Like Tree32Likes
Old 05-13-2010, 10:40 AM   #4276
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
Originally Posted by SRW141 View Post
Didn't work.
try now
Old 05-13-2010, 10:47 AM   #4277
Originally Posted by Marcos.J View Post
try now
Worked. What size is the track?
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 05-13-2010, 12:28 PM   #4278
Send a message via MSN to geubes
Wow marcos they are very different FDR's to what I ran a 17.5 at - quite similar track size i believe from the setup sheet.
Are you putting max timing and boost into the 13.5 as well?
I have been running 6.1 with great results for a 17.5, but you suggest trying around 4.8 interesting.
well i will be running the 13.5 this weekend and would have expected to be about 7.1, but might also try going to your FDR of 6 to see what happens
geubes is offline   Reply With Quote
Old 05-13-2010, 12:49 PM   #4279
Trader Rating: 8 (90%+)
I could not get the file to work, it is just script.
I went out this morning and ran the new software and it was pretty fast, I would like it to kick in earlier on the straight. I was running a 5.40 and was just gaining speed all the way through the sweeper. The car is still wanting to push out and not hold through it as much now that I have all this speedbut my laps are faster so I really cannot complain. I just need to figure out how to hold this all now.
Here is a picture of our track. We are getting ready to lay new carpet and there have been some renovations going on also. It is 75x40 with decent grip most of the time
http://www.flickr.com/photos/43445913@N03/4604833174/
http://www.flickr.com/photos/4344591...n/photostream/
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris Totcky@facebook.com
Tha Skinny is offline   Reply With Quote
Old 05-13-2010, 01:12 PM   #4280
I was doing testing with 100422 at a 100x48 indoor asphalt track. Not sure what your settings are. I ran the same settings as Marcos except #14 was set to #1 and #15 was set to #1. FDR was 6.15. Dropping #14 should kick in earlier. SP17.5v3
Hope this helps.
Steve Walter
Old 05-13-2010, 01:23 PM   #4281
Super Moderator
Marcos.J's Avatar
medium track i say maybe like 110 to 120 foot straight??
Old 05-13-2010, 01:24 PM   #4282
Super Moderator
Marcos.J's Avatar
it worked well for me
Old 05-13-2010, 05:19 PM   #4283
I'm going to be running on a track this weekend that is 210'x110' in Chaplin, CT.
Steve Walter
Old 05-13-2010, 05:47 PM   #4284
I'm running a photon with the 422...
11.5 T with FDR 7.5
Settings on 422:
9 - 7
12 - 8
13 - 4
14 - 5
15 - 4
After a 5 minute run, motor temp is a whopping 88 degrees celcius (ambient temp is approximately 33 degrees celcius)
love the new software... but apart from adjusting s/w to bring temps down (at the expense of infield punch and speed on the straight), what else can I try? Or is there really something wrong with my settings?
sammies is offline   Reply With Quote
Old 05-13-2010, 05:54 PM   #4285
Super Moderator
Marcos.J's Avatar
11.5 T with FDR 7.5
Settings on 422:
9 - 7
12 - 8
13 - 4
14 - 5
15 - 4
Try my set up that I posted and also I would go to 6.5 to a 7.0 ratio.
Old 05-13-2010, 06:00 PM   #4286
thanks for the reply..
will try that tomorrow
Old 05-13-2010, 06:06 PM   #4287
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
you running this weekend,i thought ceaser said it was around 160ft
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-13-2010, 06:11 PM   #4288
Super Moderator
Marcos.J's Avatar
could be i never measured it, racing , I was I cant now have to work
Old 05-13-2010, 06:12 PM   #4289
Super Moderator
Marcos.J's Avatar
what is your motor timing? make sure is at default(if its the V3 SPmotor)
Old 05-13-2010, 06:16 PM   #4290
am running a budget roche 11.5T... fixed timing
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
