Like Tree12Likes
Old 05-02-2010, 06:49 PM   #4021
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by Tha Skinny View Post
I am runnning on a 75 x45 carpet track with a TC5 94t spur and an sp v3, what kinda motor temps do they like. I run a KO bmc and am not having the results like my novak 17.5 and suggetions would be great.
I was geared at a final of 4.09
dont know much about the ko speedo but a little more info would help.
is it slow on infield.
or slow on the straight what were your motor temps ?
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 05-02-2010, 09:54 PM   #4022
Trader Rating: 112 (100%+)
Send a message via AIM to Valentin.H
hey guys,
for some reason on my LPF 2.0, (and i never experienced this with my v1.0) if i double tapped the brakes, even with the car moving, reverse will kick in. On my 1.0, i could tap on the brakes as much as i wanted to and the reverse would not kick in unless the car was at a stop.. Many of you might be curious why i need to be able to double tap the brakes, but i do sometimes double tap the brakes as i do a lot of drifting (countersteer) which sometimes requires double tapping.
If any of you guys could help me, that'd be great. Thank you in advance!
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 05-02-2010, 10:19 PM   #4023
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by RC Guru View Post
hey guys,
Turn off reverse.
defcone is offline   Reply With Quote
Old 05-02-2010, 10:30 PM   #4024
cherry2blost's Avatar
Originally Posted by defcone View Post
Turn off reverse.
Helpful comment !!
Have you set it to forward/Reverse with Brake?
Also you could try changing the firmware to another version and then rolling it back to the one you actually want to use as this may fix any software corruptions if they have occurred, remember to setup your radio again after flashing and re flashing.
Hope this helps as the flashing lights have, certainly on the Hobbywings, been fixed by reflashing in this manner.
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 05-03-2010, 12:08 AM   #4025
Im using a ballistic 7.5 with a speed passion ESC profile 205 in an Associated B44 on an offroad track which has a loose surface with low grip
I am unsure of the gearing I require as I am having over heating problems.
I used to use a GTB and I had a 84 spur with a 20 tooth pinion, I was able to get a 8 min run with the motor just getting to 65 Deg C.
With the new ESC I get two laps and the motor is now up to 70 Deg C and im not prepared to risk getting it any hotter.
Can anyone Help with ESC settings and Gearing required
kiwi79a is offline   Reply With Quote
Old 05-03-2010, 07:11 AM   #4026
Trader Rating: 8 (90%+)
My Temps were still pretty low 113deg. I did end up getting home and plugging in my ESC to my laptop and realized that my profile was set for punch and I had taken away alot of the RPM.
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris Totcky@facebook.com
Tha Skinny is offline   Reply With Quote
Old 05-03-2010, 07:40 AM   #4027
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by tns View Post
Hi solara and sosidge
Thanks for the feedback! So I guess at the end of the day, yes, more power does make the car more difficult to drive, particularly if it is a shaft car due to torque steer, but this can be overcome with good setup and SKILLZ - more practice time required at the track then!
Cheers!
Torque steer does not bothers me when I was running Pro 4...remember the TC3 period? That was the car to get back then.....untill the BELT cars developed better then the shaft, then the shaft faded away.
I gave up shaft cause their drive train fail very offen especially when you use alot of drag braking and braking...also not a good idea to run at outdoor with little rocks. I have yet to have 1 belt car drive train failed on me.....not even 1/2 time...and I don't replace belt or pulleys unless they have extensive wear on them.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-03-2010, 07:44 AM   #4028
Solara's Avatar
Originally Posted by chrissyred View Post
just checked my card, i made a mistake it was at 7.
what setting do u think #4 should be?
the advice from the other thread only covers #9 onwards.
it is very good advice though as it really explains how each of the functions add up. i now understand fully function #15.
im off to the track soon so il let u know how i get on, cant wait to see my lap times, just please dont rain!!
That is a throttle profile...I would say using stock motor, should be around 7, 8 or 9....if using MOD motor, may be 5, 6 or 7....I don't think using 4 is necessary.
Also, using 9 (most aggressive) does not get me faster lap time...just add more heat onto the motor. And it is a personal preference, may be you find it 0.1 faster then 7 or 8...but all my setup are between 7 or 8...7 for small tight track and 8 for bigger more open track.
Old 05-03-2010, 07:49 AM   #4029
Solara's Avatar
I know SP V3 type motor gear TALLER then Novak SS, at least back when I was using my SP speedo without software, I gear taller then other motors.
Try 3.7....and I know our team member can gear the V3 to mid 2 and low 3 (ask Charles) but try 3.7 and keep gearing up 1 tooth at a time...
Yes...you should send in your KO for the filmware update, KO does have a TURBO system awhile ago.
Old 05-03-2010, 07:50 AM   #4030
skypilot's Avatar
Trader Rating: 14 (100%+)
drrs to 2-3 timing 11.25 or lower
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 05-03-2010, 10:38 AM   #4031
Originally Posted by smilekt View Post
function 4# use parameter 6 still have supercharger ?
I saw the same. For me it's a bug which need to be corrected by SP !
chrispys is offline   Reply With Quote
Old 05-03-2010, 11:46 AM   #4032
skypilot's Avatar
can we talk about the "new" SP software yet? cause I really really wanna post some actual race results from yesterday.
Old 05-03-2010, 12:11 PM   #4033
irgo's Avatar
Flawless, i saw the Hobbywing item #15 for the 100422 Stock software
they have great RPM/Degree Explanation,
that would looks like Supercharge for real.
The most interesting is that
Item #13
the range is between 3000-15000 rpm with 1500rpm steps.
this will result more torque and max speed possibilities
but rpm can't be defined it's value yet ? 1500rpm is too far.
unlike Speed Passion Supercharge the range can be 1000rpm.
i think the best choice is to have user defined it's own value.
so it's really depend on delay and throttle activated.
anyway i was now waiting for Speed Passion After Sales Services test
since no doubt for Speed Passion and Hobbywing Technology yet right now.
Since King Golden of Speed Passion will still have to do the Sales and Services of any product send back to China, that would be in ShenZhen.
and that would be Hobbywing.
The lasting important about this product is After Sales Services that i am interested in. So now, i'm waiting, for next Speed Passion progress.
Let's see how fast hobbywing will do After Sales Services.
Quark Force
irgo is offline   Reply With Quote
Old 05-03-2010, 12:34 PM   #4034
Born2Run's Avatar
Very fast irgo.I sent them 2 speedos,one still under warranty and the other out of warranty and i had them repaired in my door after 12 days.They charged me only for shipping (34.00 USD with DHL).
Whatever
Born2Run is offline   Reply With Quote
Old 05-03-2010, 12:47 PM   #4035
Turn off reverse.
I would if i used the ESC strictly for racing..but i don't
Originally Posted by cherry2blost View Post
Helpful comment !!
yes i have set it to foward/reverse with brake.. but alright, that seems like an option, but i guess i will have to pickup a programmer to flash the firmware Has anyone else experienced the reverse kicking in after double tapping the brakes while the car is still moving forward? i'd really like to know..
thanks guys.
-valentin
www.csjunkies.com
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
