Like Tree32Likes
Old 06-21-2010, 05:57 AM   #4681
razzor's Avatar
Originally Posted by CraigM View Post
The esc timing is in addition to the can timing. I don't find the v3s come alive unless the can timing is maxed out
check your gearing is not undergeared.
V3 motors with the timing maxed and the esc values high can be overtimed so keep an eye on it.
The V3 motors are more torquey so take more gearing compared to some other motor brands.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-21-2010, 07:42 AM   #4682
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
maxing out the timing on the motor all you are doing is adding heat to the motor, they motor does sound faster but is not faster on the track.
Old 06-21-2010, 07:44 AM   #4683
tns
Originally Posted by Marcos.J View Post
i have it on my lpf, so yes it does work on them
Originally Posted by irgo View Post
1. because 2.1 is pro only.
2. technically it's ok, but not quite safe, depend on which motor turn you run with. so keep watching the ESC temps, and never forgot to use your fan.
Originally Posted by Anemic_SluG View Post
I have been running it on my 2.0 pro with a 10.5 for the last to race outings and have had zero issues... Just great performance. Just watch temp on both esc and motor....
Thanks all for the replies!
tns is offline   Reply With Quote
Old 06-21-2010, 09:41 AM   #4684
Obviously you haven't tested it on any big tracks.... It is noticeably faster on big tracks with max timing on the motor. It will suffer for about the first 2 meters but then is faster altogether. Motor temp is usually around 38-50 degrees depending on grip, air temp etc.
Mike
ixlr8nz is offline   Reply With Quote
Old 06-21-2010, 11:28 AM   #4685
Super Moderator
Marcos.J's Avatar
Mike
i havent raced on a big 1/8th scale track but I have in the past but not with the new software ,and in the past the motor felt better and didnt fade when I ran stock timing, with the advanced timing the motor felt like it was fading at the end of the run and generated more heat.
Old 06-21-2010, 12:14 PM   #4686
Well you may want to go back and retest with the newer software because I can tell you that its noticeably faster and of course runs cool because of the dynamic timing. My car is fantastically fast with a gear ratio of 6.2 and all the settings in the esc set as per the hobbywing guide.
One motor which is does not work well with built in timing of any kind is the LRP X12.
Mike
Old 06-21-2010, 03:24 PM   #4687
Hi guys, can someone tell me what the difference is between the 422 and the 528 speedpassion software ? If anyone has tried the new 528 version with v3 4t motor are the settings the same as the 422.. Also with 4t on these timed softwares what should the mechanical motor timing be on?
Cheers
mark
mark williams is offline   Reply With Quote
Old 06-21-2010, 08:31 PM   #4688
RCHR Racer's Avatar
Need Help
Setup a GT2.1 for an 8.5 V3 on 2WD offroad. How do I get another program int it. I am unfamiliar with the process. I do have the LCD card hooked up to laptop and ready to go.
I have used the Mod software pre installed but esc runs hot. Overall runs ok, but I understand I can get a better software program?
Speed Passion USA Team / SpeedPower Lipos / Radio Control Hobbies and Raceway
RCHR Racer is offline   Reply With Quote
Old 06-21-2010, 08:48 PM   #4689
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Originally Posted by RCHR Racer View Post
Need Help
here ya go.
SPEEDPASSIOn VIDEO on LCD CARD
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 06-21-2010, 08:50 PM   #4690
Super Moderator
charlie_b's Avatar
Cheers
mark
MArk,
The 422 and 528 are DIFFERENT.
100528 has 2 versions. Stock and MOD. YOU want to run the 100528_MOD version for your 4T motor. On the Sp website, you can use Reinghardt's set up from there. Please check that out.
Old 06-21-2010, 09:19 PM   #4691
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i saw some promotion sales here for sp stuff...
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-21-2010, 09:21 PM   #4692
Super Moderator
charlie_b's Avatar
Originally Posted by kschu View Post
i saw some clearance sales here for sp stuff...
CLEARANCE??? Ur not gonna carry SP anymore?
Old 06-21-2010, 10:38 PM   #4693
Originally Posted by charlie_b View Post
MArk,
Hi Charlie
I have been using 422 for a while now and I am very comfortable and used to my current settings. Now that there is this "newer" software which is supposed to be "better" and "different" as you have mentioned, I want to try it out but I hate to change the settings and start all over again. Before I do it, could you please let me know if he base setup for 528 is more or less similar to 422 and what is the key item in 528 that I should be aware of. If 528 gives better performance and most importantly a cooler running motor, I will most likely make that upgrade. I am sure many other people in this thread would like to know about this. Thanks in advance for your help.
HCHL is offline   Reply With Quote
Old 06-21-2010, 11:06 PM   #4694
Super Moderator
charlie_b's Avatar
Originally Posted by HCHL View Post
Hi Charlie
Understood.
As far as differences:
I used to get MAD power fade after about 4 minutes at ANY settings. Not anymore.
In used to run MAX BOOST to keep up with other boosetd ESC's. Not anymore. I basically run stage 5-7 and have been happy with it.
I used to run #1 on #13,#14, and #15. It has way more punch that i run between 2-4 on those settings. With that being said, here is what i have been running for about a month with NO change.
Motor:17.5 V3
4/8
9/8
12/7
13/2
14/3
15/2
On a track with a 120' straight, gear it between a 4.5 and 5.5 FDR.
These settings are for preference and feel. Adjust accordingly and at your own risk.
Old 06-21-2010, 11:13 PM   #4695
kschu's Avatar
wrong word...should be promotions..
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
