Like Tree3Likes
Old 03-23-2010, 12:11 PM   #3451
Hi,
I have just bought a SP 2.1 Prostock speedo. Can anyone help in the adjustments? I am running SP Competition 3.0 13,5T in a quite big carpet track.
DRRS and DMTS settings?
bviktor is offline   Reply With Quote
Old 03-23-2010, 02:15 PM   #3452
Originally Posted by san. View Post
I'm bit a confused and having problems finding a balance with the beta software.
Need some help understanding the difference between #4 DRRS (Start Mode) and #15 Supercharger Punch. And how they affect and/or compliment each other? Similarly, #9 AMTS (Timing) and #12 Supercharger Boost Level.
Thx.
Did this ever get cleared up? I have been following the thread closely but haven't seen an answer yet. I really want to join the turbo party, but not blow up too many motors.
Cheers
Ben
Ps. For big boys cars doesn't a supercharger operate throughout the full rev range as it is connected directly to the fan belt, where a turbo charger kicks in at a higher RPM as the turbine is spun from the hot exhaust gases. I would have thought that the 107 software is more like a supercharger and this new software more like the VW supercharged-turbo charged combination engines ( http://www.volkswagen.co.uk/technology/tsi ) SP V2.0 TSi My pedantic side coming out
Rocking Donkey is offline   Reply With Quote
Old 03-23-2010, 03:39 PM   #3453
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Cheers
Ben
To clarify:
AMTS and DDRS is what the 1st Generation SP esc's had. Basicaly Single stage ESC.
Now, with Levels 12-15, it adds a second stage kinda like a 2nd gear with a second set of adjustments.
With that being said, AMTS and DDRS are setting for the fist part of the ESC, then when the Supercharger kicks in, the next set of settings kick in.
So yes, they do compliment each other, to a point. WHen you have too much high timing on AMTS, the Supercharger doesn't seems to like it for some reason so in order to have a better"2nd gear", we have found having lower timing gives stronger boost.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 03-23-2010, 03:42 PM   #3454
KWT-NITRO's Avatar
Hi guys,
if i wanna start racing 1/12 scale, what would be my best choise from Speed Passion for an ESC and a 13.5T BL motor??
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 03-23-2010, 04:12 PM   #3455
Hello,
I am from Germany and we have the TCM meeting here next weekend.
There we use the LRP X12 13,5T for Stock Racing.
the track is a big indoor track,long straight...
Has anyone tested the X12 13,5T with the 230Stock Software?
Which motorttiming do you use?
and which settings for the speedo?
which FDR?
my speedo ist the GT 2.0 Pro.
thanks for reply!
Blade7 is offline   Reply With Quote
Old 03-23-2010, 05:03 PM   #3456
What would you guys recommend for sp 230 firmware turbo settings,
our track size is 55 x 33meters (around 50 meters straight), aspalt temp 55-60C, ambient temp 32C, sp 11.5T ver 3.0 w/ motor timing +10, fdr 4.9
also does the 5000mah 50C battery add more punch compare to 5000mah 40C batt?
TIA
leonardiw is offline   Reply With Quote
Old 03-23-2010, 11:14 PM   #3457
veecee's Avatar
Trader Rating: 34 (100%+)
Just going through the thread to get ready for the upgrade... Shawn, can you clarify this post please?
Originally Posted by Shawn Palmer View Post
......Starting from scratch:
1) Start out with a slow FDR (7.0) gear ratio
2) Start with #14 off and #15 at value 8
3) For 13.5 start with #12 at stage 4, for 17.5 at stage 6......
I'm not sure on item 2 as #15 only goes to value 6. Can you confirm if you meant that to be a different setting or a different value? Thanks!
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 03-23-2010, 11:18 PM   #3458
razzor's Avatar
Originally Posted by Blade7 View Post
Hello,
which FDR?
thanks for reply!
a lot of feedback with the X12 motors dont seem to be good.
This past weekend a buddy tried his and it just wasnt performing and made more heat.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-23-2010, 11:30 PM   #3459
Skitee's Avatar
I would start with the 4 dot timing insert which is -10 since this motor has so much timing advance built in from the factory, this will help to ensure that you're not over timing things. Then slowly work up on the supercharger punch and supercharger delay settings, if you get it going ok like that then move to a -5 insert on the motor.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 03-24-2010, 12:10 AM   #3460
SlideMasteR's Avatar
Default Supercharger Firmware
Hi guys just thought I would share my findings with you to help the guys get a starting point with the new firmware i ran (231) on GT 2.0 Pro in a Mi4LP with a SP 13.5 Ultra sportsman Series motor, with 5200 Lipo
Our track is a asphalt, outdoor, with a +-45 meter straight, fairly flowing & technical , we setup a practice day with the amb timing system for accurate results,
Day 1 - I started out at the recomended 7.0 FDR and we run foam tires here in SA so the roll out was about the 26 mm with 60 mm tires, which I initailly thought to be way too low, but gave it a few runs to get used to the new feel of the car and setting up the delays etc for the straight and wow !!! very happy with what the car is capable of ! I tried going up in gearing about 6.0 FDR and the car was slower, flat on the infield and boosted too late on the straight, so i dropped to lower gearing 7.8 FDR and re-tested and the car was better infield but lacked the ooopmh the car had in its first run ... Skittee (who runs a Photon and Tekin ) were pushing each others times down all day we both smashed the tracks lap records by almost 3 tenths so we were both very happy with the days testing.
Day 2 - I setup the car back to the 7 FDR (which for our track was spot on)and 59mm tires and started experimenting with the punch and total boost settings, and found that I had to almost max the punch and Boost levels to get really good rip corner to corner, i even tried the 230 firmware (but ran too hot for my liking and no faster than 231) so i re-loaded the 231 and ended up with the following:
12) value 9 (Max)
13) value 2
14) value 5
15) value 2
after 5 min run my motor temped @ 68 celcius which is awesome (cooler than 110) and on day 2 I knocked another tenth off the lap record
so in summary SP have definatly found the speed to keep up and run quicker than the tekins and am eagerly awaiting the new revision which Adam/Shawn say's improves the mid range punch ! but very happy with the progress so far guys tx so much !!!
just hoping we can get a beta copy of the new stuff so that we here is SA can test and use at the upcomming nationals mid april ! (hint hint )
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 03-24-2010, 12:24 AM   #3461
Would agree there sounds like a over timmed issue
Old 03-24-2010, 01:18 AM   #3462
hi,
the same things happend to me last weekend, no good punch out of the cornerwith the 230 stock.
there was a guy with a speedpassion 3.0 13,5T and he uses the 107 stock and was faster than me.
so i tried the 107 stock with the X12 and it was much better out of corner,but with a FDR of 7,8 . but the LRP speedo driver are faster the first 10 meters on the straight, so i need more punch (supercharger) to have the same speed.
I think with X12 we need a low FDR ,because the higher FDR only makes more temp and no good good punch out of the corner.
Old 03-24-2010, 01:19 AM   #3463
has anyone got a good set up for a medium size carpet track , with fast straights and twisty bits , im going to use a novak ss 10.5t with the sp lpf esc ...
cheers for your help , im trying to get it set up tonight ...
shaun207 is offline   Reply With Quote
Old 03-24-2010, 01:29 AM   #3464
defcone's Avatar
Trader Rating: 15 (100%+)
Anyone ran a lrp x12 5.5t with the gt 2.0 pro? Is it better to run more esc timing than motor timing? For a track with a 50m straight?
defcone is offline   Reply With Quote
Old 03-24-2010, 03:50 AM   #3465
CraigM's Avatar
Where do you race that has a 50m straight keef?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
