Old 05-03-2010, 02:19 PM   #4036
skypilot's Avatar
Trader Rating: 14 (100%+)
THAT is how reverse works, you have it turned on, flashing the software will not cure your problem, which actually isn't a problem, its just how the esc works. if you have program card its just a 1 minute change to turn on and off.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 05-03-2010, 03:02 PM   #4037
Originally Posted by Solara View Post
That is a throttle profile...I would say using stock motor, should be around 7, 8 or 9....if using MOD motor, may be 5, 6 or 7....I don't think using 4 is necessary.
Also, using 9 (most aggressive) does not get me faster lap time...just add more heat onto the motor. And it is a personal preference, may be you find it 0.1 faster then 7 or 8...but all my setup are between 7 or 8...7 for small tight track and 8 for bigger more open track.
thanks for the explanation, i had an experiment at the weekend and turned #4 down to 5 and the supercharger didnt kick in. put it back to 7 and it did.
the track i race at has a 45metre straight so i might try #4 at 8 and see if i get any improvement. what i really need now though is better handling as i am finding it difficult handling all the extra speed and power( started racing this year in january). im finding now that i cant find the apexes of the corners and my lap times are suffering, lol.
any advice on driving skills would be appreciated
chrissyred is offline   Reply With Quote
Old 05-03-2010, 04:28 PM   #4038
mr crum's Avatar
Send a message via Yahoo to mr crum
be smooth and practice practice practice
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 05-03-2010, 05:06 PM   #4039
Trader Rating: 8 (90%+)
I have a 17.5 3.0 and the sensor wants to slide around on me. Is there a way to fix this. Right now I have it stuck on 0 I really want to be able to play with the motor timing. What are the timing settings you guys are using with this motor?Also Is 0deg of timing really 0 degrees or is it 30 or something like a Novak?
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris Totcky@facebook.com
Tha Skinny is offline   Reply With Quote
Old 05-03-2010, 06:20 PM   #4040
lastsun's Avatar
hi, just need some help. i am running the SP GT2.0 PRO on a 12th scale with 1S 3.7v Lipo and a 6.6v LiFe receiver pack.
-i have problem using the LCD program box with 1S Lipo, i need connect to a 2S Lipo. is it normal?
-do i have to set the voltage cut-off to none before i can bind the esc and transmmiter?
-do i use all the 3 wires(black, red, white) that connect between the ESC and receiver?
-which esc firmware is best suit for 12th scale 4.0T motor
Serpent 966 EVO / OS MAX
lastsun is offline   Reply With Quote
Old 05-03-2010, 06:55 PM   #4041
Solara's Avatar
Trader Rating: 16 (100%+)
SP is currently working on the "Atsushi Hara" driving skills V1.0 for download in the future...(just kidding)
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-03-2010, 07:00 PM   #4042
Trader Rating: 76 (100%+)
Have a few questions. Hope someone can help.
Just received a GT 1.1 and was wondering about a manual. There isn't one on the speed passion site. Do i just use the GT 2.0 manual? I did use it for the throttle calibration.
Also the program card lit up once, i changed a value and then it went dark.
Finally would it be worth while getting the LCD programmer for this esc?
Thanks, Pete
pfindeis is offline   Reply With Quote
Old 05-03-2010, 07:30 PM   #4043
mr crum's Avatar
Thanks, Pete
i might be able to copy and post a manual i have for that esc , make sure u have a fully charged battery when programing, and you cant upgrade firmware so no reason to get a lcd programmer hope this helps
TEAM B.R. RACING
Old 05-03-2010, 07:34 PM   #4044
mr crum's Avatar
yes i always use 2s to program my 1s car i would set voltage cut off at 3.0 and yes use all 3 wires just remember not to turn the esc switch on with receiver pack hooked up it will cook instantly as far as software with a mod motor (4.0t) u should use 205g or 323a if u try to use supercharger software you will cook your motor
TEAM B.R. RACING
Old 05-03-2010, 07:36 PM   #4045
mr crum's Avatar
what software are you running?
if your using beta software you want less motor timing it just causes more heat if you use motor timing.
TEAM B.R. RACING
Old 05-03-2010, 08:37 PM   #4046
Trader Rating: 112 (100%+)
Send a message via AIM to Valentin.H
Thanks for your reply,
Yes I know it only takes a minute to change it on to off, but i was trying to see if there was possibly something wrong with the esc. I clearly just wanted to keep reverse and be able to "double tap" the brakes...if that's how the esc works then i'll just have to deal with it.
thank you guys again.
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 05-03-2010, 10:19 PM   #4047
irgo's Avatar
Originally Posted by Born2Run View Post
Very fast irgo.I sent them 2 speedos,one still under warranty and the other out of warranty and i had them repaired in my door after 12 days.They charged me only for shipping (34.00 USD with DHL).
no, it's been more than 12 days now.
since the Speed Passion product arrived in King Golden HK
and still waiting from factory at ShenZhen.
until now there is no report about it.
Quark Force
irgo is offline   Reply With Quote
Old 05-03-2010, 11:48 PM   #4048
Born2Run's Avatar
I don't understand.It's a SP or a HW product? Are you sure you sent it to the right address (4rd Floor, 3th Building, KeLunTe...) with the warranty-non warranty form they asking?
Whatever
Born2Run is offline   Reply With Quote
Old 05-04-2010, 04:21 AM   #4049
irgo's Avatar
it's a Speed Passion Product, Through Speed Passion King Golden at HK
with warranty
and they Send it to factory which is at China ShenZhen.
and it was Hobbywing Factory.
Quark Force
Old 05-04-2010, 04:48 AM   #4050
defcone's Avatar
Trader Rating: 15 (100%+)
with warranty
Are you allowed to say that?
defcone is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
