The Speed Passion Thread
#4396
#4397
Hi guys
Its been a while since i update my speedo. What is the best and latest software for mod and stock?
#4398
you can run ddrs at 7 and below and not lose the supercharger. it helps on the smaller indoor technical tracks, especially with lower heat............
#4399
Just now I updated my ESC 2.0 120A with the latest stock FW. In doing the upgrade, I also saw the FW no timing and I got a curiosity. This firmware installed on board make it similar to cirtix?
This question because I saw that many clubs are taking this regulator to achieve a pure stock class. I was wondering if I was in one of the tracks where they run with this ESC, could I participate with my ESC on which I installed the FW in question, or I would be the difference in performance against them (both positive and negative)?
#4400
#4401
#4402
Super Moderator
But then again...you can tune your esc however you feel makes you fast on the track....
#4403
At higher heat, i don't mess with the DDRS..never have. Heat is generated through timing. So adjusting timing, how much delay, how much timing per RPM increment all plays a factor, not just DDRS.
#4404
#4408
It wouldn't surprise me if they were using the stock software in Mod. It could potentially make the motor run cooler and also faster + you may be able to run a lesser motor like 6.5 instead of 4 turn to make the car smoother to drive but yet have great top speed.
You may have to run no turbo though.
Mike
Mike
#4409
Mike
Mike
Although, I wouldn't doubt that they are running the V422 software because of the way the track is. Lots of straight shots and sweeping corners. Not a lot of "stop-n-go".
