Old 07-19-2010, 07:29 AM   #4936
Afazli79's Avatar
Send a message via MSN to Afazli79
Can somebody send me a link to download software for program card and 528 as well. Thx.
Afazli79 is offline   Reply With Quote
Old 07-19-2010, 08:02 AM   #4937
http://www.speedpassion.net/en/produ...EXT98802PROscb
then click on the "downloads" tab
Fastfreddy74 is offline   Reply With Quote
Old 07-19-2010, 08:07 AM   #4938
SSS Racing's Avatar
Default v3 8.5 in 2wd
Any suggestions on gearing a v3 8.5 in a B4
SSS Racing is offline   Reply With Quote
Old 07-19-2010, 08:44 AM   #4939
Afazli79's Avatar
Originally Posted by Fastfreddy74 View Post
Thanks..
Old 07-19-2010, 09:05 AM   #4940
RCHR Racer's Avatar
I run an RB5 which has the exact tranny ratio. Running a 78 / 23 for spur -pinion. We have a very small tight cornering track so not much top end needed , but enough for passing. I'm by far the fastest and smoothest for our small straightaways. I can PM u the settings currently used with 528 if youde like. I use the GT 2.1 speedo with 528 Mod program and 4 barrel power cap.
Speed Passion USA Team / SpeedPower Lipos / Radio Control Hobbies and Raceway
RCHR Racer is offline   Reply With Quote
Old 07-19-2010, 01:15 PM   #4941
StickyFingaz's Avatar
Trader Rating: 12 (88%+)
Hit a wall (not that hard, I swear!) running a practice session at my local track... Now my beloved GT 2.0 doesn't turn on. Fan turns on, but no lights at the bottom of the ESC like in the past. Anyone have any idea what it could be?
Also, I've been trying to get a hold of the new guy in Illinois, but haven't had any luck via the phone. Need to get this this serviced ASAP.
Anyone know what's up?
Team Tamiya/TRF - Team KO PROPO - NorCal Hobbies
StickyFingaz is offline   Reply With Quote
Old 07-19-2010, 01:25 PM   #4942
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
You will need to get an RMA. Here is the link on directions to get this fixed.
RMA VIDEO
It's pretty straight forward and easy to do. THanx.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 07-19-2010, 02:23 PM   #4943
Tozze's Avatar
Does anyone know the weight on Speed Passion Competition 3.0 17.5R engine?
http://www.jtrcracing.net/
1:18 Xray M18 | M18 Pro
1:10 Kyosho Spider TF-2 Ford F150 | Robitronic Avid V2 | Team Magic E4JS
1:8 Nanda NRT-3 BL | Robitronic Protos
1:5 FG Porsche GT3 RSR | MCD RR Evo3 m.m.
Tozze is offline   Reply With Quote
Old 07-19-2010, 04:42 PM   #4944
RMA VIDEO
Ummm. I'm just a dude, not a hobby shop or a distributor of anything. King Golden has never, and probably never will, provide me with a login.
Dear Speed Passion USA... please pick up your phone!!!!!
Old 07-19-2010, 04:44 PM   #4945
Super Moderator
charlie_b's Avatar
This should be standard with dealers/customers for warranty/repair proceedures. I will clarify this.
Old 07-19-2010, 05:17 PM   #4946
Taman's Avatar
Trader Rating: 64 (100%+)
171 grams - no wires attached
Taman is offline   Reply With Quote
Old 07-19-2010, 07:10 PM   #4947
Hi there,
Sorry for your issue trying to get through to the SP USA office. Albert, the new rep. for US is still in the transition period with setting up the office. If you would like,send me your contact info and I will get a hold of him and get the ball rolling for you. Thank you for your understanding.
Brian
Mugen Seiki,REDS Racing Italy,Contact Tires,AVID,TeamGravityRc.com,92zero Designs,Diggity Designs,StrictlyRC.Net
B.JUCHA is offline   Reply With Quote
Old 07-19-2010, 07:25 PM   #4948
irgo's Avatar
Great day Sticky Fingaz
first you need to connect your SPGT2.0 with programming box
and tell me if it's woking,
if it is, then you should be alright,
after that, try to connect with LCD Pro,
if it's ok,
connect both with PC.
and then re flash your Firmware
and DONE!.
Quark Force
irgo is offline   Reply With Quote
Old 07-19-2010, 11:55 PM   #4949
Connected my ESC to the stock programming box and no lights came on... How do I login to the KG site so I can start an RMA?
Old 07-19-2010, 11:56 PM   #4950
Originally Posted by B.JUCHA View Post
Hi there,
Brian
PM Sent... thanks.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
