Like Tree32Likes
Old 05-22-2010, 11:05 PM   #4411
KWT-NITRO's Avatar
yokomo-ant3, you have a PM
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 05-22-2010, 11:31 PM   #4412
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Yokomo_Ant3 View Post
RedRC mentioned it in an earlier report from this weekends ETS round.
It also mentioned he came to a halt due to overheating.
defcone is offline   Reply With Quote
Old 05-23-2010, 10:53 AM   #4413
Had a good showing with the SP speedo yesterday at Jackson RC Raceway running 17.5. Qualified 6th out of 18. I was the only SP speedo. Rest ran Tekin. Fastest lap of the day was 13.48 and mine was 13.61. Speedo ran strong all day. The motor temp's was a little high for my liking. Need to work on that. Next weekend is our big Memorial Day Race. 50- 17.5's and 30- 13.5's have entered.
4/8
9/8
12/9
13/3
14/2
15/2
sp17.5v3 10 timing
FDR 5.22
outdoor asphalt 140x70
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 05-23-2010, 12:26 PM   #4414
Vicko's Avatar
Trader Rating: 14 (100%+)
so where can I dl the lastest sofewear for the speedo?
also is any one using this speedo with the LRP X12 17.5
I'm running on an 100 by 45 track
Vicko is offline   Reply With Quote
Old 05-23-2010, 12:49 PM   #4415
Super Moderator
Under the download tab:
http://www.speedpassion.net/us/productDetails.asp?p=65
Dave H is offline   Reply With Quote
Old 05-23-2010, 12:52 PM   #4416
Danny-b23's Avatar
http://www.speedpassion.net/us/productDetails.asp?p=56
It will be under "Downloads".
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 05-23-2010, 02:08 PM   #4417
Originally Posted by @tomino View Post
Just now I updated my ESC 2.0 120A with the latest stock FW. In doing the upgrade, I also saw the FW no timing and I got a curiosity. This firmware installed on board make it similar to cirtix?
This question because I saw that many clubs are taking this regulator to achieve a pure stock class. I was wondering if I was in one of the tracks where they run with this ESC, could I participate with my ESC on which I installed the FW in question, or I would be the difference in performance against them (both positive and negative)?
Hi guys, someone has an answer for me?
@tomino is offline   Reply With Quote
Old 05-23-2010, 02:57 PM   #4418
Thumbs up
4/8
9/8
12/9
13/3
14/2
15/2
sp17.5v3 10 timing
FDR 5.22
Steve, the SP controllers do not like a lot of timing on the motors. Try using 5 degrees of timing instead of 10 degrees, then on your supercharger settings, try the following:
13-2
14-1
15-1
also put a fan on your motor, and wire it directly into your battery. try that, and let us know how it works.
Rich
gdcopbdcop is offline   Reply With Quote
Old 05-23-2010, 02:58 PM   #4419
Steve,
also, i would gear it about the same, and as always, keep a close eye on the motor temps.
Old 05-23-2010, 03:49 PM   #4420
does anyone know if it was the 422 software the TRF team were using in mod 4.0t at the latest ets round ? , i guess the settings would be fairly mild..but it sounds like they were fast down the straight to the point where groskamp couldnt stick with them down the straight..Mmm
mark williams is offline   Reply With Quote
Old 05-23-2010, 06:27 PM   #4421
CraigM's Avatar
Trader Rating: 34 (100%+)
more likely 518 or an unreleased "team" software
I'd like to know the sort of settings they were using, watching the video they certainly pull away from Jilles and his nosram. Hara's GM was in a league above them even
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-23-2010, 07:55 PM   #4422
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Nope...it is the 100422. Boost settings were mild and timing down to zero.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 05-23-2010, 07:57 PM   #4423
Super Moderator
charlie_b's Avatar
Zero timing is Zero Timing. If the track to you goto has a Zero Timing Class, this version software is the one you will use.
Old 05-23-2010, 08:29 PM   #4424
@charlie_b
Charlie, what is the recommend starting point for mod 3.5T fdr & turbo setting (param: 4,9,12,15)
leonardiw is offline   Reply With Quote
Old 05-23-2010, 09:51 PM   #4425
hey guys a bit of an off shot
just looking for a setting with the new firmware. I'm goina to be using it in a wgt car with 2s lipo. with a 10.5.
I need a not so aggressive start off the line and coming out of 180's to the the nature of the car can be a bit squirlly if you understand pro 10,s you know what i getting at.
plus a quick down the shuts and a good blast for the straight.
yes,i have the new firmware updated and the motoe is a trinity base. not sure what what excatly it is. just trying to get a decent starting set up that i can go for there.
cyrrus is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
