The Speed Passion Thread
#3633
hi , after looking through this thread for a hour and with no joy i thought id ask direct
Just got a LCD programmer for my SP v2.0 LPF and ive put 110 software on successfully , Im running a 13.5t V3.0 SP motor on a small carpet track but im unsure on a FDR for this and also ESC settings , I dont wanna go blowing anything up on my first attempt at this
Before updating i use to run a FDR of anywhere between 5.5 - 6.0 at this track if thats any help to you guys ?
#3634
Super Moderator
#3637
Im planning to put on the 5.5t sensorless motor on my 4wd buggy. What fdr would you recommend for it and which firmware should i use for my setup? Mite be running it on TRF511 or LRP Blast 10
#3638
built in timming
with the speed passion 13.5 ultrasportsman, does it come with timming advance buit in? (not the latest one but the black can with purple swirls)
#3641
Hi all,
I have finally been able to get to the track and have some sort of results worth commenting about, however I'm not sure I have ended up with a result that was much better than the 107 software I was running before.
So rather than spout off I'm going to put up my settings and see if I'm doing anything wrong.
Car: Cyclone TC
Motor: SP V3 17.5
ESC Settings:
The track: http://www.aerccc.org.au/content/ind...id=54&Itemid=2
I'm thinking that I have done something wrong with the upgrade of the s/w as I was expecting the FDR to be up around the 6 mark judging on some of the earlier posts and there doesn't appear to be much turbo kick. When I first started testing the super charger seemed to start to come in towards the end of the straight and didn't seem to matter what I adjusted nothing changed. On earlier posts it was suggested hitting the upgrade button more than once. Well I clicked four times just to make so that can't be it... could it?
Thanks in advance
Reece
Car: Cyclone TC
Motor: SP V3 17.5
ESC Settings:
- 4: 7
- 9: 6
- 12: 4
- 13: 2
- 14: 4
- 15: 6
Thanks in advance
Reece
#3642
#3643
#3645
Hello,
i was Drive indoor for testing the Beta Software.
Car: Xray T3
Tires: Sorex 28r
fdr: 5.0
Engine: Corally 17.5T with Sensor
I drive with 231, Torque and Speed are Top, after 1 min or 1.30 min the Torque are OK but the Speed is away. It feels that i drive without a sensor cable. I can Drive with this Problem and after 10 minutes the Engine have 55 degree.
Then i make a break but change nothing at the ESC, than i drive my next Batterie, the same Problem after the Time.
Before i Drive my First Batterie i have change the Sensor Cable and play the sofware again on the ESC. The Problem there is also on 230.
I know not what may, i believe i go back to 107 If no one can help me. The Speed is Top but 1 min or 1 min 30 sec are to little for races over 7 minutes.
Car: Xray T3
Tires: Sorex 28r
fdr: 5.0
