Like Tree12Likes
Old 04-19-2010, 06:02 PM   #3856
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Originally Posted by cherry2blost View Post
Thank you for your explanation Charlie_b.
NP, anytime.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 04-19-2010, 07:56 PM   #3857
kiwidave72's Avatar
Send a message via MSN to kiwidave72
Originally Posted by charlie_b View Post
NP, anytime.
Yes thanks.
Im willing to wait for the new software, now that we are starting to head into winter, and there isnt much indoor racing around here. so ill be using 230 for now, and will work on my settings.
kiwidave72 is offline   Reply With Quote
Old 04-19-2010, 08:30 PM   #3858
defcone's Avatar
Trader Rating: 15 (100%+)
Charlie when you say you don't go above 3 on SC boost settings you mean you don't go below it? I thought that setting made the motor hotter as you went down?
defcone is offline   Reply With Quote
Old 04-19-2010, 08:46 PM   #3859
Matt 10's Avatar
Shawn, when will the single cell battery be released??????????
CEFX, BSR Racing Tires, Team OHP
Matt 10 is offline   Reply With Quote
Old 04-20-2010, 03:13 AM   #3860
xrayal's Avatar
Charlie, thank you very much. It makes a lot more sense now. I'll be putting it into practise this Friday night. Thanks dude.
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
xrayal is offline   Reply With Quote
Old 04-20-2010, 04:13 AM   #3861
Redwood's Avatar
Thanks for the info Charlie,
I was under the impression that setting 15. Punch, was nothing to do with supercharger, and that it just made your car more punchy before the supercharger kicked in, presumably by using lower timing. My tests seemed to confirm this, but maybe I was just seeing what I wanted to see.
Can you elaborate on what you think 15 does?
Cheers
Neal
Redwood is offline   Reply With Quote
Old 04-20-2010, 11:11 AM   #3862
Super Moderator
charlie_b's Avatar
Cheers
Neal
Punch is #4 or DDRS. From what i have observed, if i set #15 at 1 on the track where there is a sweeper then a straight, the supercharger kicks in on the sweeper before the straight. When I set the value to 3, it turned on about 15 feet after the beginning of the straight.
When you bench test your car, you will notice 2 steps of boost type of reactions. 1 for mid and one for full throttle. I think this is the dynamic timing that was mentioned way early into the supercharger program. Because this seems to be lower in timing/boost, i can only assume that this is the punch that helps get the motor up to speed onto the high rpm/low torque settings.
Since we we still do not have a clear definition of the settings, we can only go by what we observe. Please be patient everyone, with us only in the US testing for the higher turn motors(17.5/13.5), we are limited to those who get to go out to the track during the week or test before a race on weekends. THere has been great improvements since the 218 so i know we are in the right direction. Ultimately we want to get the same Smooth curve Speedpassion is known for, with the ballistic power to back it up.
Keep posting your findings. SP is listening.
Old 04-20-2010, 11:40 AM   #3863
Redwood's Avatar
Thanks Charlie, I appreciate that all this stuff is still being worked out, hence why it's called beta software.
I didn't actually get to test the software this weekend as every time I tried to race with the supercharger software, the speedo went into sensorless mode and lost all punch and top speed, and the motor got hot to boot.
I shimmed the rotor closer to the sensor, but only had one qualifier left so switched back to the old 107 software, car was excellent actually but that was 10.5 on a super small track.
Has anyone else experienced a switch to sensorless mode, I was running a GT 2.0 pro with 230 supercharger software and a SP ultra sportsman 10.5. My friend also had the exact same issue with the same type of motor and the speedo we shall not mention in this thread.
Regards
Neal
Old 04-20-2010, 11:49 AM   #3864
Super Moderator
charlie_b's Avatar
Regards
Neal
Dude..are we running the same car??
I had that issue too. When i test, it is usually 10 laps at a time, then record. No issues at 10 laps. In actual 7 minute racing, mine went into the same mode. WHat Shawn suggested is either disable temp control(do at your own risk) or lower your lipo cut off. I have not gotten a chance to see if this works, but will try to test that either tonight or tomorrow night.
Old 04-20-2010, 12:33 PM   #3865
Joel Lagace's Avatar
Originally Posted by RTR canada View Post
I really wanted to win a trophy this weekends Tamiya race so i switched to Tekin and took first place and pulling 2 more laps than with the Speed passion! All this waiting i hope they make you guyz really happy? I did use the Sp motor thou and seemed good.
Common.. 2 laps eh? your my hero
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 04-20-2010, 12:40 PM   #3866
How is it possible to tell when its gone into sensorless mode? A while ago I had an old motor run fast for the first 3 mins and then as it heated up it would slow down (to 540 speeds), and it turned out one of the windings inside the motor was starting to short when it got hot.
If I let it cool down it would be fine for about a lap and then the same thing would happen.
Eventually it failed altogether.
Mike
ixlr8nz is offline   Reply With Quote
Old 04-20-2010, 01:08 PM   #3867
kiwidave72's Avatar
when i was out on sunday that car was fine other then in one race the car either went into sensor less mode or the sensor cable came loose.
At the end of the race i had a look at the cable and pushed it in hoping that doing so would solve my problem. took the car straight out on to the track again it was fine.
David
Old 04-20-2010, 01:20 PM   #3868
When i was testing last week, i also ran into the problem of the motor going into the sensorless mode. it usually happened after i tapped a wall or run over a corner dot. i fixed the problem by blowing out the tire dust with the compressor, and changing the sensor wire. works fine now.
gdcopbdcop is offline   Reply With Quote
Old 04-20-2010, 04:20 PM   #3869
skypilot's Avatar
Trader Rating: 14 (100%+)
no problem with fade, still trying various settings, once i had to rebind the esc, 5 times before it would take the new settings, (it was about walking speed before the 5th try)
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 04-20-2010, 04:26 PM   #3870
Super Moderator
charlie_b's Avatar
I do mean i do not go above 3 because there is too much delay or lack of Punch. I have gone to 1 and gave me the punch i need and still had no overheating issues. THis might change with the new settings im gonna try.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
