Old 07-30-2010, 11:57 AM   #5026
Default new download - probs
hello team speedpassion,
the new download, e.g ESC GT 2.0 - Manual - doesn´t work.
can you clear the problems please....
lg
Harald
XRAY_Blade is offline   Reply With Quote
Old 07-30-2010, 02:25 PM   #5027
hi ,
could anyone be so kind as to explain how i can remove the 528 software so i can go back to 110 software ?
If this is not possible could someone explain what i should turn off on the 528 software to turn off the turbo effect completly
thats 528 stock btw
thankyou
madwestmo is offline   Reply With Quote
Old 07-30-2010, 02:30 PM   #5028
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by madwestmo View Post
hi ,
thats 528 stock btw
thankyou
you will need the LCD Programming box and your computer , but why would you want to install the 110?? you can just basically turn of the supercharge and still run the 528
Old 07-30-2010, 08:27 PM   #5029
cherry2blost's Avatar
Hiya Marcos, we found this as well, on smaller indoor tracks with additional 'mechanical' timing the 110 software runs more consistently and more importantly cooler than the 528 with SC turned off. Wonder if the SP guys have found this at all? (Trinity 10.5's BTW )
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 07-30-2010, 10:03 PM   #5030
Super Moderator
Marcos.J's Avatar
mine is working just fine , my motor even in the 100 degree florida heat hasnt seen anything over 130 degrees. Tomorrow I will be running in a inddor track so I may be able to tell you then what my temps are in a smaller indoor track
Old 07-31-2010, 02:15 AM   #5031
Cooool (pardon the pun) will be good to see your results but 110 is an awesome software version regardless lol.
Old 07-31-2010, 03:15 AM   #5032
this has not helped one bit...
Old 07-31-2010, 08:11 AM   #5033
irgo's Avatar
Default Speed Passion Rollback 528 (V2.0_100528) to 110 (V1.1_100110STOCK)
hi ,
thats 528 stock btw
thankyou
You will need to install Speed Passion PC Interface version 1.32
first without uninstalling the PC Interface version 1.33.
run PC Interface 1.33 and change your ESC Firmware 528 to 205
close your PC Interface 1.33
* copy file version_control only from 1.33 to 1.32 *
run PC Interface 1.32 and change your ESC Firmware 205 to 110.
Done!
next :
close PC Interface 1.32
Done!
now you can change 110 settings with PC Interface 1.33.
Quark Force
irgo is offline   Reply With Quote
Old 07-31-2010, 08:16 AM   #5034
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Some of us up here have been running 528 with 17.5 motors on carpet alot lately and its not over heating the motor. If you are overheating a 10.5 I would look into your settings or your FDR. Can you list what settings you are using thats making the motor too hot and lacking consistency?
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-31-2010, 11:55 AM   #5035
tns
Hi all
I'm running a SP v3 11.5T motor (5 degree timing) and a GT2.0 LPF ESC (528 firmware), and I'm also using 6.6v LiFe batteries
Would anyone have a suggestion as to what might be a good settings (ESC as well as FDR) for such a combination of hardware? The last time I ran the car, I had a FDR of 6.5, maxed out SC boost and AMTS, and SC punch at -1 or -2. The motor temped at over 90C after a couple minutes of hard running (too hot!).
In particular, should I gear close to a FDR of 7, or, given my choice of lower voltage batteries, should I instead be gearing nearly to a FDR of 6? I need to get my motor temps down without sacrificing too much speed/punch.
I find plenty of suggested settings for 13.5T and 17.5T motors, but info on proper settings for 11.5T seems rather scarce... Any views will be much appreciated.
Thanks!
tns is offline   Reply With Quote
Old 07-31-2010, 12:27 PM   #5036
Done!
next :
Done!
i have just tried to do this and it goes to 205 ok but then when i go onto 1.32 and go to change to 110 it says im unable to upgrade ? any suggestions on how to solve this ?
Old 07-31-2010, 04:40 PM   #5037
irgo's Avatar
whoops sorry check again post above corrected.
Quark Force
Old 07-31-2010, 05:44 PM   #5038
Super Moderator
Marcos.J's Avatar
The 528 ran great today plenty of rip and top end, ended with a 5.12 with a SP 17.5 motor temps were in the 140 range.
Old 07-31-2010, 07:30 PM   #5039
Super Moderator
Marcos.J's Avatar
Here is my Esc set up sheet.
Old 07-31-2010, 07:52 PM   #5040
Trader Rating: 20 (100%+)
Default 13.5 v3 tarmac MarcosJ
Thanks for the carpet 17.5 v3 just what I was looking for. Can you post a tarmac 13.5 v3 sheet too.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
