Like Tree46Likes
Old 07-09-2009, 11:14 AM   #331
Stusdal's Avatar
I have the SP GT 2.0 Pro Carbon edition. Ive set the cut off to 2.8 Volts. But it does not cut as I expected. It droops drasticly in power but does not stop completely, Is this correct?
The same happend when I set i to 3.0 Volts
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 07-09-2009, 11:32 AM   #332
razzor's Avatar
The 2.0 does not have a hard cut off but a soft, that allows you to drive the car slowly.
Prefer it to a hard cut helps you get off the track with out worrying of being hit by traffic.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-09-2009, 11:36 AM   #333
Stusdal's Avatar
Thanks! Thats a clever feature
Old 07-09-2009, 07:20 PM   #334
irgo's Avatar
Default speedpassion GT2.0Pro BRUSHED MOTOR ? Upgradeable
Originally Posted by irgo View Post
Above is The BLUE STAR EDITION
I mention Below Speedpassion
v2.0 PRO for 800A
v2.0 LPF for 440A
Both came from Speedpassion.
But the most important question is this,
Speedpassion had 4 latest version on GT2.0
Speedpassion GT 2.0 PRO Carbon Black Edition
Speedpassion GT 2.0 LPF Carbon Black Edition
Speedpassion GT 2.0 PRO Blue Star Edition
Speedpassion GT 2.0 LPF Blue Star Edition
at Speedpassion GT 1 PRO Card it has "Motor Type" to select Motor Brushed,
where at Speedpassion GT2 had no "Motor Type" to select Motor Brushed.
Which Speed passion GT 2.0 can Use Brushed Motor ?
and Shawn, Be Explanative, because Brushed Motor had good DragBrake
My Question is :
Originally Posted by danjoy25 View Post
Nope, only sensored and sensorless motors now.
Originally Posted by abailey21 View Post
No brushed motors on the GT 2.0's
if you see that at Program Card v2.0 there is no "Motor Type"
that was the pocket sized programming box.
SO there is another way to set or updates speedpassion GT2.0 by this :
"Built in ESC enhancement feature allows you to update to our latest software and future new developments (USB software upgrade kit “Professional LCD program unit PN#SPLCD01” are sold separately," "
See that that's means GT2.0 can be Upgraded with LCD
Here's The Manual of GT2.0
See The manual at page 7 on
2. Programmable Values
2.10. Motor Type: Select brushless or brushed motor according to the motor in your car. WARNING: You must set this programmable item correctly according to the wiring method you are using, and BEFORE applying power to the ESC with the new wiring arrangement.
www.racing-cars.com/images/GT2_LPF_Manual.pdf 2MB
And there is also other way to Apply your GT2.0 "Motor Type" with PC
through Downloadable Software USB Link from Speed passion.
on "Advanced" Tab.
See my Attachment.
There is also Database on USB Link Software, at
"Software" Tab
there is UPGRADE Button, wich i believe it's a firmware for car ESC
This way We might use firmware from older version or GT1
Software version : v1.0_HW_xxx
Choice version : v1.00_HW_xxx
See my Attachment.
This Could allow us to Select "Motor type" to use Brushed Motor?
Quark Force
irgo is offline   Reply With Quote
Old 07-10-2009, 05:34 AM   #335
abailey21's Avatar
Trader Rating: 36 (100%+)
on "Advanced" Tab.
See my Attachment.
"Software" Tab
See my Attachment.
No, the ESC will NOT run brushed motors.
If you need to run brushed motors I would suggest buying a brushed motor ESC like the Tekin FX1, or LRP QC3.
Or are you just trolling our thread trying to help by posting all our specs?
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 07-10-2009, 07:41 AM   #336
irgo's Avatar
Hm... Wonder why don't you suggest me with Tekin RX8.
which allow us to use Brushless/Brushed
like Speedpassion GT1.1 Brushless/Brushed able
why less option on GT2.0 ESC, ?
i need an explanative Answers for GT2.0 that reasonable
isn't this thread work's for ?
