Like Tree12Likes
Old 06-22-2010, 03:12 PM   #4711
Yeah sorted now thanks RCHR Racer
S.A.W is offline   Reply With Quote
Old 06-22-2010, 03:15 PM   #4712
RCHR Racer's Avatar
Excellent!
Speed Passion USA Team / SpeedPower Lipos / Radio Control Hobbies and Raceway
RCHR Racer is offline   Reply With Quote
Old 06-22-2010, 03:33 PM   #4713
Default 528 f/w lacks punch?
Hi guys,
Only discovered the new 528 firmware today, so quickly loaded it into my GT2.1 and put the settings to the same as I used with the 422 f/w.
Went racing this evening and found the car had great top speed but really lacked punch.
Do you think I need to re-update the ESC to make sure the f/w 'took' properly?
Or do I need to change some of the settings with 528?
With the 422 f/w I had loads of punch coming out of corners. With the same settings the 528 f/w is very 'soft'.
Any help much appreciated.
Frank
Frankgw is offline   Reply With Quote
Old 06-22-2010, 03:40 PM   #4714
Originally Posted by Frankgw View Post
Hi guys,
Frank
Post your settings, motor brand and type and track size. So we can help.
None of us have found this.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 06-22-2010, 05:15 PM   #4715
I have not found 528 to be "soft" but I must say it really is no different on the track to HW518... I raced against a competitor with exactly the same settings as me but earlier software (518) and could notice no difference at all. Not even an inch difference down our approx 70m straight.
I think SP528=HW518
Mike
ixlr8nz is offline   Reply With Quote
Old 06-22-2010, 05:35 PM   #4716
I think SP528=HW518
Mike
I'm not comparing SP to HW. Last weekend I helped a racer at our local track with a HW speedo w/ 518fw with a x12 17.5. He made a couple of adjustments after we spoke and car was up to speed.
There is a difference from SP422 to SP528. I feel that SP528 has more mid power band and runs cooler over the SPSP422. Also been able to lower the supercharge settings.
Steve Walter
Old 06-22-2010, 06:21 PM   #4717
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I will vouch that Steves car has as much rip as any of the top guys around are area for HP. He is not lacking as he has his Speed Passion speedo figured out.
Even if he has a bad run it is not because of the lack of rip thats for sure.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-22-2010, 10:15 PM   #4718
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
I think SP528=HW518
Mike
Mike, we never tested the 518 so we really have nothing to compare it to.
I will just say i am gonna have to believe you since we(SP Drivers) did not test the 518.
Regardless, 100528_stock is by far the best Stock software we have tested and is easily tunable to any circumstance on the track.
For those having issues, there could be different reasons why you are not having "Rip". Just post your settings and gearing and one of the SpeedPassion drivers will chime in to help with your set up.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 06-23-2010, 12:43 AM   #4719
Hi,
Is there a suggested starting set up pdf for the 100528 ? I have one for the 100422 or should I use the same settings ? It's for a 17.5t.
Thanks.
Old 06-23-2010, 02:20 AM   #4720
I found with the 528 I had to gear down 1 pinion (48pitch) I used the same settings as the 422
Barger is offline   Reply With Quote
Old 06-23-2010, 03:14 AM   #4721
Default Where can I buy the 2.1?
Hey guys. After spending a fortune buying the latest SXX SS i want to give the SP 2.1 a go. I like the idea of downloadable updates. Can someone please let me know where I can buy one online as I cant find them available anywhere. Cheers.
Bumpy is offline   Reply With Quote
Old 06-23-2010, 03:47 AM   #4722
Mitch-e4fs's Avatar
Hi im looking to get a brushless ESC and am very interrested in the sp 2.0.
Ill be using it for mostly 21.5-17.5 in non stock esc racing ie: Tekin rs in stock/superstock with max boost. Will the mod profiles be best for me? Im currently running silver can in Vintage class 21.5 (similar to Trans am) and can keep up through the corners but down the straight i get blown away. Is this the ESC for me?
Mitch-e4fs is offline   Reply With Quote
Old 06-23-2010, 04:07 AM   #4723
RCHR Racer's Avatar
Absolutely!
Old 06-23-2010, 04:32 AM   #4724
Mitch-e4fs's Avatar
Originally Posted by RCHR Racer View Post
Absolutely!
Will I be as competative as the tekin guys?
And will I need the "black box" to
set it up and tune it properly?
And is the speed passion unit better than the hobbywing? Or are they identical?
Old 06-23-2010, 05:05 AM   #4725
OK, sorry.
Thanks for the comments.
Track is tight twisty indoor carpet, Losi fixed timing 13.5T. FDR 6.17 on a Tamiya 416WE.
ESC settings:
4/7
9/5
12/3
13/2
14/3
15/7
I know these are pretty soft settings, but with the 422 f/w the car had plenty of punch. Now with the 528 it seems very soft and picks up speed after what feels like a 2 second delay (probably less really!).
Any ideas? I will try re-flashing the ESC and see if it's any different.
Cheers
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
