Like Tree46Likes
Old 07-19-2010, 10:56 PM   #4951
Tozze's Avatar
Originally Posted by Taman View Post
171 grams - no wires attached
Thank you very much Taman!
http://www.jtrcracing.net/
1:18 Xray M18 | M18 Pro
1:10 Kyosho Spider TF-2 Ford F150 | Robitronic Avid V2 | Team Magic E4JS
1:8 Nanda NRT-3 BL | Robitronic Protos
1:5 FG Porsche GT3 RSR | MCD RR Evo3 m.m.
Tozze is offline   Reply With Quote
Old 07-20-2010, 01:33 AM   #4952
Default Please help me!
Hi,
Like i wrote two Sites ago(anfortunately everybody ignored my post :-( )
Which Kind of RPM Delay has the #100258 stock Software?
Is it a) 4000 / 5000 / 6000 / ....
Or b) 3000 / 4500 / 6000 / ....
Please help me!
Thanks!
Shqizy is offline   Reply With Quote
Old 07-20-2010, 02:57 AM   #4953
Talking 528 updatecorrect ?
hello shqizy,
hello @ all,
Im new here in this forum, but I have the some problem like shqizy has.
I update to the 528 on my GT2.0 PRO but cant see the rpm delay 3000/4500. etc..
So Im not sure that I currently use the right software.
so please help us, in this topic,so that we can be sure that we dont have done something wrong.
very best regards
Harald
and
greetings from sunny VIENNA
XRAY_Blade is offline   Reply With Quote
Old 07-20-2010, 03:48 AM   #4954
RCHR Racer's Avatar
Originally Posted by Shqizy View Post
Hi,
Please help me!
Thanks!
A
Speed Passion USA Team / SpeedPower Lipos / Radio Control Hobbies and Raceway
RCHR Racer is offline   Reply With Quote
Old 07-20-2010, 09:20 AM   #4955
M-Technic's Avatar
Trader Rating: 15 (100%+)
I've got a question regarding the 528 Stock software.
Why is it that the supercharger has both an RPM delay, AND a time delay? Shouldn't it be one or the other? If you hit the RPM before the time delay or vice versa, does it wait til both are met to add the supercharger timing?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-20-2010, 09:24 AM   #4956
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
your trying some thing different
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-20-2010, 09:45 AM   #4957
M-Technic's Avatar
I've been running the SP stuff on and off for a while. Never really been able to get it right. This thread doesn't seem as technically inclined as the Tekin thread. Not many setups or theories shared. Now that the season is over I am going to spend some more time with 528. I can never seem to get the motor to wind out like it does with my Tekin. It always sounds like it is struggling to build RPM. I never find the settings on the speedo to make as much of a difference as gearing does, which is opposite of how the Tekin reacts.
Old 07-20-2010, 10:10 AM   #4958
Trader Rating: 8 (90%+)
So is atsushi running for speed passion now? I noticed one in his car at ets.
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris [email protected]
Tha Skinny is offline   Reply With Quote
Old 07-20-2010, 10:29 AM   #4959
MikeXray's Avatar
Trader Rating: 73 (100%+)
I have noticed the same thing, I don't think its supposed to act like the tekin does, that's why they call it supercharge and not turbo. (anyone not into 1:1 cars, superchargers build a ton of low end torque but actually create parasitic drag in higher rpms, where as turbos need time to spool and run faster the higher rpms you can turn). Higher gearing helps a lot, I had my 13.5 geared at 5.9, bumping it up to 5.3 helped a lot and it didn't run any hotter.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-20-2010, 10:40 AM   #4960
M-Technic's Avatar
I assumed they called it supercharger just to be the counterpoint to Tekin's turbo. I never thought it could have a deeper meaning. I agree with what you said though, more gear helps.
I still don't understand why the supercharger has both and RPM as well as a time-based delay.
Old 07-20-2010, 10:54 AM   #4961
I believe start RPM is the point the ESC starts adding any timing at all. The delay only effects the 8* of supercharger timing.
g26er is offline   Reply With Quote
Old 07-20-2010, 10:54 AM   #4962
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Being an electrical engineer and a former Tekin user myself, I can understand some of the frustrations when trying to dial in the Speed Passion ESC software. Myself along with the help of others here in the Chicago area have spent a fair amount of time "reverse engineering" the Speed Passion settings to correlate them to the Tekin settings we are familiar with. I'll try to summarize these below:
#9 DMTS Timing: This setting defines the Software defined motor timing (boost on Tekin).
#12 Supercharger Timing: This setting defines the additional amount of timing to be added once you are full throttle and after the #14 Supercharger Delay time (Turbo timing / Turbo Delay on Tekin)
#13 DMTS Timing Start: This is the RPM at which the #9 setting begins (Tekin Start RPM)
#14 Supercharger Delay: This the the amount of time delay after you are full throttle before the Supercharger Timing is added. (Tekin Turbo Delay)
#15 Supercharger Timing Punch: From the testing we have done, this appears to control the rate at which the DMTS timing & Supercharger timing are applied. This is similar to the Tekin Turbo Ramp Rate, but it seems to apply to the overall timing curve since it has an effect on the end RPM of the overall timing.
The end rpm can be calculated via: END RPM = DMTS Timing Start + (DMTS Timing + Supercharger Timing) * Supercharger Timing Punch
With the above info, I was able to correlate Speed Passion settings to my Tekin settings. The Speed Passion remains in my car as I find it easier to drive due to its smooth response. I know that if a driver beats me, it is because they drove a better race, not because their ESC was any faster .
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 07-20-2010, 11:27 AM   #4963
M-Technic's Avatar
Jimmy, thank you for the excellent information. That will be very helpful. I will report back on Thursday after I run again tomorrow night.
Speed Passion team driver Tim Potter and I have managed to get our settings down such that the SP speedo is considerably faster than a Tekin on the infield of our track, but it is always at the cost of top end speed. At the end of our straight away the Tekin's always pull away. We had been testing with SP v3 motors.
Tomorrow I am going to run with my Duo2 motors, as I am a driver for Trinity and I am most familiar with their motors. The SP motors are nice but they seem to like different gearing and setups than the Trinity motors that I am used to.
Old 07-20-2010, 01:07 PM   #4964
skypilot's Avatar
Trader Rating: 14 (100%+)
not sure where, but a few pages back there is a download for a setup sheet that gives all the rpms and stuff for each setting.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 07-21-2010, 04:21 AM   #4965
SSS Racing's Avatar
Originally Posted by RCHR Racer View Post
I run an RB5 which has the exact tranny ratio. Running a 78 / 23 for spur -pinion. We have a very small tight cornering track so not much top end needed , but enough for passing. I'm by far the fastest and smoothest for our small straightaways. I can PM u the settings currently used with 528 if youde like. I use the GT 2.1 speedo with 528 Mod program and 4 barrel power cap.
Thanks Brandon
I started with a 24 pinion with the standard spur 81, and went up to 26. It got a bit quicker with the 26, but still not what i was expecting from a 8.5 motor.
I ran out of time to try a bigger pinion, and was hesitant to keep going up in pinion size. Seem to be getting into 17.5 gearing range..
I'm running the SP v.1 LPF speedy, so no software update for me.
SSS Racing is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