Quark Force
Old 07-10-2009, 08:21 AM   #337
abailey21's Avatar
Well the Tekin RX8 is made for 8th scale, not 10th, the Tekin FX1 is specifically made for brushed motors, not brushless.
The GT 1.1 will run brushed or brushless
and the 2.0 is specifically designed for ONLY brushless, no brushed.
Here's an explanation, 99.9% of R/C racers that run a "Brushless ESC" only use "brushless" motors. Only a person making that transition from brushed to brushless will use a "Brushless ESC" for brushed motor use. After a short period of time they will make the full transition to brushless motors. so there is no need for them to use the brushed motor functionality of the ESC any longer. We decided in the design process of the GT 2.0 to only offer brushless compatibility after watching what racers used and large races around the world, less than 5% of racers used brushed motors in the back half of 2008 and the beginning of 2009. So the decision was made to only offer brushless on the new ESC.
K.C.C.O.
Old 07-10-2009, 05:50 PM   #338
irgo's Avatar
Thank's for the explanation.
Speedpassion GT1.1 had weight 39g without wires, but
Speedpassion GT2.0 had weight 60-65g
isn't this means GT2.0 have add more component's or heavier component's ?
if only 5% Brushed motor user was the reason for the GT2.0
What is the differences Between Speedpassion GT2.0 Black Carbon Edition with Speedpassion GT2.0 Blue Star Edition rather than their appearance ?
Quark Force
Old 07-11-2009, 01:47 AM   #339
dameetz's Avatar
They are both the same thing but I like the blue star better coz I drive a Tamiya which kind of add a bit of bling factor to it.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 07-11-2009, 06:22 AM   #340
abailey21's Avatar
The only difference is the color
K.C.C.O.
Old 07-11-2009, 10:06 AM   #341
TeckLancer's Avatar
Trader Rating: 16 (100%+)
Originally Posted by TeckLancer View Post
would this esc be good for 17.5 stock racing compared to the gt 2.0?
anyone ?
Eric Arellano
TC5,RC18-b,PRO4,FS,EIGHT-E 2.0,TLT,TF-5,Nitro MT
Panther tires, Speedtech r/c, Murfdogg Motorworks
check oout my forsale thread http://www.rctech.net/forum/r-c-items-sale-trade/401576-wts-b44-b4-losi-8e-hpi-nitro-mt-few-lipos.html
TeckLancer is offline   Reply With Quote
Old 07-11-2009, 12:02 PM   #342
abailey21's Avatar
anyone ?
I asked you "Compared to what?"
Your questions asks if "insert anything here" would be good for stock racing compared to the GT 2.0.
The answer is; what are you comparing it to?
K.C.C.O.
Old 07-11-2009, 07:14 PM   #343
irgo's Avatar
Default Speedpassion GT 2.0 Program Card
So, Speedpassion 4 latest version on GT2.0
Is the same and the diffrences is just between LPF and PRO for GT 2.0.
Could Speedpassion GT1.1 pocket sized programming box/card work's on Speedpassion GT2.0 ESC ?
Quark Force
Old 07-13-2009, 04:34 AM   #344
bluephi1914's Avatar
Trader Rating: 34 (100%+)
that sounds right.. and I dont thnk that you can use the same programing box for the 1.1 versus the 2.0 ESC's or at least i wouldnt want to.
Mr. 17.5 's Rides ----> T3 EU / T2 008 EU (Vintage)
** NEXUSRACING.COM **
** Team Xray - Team Novak - Proline - Sorex - KO Propo - Team Trinity **
bluephi1914 is offline   Reply With Quote
Old 07-13-2009, 07:31 AM   #345
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Questions?? Braking
Hi,
(1) The TEKIN RS (with say 10.5T BL + Boost) has an acknowledged high speed braking issue. It is only obvious when taking a tight corner, at end of a long straight, usually on large tracks (were talking ~200' straight, ~1000' track length, and modified 4/4.5T BL speeds).
(2) Does the SP GT Pro 2 have any braking issues (under like conditions) ?
(3) Will the SP GT Pro 2 work satisfactorily with the TEKIN 10.5T BL Redline ?
Thanks in advance
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/[email protected],138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
qcrc
