Old 06-26-2010, 10:03 PM   #4756
skypilot's Avatar
Trader Rating: 14 (100%+)
your esc needs to be re calibrated to the radio, for reason it loses it set, just reset every time you turn the esc on, you'll get used to it and it won't seem like pain
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 06-27-2010, 03:08 AM   #4757
razzor's Avatar
Originally Posted by Team Turtle View Post
I know this has probably been asked before but I couldn't find anything on it. I installed 422 on a LPF and it will work fine sometimes and sometimes it will only run about 1/3 throttle no SC or timing at all. I have flashed the ESC several times and it will still do it. Turn off the power and turn it back on and it's fine. It mat only do it once a day and sometimes not at all. My other LPF has been fine no issues what so ever.
recalibrate radio and and set full throttle at 95% on your end point. once done increase end point to 100%.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-27-2010, 08:00 AM   #4758
@ Speedpassion pro's:
which Capacitor are SP pro's like Marc Rheinard using on their SP GT2.0??
I guess it's a JAMICON 2200uF 25V Ultra low resistance Capacitor - right??
Shqizy is offline   Reply With Quote
Old 06-27-2010, 04:28 PM   #4759
Hi everyone, I just have a question about 528 mod ....... can it be used in 4 wheel drive off road? OR is it just for on road?
Mi4LP / Speed Passion GT Pro V 2.1 Pro Stock / GM 10.5 Pro Stock
Cat SX / Speed Passion GT Pro V 2.0 / Speed Passion 6.5 V2
Mugen MBX6T / Ninja BO1A
baldman666 is offline   Reply With Quote
Old 06-27-2010, 04:45 PM   #4760
Has anyone used the new software for stock offroad 2w buggy?
What were your findings? Settings?
Thanks, Rob..........
*Restructuring* :)
Robio is offline   Reply With Quote
Old 06-27-2010, 06:15 PM   #4761
mr240's Avatar
Trader Rating: 59 (100%+)
Just installed the Stock Spec 17.5 ESC and motor. How can I configure my settings, such as lipo cutoff, drag brake, etc. Is the only way through the program card or PC.
mr240 is offline   Reply With Quote
Old 06-27-2010, 06:48 PM   #4762
RCHR Racer's Avatar
Ill keep you posted. Testing tomorrow the settings with a 2.1 with 528 software. In a RB5 SP. Will let you know.
Last week, started with default settings which were fine. seemed smooth, but trying to smooth out a little more since offroad is much different with bite levels
Speed Passion USA Team / SpeedPower Lipos / Radio Control Hobbies and Raceway
RCHR Racer is offline   Reply With Quote
Old 06-27-2010, 07:18 PM   #4763
The basic settings can be changed with the "programming" card that came with the speedo. For advanced settings via your PC or to change software, you'll need the "Professional" programmer.
Rob...........
*Restructuring* :)
Old 06-27-2010, 07:29 PM   #4764
Sounds good.
Right now I'm running 205c with the previous software.
Rob......
*Restructuring* :)
Old 06-28-2010, 04:44 PM   #4765
Default 528 software
Originally Posted by skypilot View Post
if your running windows 7, you need to run the program as admin to get it to overwrite.
the new software does work with the lpf,
this is where we miss Adam, he was very good at explaining these sorts of things. I wish I could explain it in full detail.
I dont have W7 I have XP
emerge is offline   Reply With Quote
Old 06-28-2010, 10:44 PM   #4766
syndr0me's Avatar
Trader Rating: 32 (100%+)
Been looking for something with a little better feel down low than the Tekin, and decided to give the SP 2.1 a try. It definitely delivered, the way the motor rips out of the turns is phenomenal! The only thing it seems to lack is that rip on the straight that you get with a Tekin. It definitely seems to boost on the straight, just not quite as hard. Any suggestions? I'm running a SPv3 17.5 with an FDR of about 6.4. Settings are as follows:
4/8
9/8
12/7
13/2
14/3
15/2
If I tried to gear up much more, it would get slower and hotter. Timing on the motor is maxed.
Track has about a 95' straight. You can see it here. Layout is different now, but that gives you the gist of it.
syndr0me is offline   Reply With Quote
Old 06-28-2010, 11:02 PM   #4767
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
4/8
9/8
12/7
13/2
14/3
15/2
Goto 13/1 and gear it 5.9. You will feel it more on top. PS, keep the timing on 5* since the straight is so short.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 06-28-2010, 11:27 PM   #4768
defcone's Avatar
Trader Rating: 15 (100%+)
I'm running on a similar track but with a v2 motor, is gearing the same as a v3?
defcone is offline   Reply With Quote
Old 06-28-2010, 11:47 PM   #4769
Super Moderator
charlie_b's Avatar
Hey Def,
The V2 motor has timing built in. The factory settings of the V3 is 5* and obviously CAN be adjusted, but i prefer the factory timing because you can gear the motor higher since the V3.0's naturally have more torque.
With the V3.0, i would gear if a couple of teeth higher to start.
Old 06-29-2010, 08:03 AM   #4770
steveonamission's Avatar
Originally Posted by steveonamission View Post
Hi Chaps
Starting to give 10.5 a go, after running modified for a while....
I could do with a starting point on settings for a track straight length of 55metres.
Its a little technical
528 firmware.
Thanks for your time
Steven
Cough.
www.fuller-paint.blogspot.com
steveonamission is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
