Like Tree8Likes
Old 04-02-2010, 07:33 AM   #3646
Originally Posted by eceer View Post
Hi all,
I have finally been able to get to the track and have some sort of results worth commenting about, however I'm not sure I have ended up with a result that was much better than the 107 software I was running before.
So rather than spout off I'm going to put up my settings and see if I'm doing anything wrong.
Car: Cyclone TC
Motor: SP V3 17.5
ESC Settings:
  • 4: 7
  • 9: 6
  • 12: 4
  • 13: 2
  • 14: 4
  • 15: 6
FDR: 4.38 = (69/34)x2.16
The track: http://www.aerccc.org.au/content/ind...id=54&Itemid=2
I'm thinking that I have done something wrong with the upgrade of the s/w as I was expecting the FDR to be up around the 6 mark judging on some of the earlier posts and there doesn't appear to be much turbo kick. When I first started testing the super charger seemed to start to come in towards the end of the straight and didn't seem to matter what I adjusted nothing changed. On earlier posts it was suggested hitting the upgrade button more than once. Well I clicked four times just to make so that can't be it... could it?
Thanks in advance
Reece
For mine, my supercharger does not even engage until setting 4 is increased to 8 and setting 9 is reduced to 4 and below.
HCHL is offline   Reply With Quote
Old 04-02-2010, 07:47 AM   #3647
Tech Legend
Cain's Avatar
Trader Rating: 223 (100%+)
Anyone know if you can use the older 1.1 card with the GT2.0s and access the new features?
< RC10B6D | Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 04-02-2010, 08:27 AM   #3648
Trader Rating: 14 (100%+)
So what do i do with the dead LPF i have, send it overseas.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.0 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 04-02-2010, 09:24 AM   #3649
abailey21's Avatar
Trader Rating: 36 (100%+)
Try this, give it a good read, it "should" answer your question...
http://www.speedpassion.net/us/contact.asp
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 04-02-2010, 11:47 AM   #3650
Hi all,
Car: Cyclone TC
Motor: SP V3 17.5
ESC Settings:
  • 4: 7
  • 9: 6
  • 12: 4
  • 13: 2
  • 14: 4
  • 15: 6
Thanks in advance
Reece
Firstly what temp is your motor? If its cool and there seems to be no fade during the race try the following:
Try your motor timing at +10. This certainly made my car faster (sp v3 13.5) I think you have the right gear ratio. I am currently running 4.0:1 on a huge track. Also try the supercharger value 12 at a higher number like 7. There will be a more noticeable difference then, but for sure it will get hotter.
If the temp does go up too high after trying the timing changes maybe you could use a smaller pinion? Its hard to tell exactly how fast your track is without seeing it in person I guess.
Mike
ixlr8nz is offline   Reply With Quote
Old 04-02-2010, 02:03 PM   #3651
eceer's Avatar
Mike
Thanks Mike,
We tried some settings similar to the ones you have mentioned, I think a lad was helping me sort it out, and we got a temp up around 95C. Pulling back the settings towards the cooler range brought the temp back down to 70C. To be sure I will try the settings you have mentioned and see how we get on.
Thanks Reece
☞ Adelaide RC Team driver ☜
☞ Switchmedia ☜
☞ They're not toy cars, they are fine examples of engineering. When driven correctly are a joy to behold. ☜
eceer is offline   Reply With Quote
Old 04-02-2010, 07:36 PM   #3652
Boz
Trader Rating: 23 (100%+)
Originally Posted by abailey21 View Post
I'm running the 205G
Here's my setup...
Code:
http://rapidshare.com/files/370889023/B44_ESC_Setup.pdf
In your setup Adam, you have the the timing setting as 'stock'. That is stock?
I find it interest that drivers are displaying there setup, but most of the time forget to name the brand of motor and the timing on the motor can. Are these not an important part of obtaining the best from the esc?
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 04-03-2010, 03:58 AM   #3653
V12
V12's Avatar
Regarding the Speedpassion V 3.0 13.5T motor what mechanical timing is the motor using when adjusted to the 0 position? 30?
When do you use the additional 10 position?
V12 is offline   Reply With Quote
Old 04-03-2010, 05:52 AM   #3654
Does anybody have an empty case for a speed passion esc? I broke the case taking it out of the car and need a new one.
chrisw is offline   Reply With Quote
Old 04-03-2010, 10:39 AM   #3655
xrayal's Avatar
what do you find are the main (if any) differences between 230 and 231. running 13.5 on a small indoor carpet, high traction. most of the tekin boys gear at around 8-8.5 fdr................
tamiya 416x
hobbywing
spektrum dx3r
mardave
xrayal is offline   Reply With Quote
Old 04-03-2010, 12:39 PM   #3656
Hi,
Anyone know which is the default software for the 2.1 speedo? The 231 is a bit complicated for me and I'd like to reinstall the default version, but I don't remember which was that.
bviktor is offline   Reply With Quote
Old 04-03-2010, 01:32 PM   #3657
razzor's Avatar
Originally Posted by bviktor View Post
Hi,
110 was mentioned as the std firmware on the 2.1
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 04-03-2010, 01:55 PM   #3658
Actually soldered everything back up on my lpf and it will run but as soon as there is a significant load the motor locks up. Turn it off and on it fires up again. Could this be a motor problem?
Old 04-03-2010, 04:34 PM   #3659
Default Timing Curves etc
Please check out the following graphs I have attached and lets just review a couple of things.
The first graph is of how I understand the supercharger software works in the simplist terms.
The second graph is of how I think the software could work when using a system very similar to the one that KO used on their VFS-1 for frequency control a few years ago. Again in the simplist terms.
Could this work?
I feel the Supercharger software or similar software from other brands is like having a two speed gearbox for example. Imagine if you could have software that makes it run similar to having a Constant Velocity Transmission.
Best Regards
Mike
Old 04-03-2010, 05:26 PM   #3660
RTR canada's Avatar
im running a 7.7 FDR and i have tried all gears and modes on the turbo software and at this point there is no way i can keep up with the Tekin. The infield power is not so bad but when you get on the straits they make me look dog slow. Im running t2009 and Sp pro esc and 3.0. If anyone has any ideas other than getting a Tekin please let me know. Thanks
RTR canada is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
