Like Tree32Likes
Old 06-17-2010, 12:07 PM   #4651
When I went from a SP V2 17.5 to a SP V3 17.5 motor I lost my drag brake, the only setting that works is all the up at 8 and thats way to much.
Any suggestions on what to try?
Dave Barber is offline   Reply With Quote
Old 06-17-2010, 02:20 PM   #4652
Originally Posted by Marcos.J View Post
try these
its what I ran with the 422 but it worked great with the 528
Thanks Marcos...similar to what I was running except I had no drag brake...will try it also my FDR5.48...maybe a bigger track? and 13/14 I had at 5..will change that.I found my setup a tad slower( than guy with a good Tekin setup) at the start of the back straight,but otherwise very good.
Barger is offline   Reply With Quote
Old 06-18-2010, 03:03 AM   #4653
Originally Posted by altreyx View Post
There is no need to delete the previous version that is the 1,33
Unzip the downloaded file and inside you will find the 1,33 version setup.exe + settings.db3 /version control.ini + .doc file (is a small manual about the SC software)
Copy these 2 files (settings.db3 , version control.ini) and past to your SP directory that should be XX(normally is C):\Program Files\Speedpassion USB Link V1.33
When it will ask overwrite 2 filesa select “yes” and you will have the last firmware release.
Hoping what i wrote is clear
I finally had some time to sort the issue out, My netbook running XP updated by just copying the files. However the PC with Vista installed needs to be updated differently.
As Vista determines the settings.db3 file to be a data file it does not use the version in the program files directory but an alternate version in the following path C:\Users\User_name\AppData\Local\VirtualStore\Program Files\Speedpassion USB Link V1.33.
For more info have a look at the following Microsoft article
After this it works fine
XRAY T4 2015 | Hobbywing Club Spec | Thunder Power 21.5
miku is offline   Reply With Quote
Old 06-18-2010, 04:19 AM   #4654
AZ416's Avatar
iv tried doing this, even deleting all previous version and re-installing them but still nothing, still comes up with the 422stock software, any ideas =)
thanks
Adam Z - TAMIYA 416X/lipo deck Powered by:
Speed Passion V3.0 - LRP SXX Tc Spec - Spektrum - Sorex - Protoform Custom Painted
AZ416 is offline   Reply With Quote
Old 06-18-2010, 04:31 AM   #4655
altreyx's Avatar
thanks
Only installing the "new" 1,33 setup nothing is changing, you need to overwrite the control.ini and settings.db3 files
You will find them into the new unzipped folder; copy and overwrite them to Speedpassion directory and you should have the new firmwares.
If is not working i don't have any idea, may be someone else can help you better than me.
@Miku: i'm using windows7 and no problem at all, at the end i'm happy that you have solved your "issue"
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 06-18-2010, 04:43 AM   #4656
MikeXray's Avatar
Trader Rating: 73 (100%+)
The updated zip is under the 2.1 ESC not the lcd programmer, just FYI.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 06-18-2010, 04:52 AM   #4657
AZ416's Avatar
ok got it, i did what "miku" did with the vista thing and it worked fine, only other thing is what difference is there with the V2 mod software and the V1
thanks =)
Old 06-18-2010, 12:26 PM   #4658
irgo's Avatar
Originally Posted by charlie_b View Post
We all tested the software, so it is fine...but it is still at you own risk. It is impossible to guarantee anything electronic due to the fact that every user is different and there is no control on how a user would use/abuse it.
Is it safe to race? Definitely.
Could if blow your stuff? Definitely, just like any software, but most unlikely if not abused(geared wrong, using stock software with mod motor, etc.).
The 100528 stock and mod are tested and has been very successful at the track.
Reinhard is using the 100258_mod.
are you sure 100258_mod ?
Quark Force
irgo is offline   Reply With Quote
Old 06-18-2010, 02:05 PM   #4659
SpeedySST's Avatar
Default 14ga wire for GT2.1
Sorry if this has been asked and answered before but I received a GT 2.1 with 14ga wire. I am tempted to use TQ 13 ga wire but I have some pretty flo green 14 ga wire sitting around. Will it make a difference when using 13.5 or 17.5? Thanks guys!
SpeedySST is offline   Reply With Quote
Old 06-18-2010, 02:28 PM   #4660
thanks
I had the same problem a while back when trying to use the first supercharger software and it was with Windows Vista AND you have to right click on the Speed Passion icon (on your desktop) and RUN IT AS ADMINISTRATOR. Then all the other options come up once your speedo is all connected up etc.
Hope that helps you
Mi4LP / Speed Passion GT Pro V 2.1 Pro Stock / GM 10.5 Pro Stock
Cat SX / Speed Passion GT Pro V 2.0 / Speed Passion 6.5 V2
Mugen MBX6T / Ninja BO1A
baldman666 is offline   Reply With Quote
Old 06-19-2010, 10:36 AM   #4661
Can some please tell me where I can find the left hand side document the Joel posted ?
Thanks.
S.A.W is offline   Reply With Quote
Old 06-19-2010, 11:05 AM   #4662
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Ur right...100528_mod. =)
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 06-19-2010, 08:44 PM   #4663
Got a problem...Had V2 pro wth 422 for a few weeks now...going great...flashed 528 last night,ran 1 heat ...impressive,in the next heat(went down 1 pinion)was going great for half the race then went slow for a couple of seconds then stopped.turned the car off then on again same thing, it would rev a bit then slow and stop.Changed motors,flashed speedie again,reset radio...still the same...anyone got any ideas?
Old 06-19-2010, 08:53 PM   #4664
try changing your sensor cable, clean out the port on the speed-o with air, make sure you have a good connection
gdcopbdcop is offline   Reply With Quote
Old 06-19-2010, 10:21 PM   #4665
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
its the sensor inside the motor try changing it that should take care of it.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
