Like Tree3Likes
Old 04-06-2010, 06:35 PM   #3706
Smile
keep the faith guys, they are working on new software that will make the SP
controllers very,very fast. as soon as it has been tested and approved it will be sent out.
rich
gdcopbdcop is offline   Reply With Quote
Old 04-06-2010, 07:33 PM   #3707
Boz
Trader Rating: 23 (100%+)
Originally Posted by charlie_b View Post
230/231 was released because it was deemed 'safe' for the user. 318 is still being tested by some of the drivers. Just because there is a newer version of a software doesn't mean it is safe for the end user...if you have read our previous posts, some of us have blown 3-4 motors testing new software. Im sure you wouldn't want to do that now would you?
When you say the motor blows, what actually happens to the motor. I've raced electric (brush) from 84-95, then nitro from 95-2009. I know what a nitro engine does when it blows up, but i'm yet to see a brushless let go.
Chris Bozich
Xray XB4 and XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 04-06-2010, 08:13 PM   #3708
MikeXray's Avatar
Trader Rating: 72 (100%+)
The fun way is to blow up the rotor, but usually if you overheat the coils they weld themselves together and short out.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-06-2010, 09:07 PM   #3709
ok me confused. here. i got the program to down load. but were do you check for updates. at all.
i have the lcd programer and the cable. hook up to my laptop and
can't figure out were the updates are me confused
A
cyrrus is offline   Reply With Quote
Old 04-06-2010, 10:19 PM   #3710
defcone's Avatar
Trader Rating: 15 (100%+)
A Mass smoke ball emits from underneath your bodyshell, you can tell your motor is about to cook when you have excessive drag brake from the motor if you didn't have any dragbrake set into the speedie. That's what happened to mine.
defcone is offline   Reply With Quote
Old 04-07-2010, 12:12 AM   #3711
adri-13's Avatar
Originally Posted by altreyx View Post
wow... i use fdr 7,1 DMTS at 5 (15) and DRRS at 6 on a circuit with a 25m of stright and rest is medium speed (at the end is a medium tech track).
But i never had the motor over 55C (SP v3 10,5) and the esc over 22C
For me you are using a little bit too much AMTS value...i suggest you to start with something more around at 15 and reduce a little bit your FDR (may be start at about 7,0 but depend on your track size)
Forgot to say i use the endbell timing over the motor a little bit less than +10 (i can say at about +8)
Bye
ok . I have tested the +10 timing on the motor but the temperature is the same.
PETITrc driver
www.PETITRC.com
http://rcracereportsigm-racing.blogspot.com/
adri-13 is offline   Reply With Quote
Old 04-07-2010, 12:37 AM   #3712
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Originally Posted by defcone View Post
you can tell your motor is about to cook when you have excessive drag brake from the motor if you didn't have any dragbrake set into the speedie..
Looks like i cooked another motor then. I have drag brake from hell right now.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 04-07-2010, 04:52 AM   #3713
Try the beta supercharger softwares, you'll have more high speed and less motor temp.
If you're in Monteux on sunday then I could update the software in your speedo.
chrispys is offline   Reply With Quote
Old 04-07-2010, 05:10 AM   #3714
adri-13's Avatar
yes i was been in Monteux on sunday becanse it's my league . Why not!! thanks a lot
What's your value on the supercharger software??
Bye
PETITrc driver
www.PETITRC.com
Old 04-07-2010, 10:25 AM   #3715
Hebiki's Avatar
Trader Rating: 26 (100%+)
yup! been there done that.... i went to temp my motor.. my temp gun said "ERR".
1 min later i temped it again. the endbell was at 240deg F. the internals melted together and i couldnt turn the rotor.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-07-2010, 02:10 PM   #3716
F-1
Hello! Why some of Top Team Drivers remove the gold contacts from ESC, and and solder the wires like on LRP Sphere?
F-1 is offline   Reply With Quote
Old 04-07-2010, 02:42 PM   #3717
2 reasons come to mind:
More efficient/ less voltage drop as there are less solder joints
Less chance of a bad joint or if they get hot unsoldering and coming off mid race.
Its hard to see why anyone uses them actually.
Mike
ixlr8nz is offline   Reply With Quote
Old 04-07-2010, 03:01 PM   #3718
F-1
And how they solder wire in ESC? I can see what the holes it's to small, and I cant insert the wire to the hole...
Old 04-07-2010, 05:00 PM   #3719
You probably just need to clean out all the old solder so the holes are back to the original size.
Mike
Old 04-07-2010, 07:24 PM   #3720
mlight13's Avatar
Trader Rating: 40 (100%+)
I will eventually play around with the Supercharger 230/231 software, but what is the best non-supercharger firmware for a 17.5 Touring Car? Thanks...
Mark
mlight13 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
