Like Tree12Likes
Old 06-19-2010, 11:36 PM   #4666
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Marcos.J View Post
its the sensor inside the motor try changing it that should take care of it.
Do you know where you can buy v2 sensor units?
defcone is offline   Reply With Quote
Old 06-20-2010, 12:30 AM   #4667
I changed motors and sensor cables...could the capasitor becausing it?I will wait till next week and get my mate to flash the 422 into it and see if that fixes it....apart from that it must be a speedie issue..software or hardware I am not sure...but it never got hot
Barger is offline   Reply With Quote
Old 06-20-2010, 01:20 AM   #4668
irgo's Avatar
Where is your location ?
Quark Force
irgo is offline   Reply With Quote
Old 06-20-2010, 01:36 AM   #4669
defcone's Avatar
Australia.
Old 06-20-2010, 02:45 AM   #4670
tns
Default 528 software only for v2.1 esc?
Hi
Does anyone know why the 528 software is stated as being only for v2.1 series of ESCs? Safe to use it with a v2.0 LPF?
tns is offline   Reply With Quote
Old 06-20-2010, 03:34 AM   #4671
Hi,
When using the sp motor 17.5t and speedo with the 100422stock software what should the timing be set at on the actual motor ? does the speedo automatically take over the timing regardless of what it's set on the motor ?
Also on this link files.mibosport.com/200001241-5ea455f9ed/Supercharger%20Starting%20points dot pdf what are they refering to on items 1-8 under 17.5t ?
Nothing seems to match up with all thre documents
S.A.W is offline   Reply With Quote
Old 06-20-2010, 05:39 AM   #4672
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
Originally Posted by tns View Post
Hi
i have it on my lpf, so yes it does work on them
Old 06-20-2010, 06:34 AM   #4673
irgo's Avatar
Hi
1. because 2.1 is pro only.
2. technically it's ok, but not quite safe, depend on which motor turn you run with. so keep watching the ESC temps, and never forgot to use your fan.
Quark Force
Old 06-20-2010, 10:52 AM   #4674
Trader Rating: 22 (100%+)
I have been running it on my 2.0 pro with a 10.5 for the last to race outings and have had zero issues... Just great performance. Just watch temp on both esc and motor....
Speed Passion U.S.A. - Turtlemaster Racing
www.speedpasion.net
Anemic_SluG is offline   Reply With Quote
Old 06-20-2010, 12:13 PM   #4675
I would go through the following fault finding process:
1. Put 528 back on and set as it was
2 Turn the Lipo cutoff to the off setting
3 Test the car.
If the car goes fine and does not slow down then you have a battery/connector problem or faulty esc.
If the car is just like before then you have a output problem. Probably a faulty esc or sensor wire plug.
Mike
ixlr8nz is offline   Reply With Quote
Old 06-20-2010, 12:52 PM   #4676
robk's Avatar
Check your motor timing as well. My car had problems when i tried lower timing, but has no problems at higher timing.
robk is online now   Reply With Quote
Old 06-20-2010, 08:22 PM   #4677
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by S.A.W View Post
Hi,
I don't know what that link is, but on the timing, I run mine in the middle where it came from the factory
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 06-21-2010, 12:51 AM   #4678
CraigM's Avatar
Trader Rating: 34 (100%+)
Hi,
The esc timing is in addition to the can timing. I don't find the v3s come alive unless the can timing is maxed out
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-21-2010, 03:36 AM   #4679
I agree
Still trying to find the problem with my speedie...going to change capasitor tomorrow...let you know how it goes
Old 06-21-2010, 03:51 AM   #4680
CraigM's Avatar
I agree
It sounds as if it's hitting the lipo cutout, double check the voltage per cell is set right (3.0v) and that your batts are in good nic. Normally when the cap is stuffed all you get cogging when you mash the throttle
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
