Like Tree34Likes
Old 06-13-2010, 07:58 AM   #4576
SpeedySST's Avatar
Ok so yeah I DID miss something! I blame my Polish heritage!
SpeedySST is offline   Reply With Quote
Old 06-13-2010, 08:05 AM   #4577
Originally Posted by charlie_b View Post
Most likely it will be released with in the week. It will be STOCK and MOD version of this software. It is very successful on the track where Reinhard and other drivers are loving totally loving it, including me.
I totally agree.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 06-13-2010, 10:29 AM   #4578
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
it is!! Its awesome,
Old 06-13-2010, 11:04 AM   #4579
Trader Rating: 22 (100%+)
Originally Posted by defcone View Post
What does it mean when my speedie blinks green non stop, but the motor still runs perfectly? I'm running a GT2.0 Pro with a SP v2 4.0t tried different sensor cables, recalibrating still has the green light flashing.
Thanks in advance.
I was helping at the track and the guy I was helping had the same issue... Turned out it was his sensor wire. It was not plugged in all the way. So make sure it is pushed way down into the esc and motor.
Someone can correct me if I am way off base, but it looks like the green blinking led is a sensor issue... Is there a listing of error codes somewhere. It would be helpfull when trying to locate a issue between the esc and motor.
-j
Speed Passion U.S.A. - Turtlemaster Racing
www.speedpasion.net
Anemic_SluG is offline   Reply With Quote
Old 06-13-2010, 12:47 PM   #4580
i have bin out of the game for about 6/7 years now.
and the 2.0 pro would be my option
in the pdf manual it says
The voltage of the ESC fan socket is equal to the voltage of the battery, so please keep in mind that the voltage of battery CANNOT be over the voltage limit of the fan. (6 Cell Ni-xx or 2 Cell Lipo)
now what do they meam with 2 Cell Lipo ?
will tis ESC work with a (for example a Carbon Molecular 5400 45C 7,4V lipo)
Grtz Lockyie
Lockyie is offline   Reply With Quote
Old 06-13-2010, 01:24 PM   #4581
mlight13's Avatar
Trader Rating: 40 (100%+)
I need some help. I am running a XeRun 13.5 (2,500kv) motor and SP 422 firmware with an FDR of 7.31 which seems perfect for my medium asphalt track as I hit full speed right at the end of the straight. My motor temp hit 205*F after 5 minutes and the outside air temp was around 75*F. I need it to run cooler, but how??? I thought I was already running conservative settings on my ESC.
My ESC settings are:
4/ 8
9/ 7
12/ 7
13/ 4
14/ 5
15/5
The car seems good all around with speed and braking, but the motor gets waaaay too hot! Please help!
Mark
mlight13 is offline   Reply With Quote
Old 06-13-2010, 03:13 PM   #4582
Super Moderator
Grtz Lockyie
No problem, that is a 2 cell lipo, it will work great, we’ve got some of the same batteries.
The lipo cells are 3.7 volts per cell nominal, thus a typical rating of 7.4 Volts for a standard 1/10 scale 2 cell lipo. You will also see them called a 2s lipo, for 2 in series. They max out at 4.2 volts per cell fully charged.
Just be sure you have the Low Voltage Cutoff turned on. Lipos are sensitive to over charge or over discharge, other than that they are darn near incredible.
Hey guys, thanks for the replies on the 52*. I'll patiently (???) wait.
Dave H is offline   Reply With Quote
Old 06-13-2010, 03:29 PM   #4583
Thx for the fast reply Dave.
a few other question not ecs related and maybe this is not realy the place to ask them.
-Dont chargers have a option to see whan they are full ?
-Do you have do discharge lipo's? (i was in the understanding not to do that)
Old 06-13-2010, 04:37 PM   #4584
Super Moderator
We can go offline, expect a Private Message shortly.
Old 06-13-2010, 05:27 PM   #4585
you need to cool down motor temp by using proper heatsink (sp heatsink recommended), thermalpaste & 1 or 2 good fan (e.g. tornado fan from YR)
http://www.speedpassion.net/en/productDetails.asp?p=15
4/ 8
9/ 7
12/ 7
13/ 4
14/ 5
15/5
leonardiw is offline   Reply With Quote
Old 06-13-2010, 05:58 PM   #4586
Abu Salahuddin's Avatar
4/ 8
9/ 7
12/ 7
13/ 4
14/ 5
15/5
I am running a SP V2 11.5t motor with the 422 FW. My motor temp usually at 65-70*C. First I suggest that you get a heatsink and a fan to externally cool the motor. This will help alot.
If I'm you at that FDR, I'll use this setting: -
4/ 7
9/ 5
12/ 7
13/ 1
14/ 2
15/ 4
Abu Salahuddin is offline   Reply With Quote
Old 06-13-2010, 06:43 PM   #4587
mr crum's Avatar
Send a message via Yahoo to mr crum
Thanks in advance.
if u already replaced sensor wire and you still have blinking green light .
take your motor apart and clean the sensor if that dont work then you have a faulty sensor
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 06-13-2010, 07:45 PM   #4588
skypilot's Avatar
Trader Rating: 14 (100%+)
anyone come up with a cure for having to reset the esc every so often
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 06-13-2010, 07:56 PM   #4589
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Get a Tekin.
Seriously though the Shouie looked good today.
You're my idol.
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 06-13-2010, 08:25 PM   #4590
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Logi Maker View Post
Get a Tekin.
LOL, a tekin is NOT a cure for resetting your esc often.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
