in the settings you posted:
Your RPM window for timing is much to narrow (#15 setting): Start 3000 & End 8800 This will cause the motor to feel sluggish (too much timing applied to fast) and generate excessive heat.
The SC delay (#14 setting) of 0.1sec combined with your above timing settings is causing an excessive amount of timing being applied to the motor.
Your FDR of 5.73 would signal to me that you on a Big track. Have a look a few posts back for the setup I posted for 200ft track to get an idea of settings.
I would at least change your current #13 setting to 2 and #15 to 3. If it seems slow, don't be afraid to drop several teeth on the pinion. A zero delay SC setup typically needs a lot of RPM to go fast, and we typically will run it on short / med technical tracks as you get a lot of rip out of the corner with it.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 08-08-2010, 12:18 PM   #5108
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
hey guys i have the 528 mod software in my 2.0 pro right now and ive done the search but i cant seem to find the differences between the mod and the 528 stock software i mainly run mod right now but sometimes run stock and was wondering if they are close enough so i dont have to switch the firmware everytime i choose to run stock instead of modified .
Serpent project 4x
jeff jenkins is offline   Reply With Quote
Old 08-08-2010, 12:28 PM   #5109
robk's Avatar
Trader Rating: 22 (100%+)
That is why you are getting pulled. Your motor is in a completely different powerband and will not run geared in the 5's. It will look like you're getting dominated all over until you run the proper gear ratio (7 + FDR)
Old 08-08-2010, 03:05 PM   #5110
Thanks guys...will try your settings and get back to you
Old 08-08-2010, 03:09 PM   #5111
Hi,
I'm running a T3 with SP motor and 528 software. I raced a few weeks back in 17.5t and used,
9-8
12-9
13-1
14-1 (0.1)
15-1
geared at 4.96 and the car was really quick and temps were ok so thought I'd try a 13.5t class.
If I use the suggested settings of,
9-8
12-7
13-3
14-5
15-1
the car is slow so I need to use the settings from the 17.5t and have to gear it 5.93 to be competative.
so thought i'd just try a 10.5t with,
9-5
12-7
13-4
14-4
15-4
and it's sllloooowww ?
I always seem to have to use the 17.5t settings and gear it by temp but no mater what I geared it too it was barely any quicker than the 13.5t. I tried 6.5 all the way to 5.0 ad it never really made much difference until I advanced the motor timing but this only added 1 or 2 mph top end ???
What's some good settings for 13.5 and 10.5 speed passion motors do I need the motor timing up, down or leave it in the middle ?
I'm confused with it, any tips please the track is outdoors with a 45m straight, mostly fast flowing with only a few technical places.
Thanks.
S.A.W is offline   Reply With Quote
Old 08-08-2010, 04:37 PM   #5112
Trader Rating: 8 (90%+)
Hey guys, can I just get a switch from so USA. Mine came off ofctje chassis this weekend and I lost the top part to it. Is this something I need to send I'm my speedo for?
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris Totcky@facebook.com
Tha Skinny is offline   Reply With Quote
Old 08-08-2010, 05:18 PM   #5113
marcel p's Avatar
Send a message via MSN to marcel p
[QUOTE=S.A.W;7777418]Hi,
9-8
12-9
13-1
14-1 (0.1)
15-1
9-8
12-7
13-3
14-5
15-1
9-5
12-7
13-4
14-4
15-4
Thanks.[/QUOTE
i use with 13.5 sp 3.0 motor on max timing
1-1
2-1
3-1
4-8
5-4
6-4
7-2
8-1
9-8
10-2
11-2
12-9
13-6
14-3
15-2
fdr 7.3 on a medium size track.
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 08-08-2010, 05:32 PM   #5114
skypilot's Avatar
NO, NO, NO, NO....
I ran it at the recommend gearing I was given, I DIDN'T HAVE A CHANCE TO MESS IT TO SEE IF I COULD GET IT BETTER.
Old 08-08-2010, 08:12 PM   #5115
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
NO, NO, NO, NO....
I have no idea what to say..... That setup is just as fast and faster then everything else. Everything you are saying is exactly what we were noticing with the previous ver of the software.....maybe double check your ESC and make sure its on 528. If it wasnt working then something more must have been going on....idk. Sucks that you had a bad weekend....god knows I have been there.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
