Like Tree12Likes
Old 03-20-2010, 08:10 PM   #3406
Shawn Palmer's Avatar
Hi TEM,
Are you sure you loaded the software twice? Kinda sounds like you got the "half version" when loaded only once.
I ran another improved version yesterday that went out to the team guys. It goes a little further for top speed, but the main improvement is exactly the midband throttle you mention - I saw that right away too, and we've got that corrected with the new stuff. Also corrected is the "only 6 options in the Supercharger punch" setting.
I'll be hitting the track tomorrow, and if all goes well we might be able to sneak it on here for the non-team guys as another semi-public beta.
I think I've mentioned this before, but this is just the "framework" for what we've got coming in the near future. Once it's stable and where we want it, then the real fun begins
cherry:
Extra efficiency? I'll never tell. Just one of the cool (pun intended) benefits of SP supercharger software.
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Old 03-20-2010, 09:08 PM   #3407
tandman's Avatar
Send a message via Yahoo to tandman
Shawn, are the Marc Rheinhard edition mod motors available through King Golden? Or any of the other driver edition mods.
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-Rcamerica
tandman is offline   Reply With Quote
Old 03-20-2010, 10:01 PM   #3408
TEM
TEM's Avatar
Shawn,
That was a quick response! Thanks! I did load in the software twice. (it was brought up as an issue by someone else several pages ago on this thread). I also re-calibrated the radio every time I made a settings change with the settings card (pretty FAT for a "card"). There was another guy at the track testing the same thing and had the same result. Anyways, it's still early for the beta. I do look forward to future updates.
But in the future, could we get a sample settings set-up and FDR and motor info used by your official testers so we can get a closer baseline to start from? Would save a lot of time. I know you guys don't want us to burn something on first run but someone should know to temp frequently and use some due-diligence in testing these things! Anyone who empties a 5000mah lipo straight up on a unproven set-up DESERVES to burn something!
Somehow just feels the Tekin set up is more intuitive. RPM range for the boost and incremental increase for timing per units(chunks) of RPM within that boost range, additional increase in timing for throttle held for x seconds. Of course all that could be forgotten when the SP catches up. Perhaps the settings in SP "will" eventually do the same thing? or hopefully act more similarly.
I only get to go the the track a couple times a month these days. Will try loading the software in again when I get the chance to go. Hopefully by then there will be some new info/software (hint hint!)
TEM doesn't advertise for free! Does anyone else notice that a LOT of companies are not even packaging decals with their products?
TEM is offline   Reply With Quote
Old 03-20-2010, 11:41 PM   #3409
Jeremy Blair's Avatar
Trader Rating: 23 (100%+)
Default motors
yes the Driver edition Mods will be available through King Golden.
TEM the Software will only get better with more testing and when it does get available it will be easier to use. I can tell you I got the new edition of the software and you won't be dissappointed. There will be tested setups on motor and speedo settings on the King Golden site as it grows so then it will be a little easier like your asking for just be a little more time and you should be happy.
Jeremy
Clints creations Painting : clintscreations.com
Raceway Hobby
Cowtown RCC Club member
Jeremy Blair is offline   Reply With Quote
Old 03-21-2010, 02:48 AM   #3410
lochness42's Avatar
Well anyone experienced lack of brakes after turning on supercharger? At our nationals yesterday I started with supercharger off and brakes were good, when I turned on supercharger - stage only 1 and other setting very conservative as well, I lost good ammount of brakes. After turning off supercharger, brakes stayed weak.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 03-21-2010, 04:56 AM   #3411
defcone's Avatar
Trader Rating: 15 (100%+)
No loss of brakes here, had to dial down to 75%.
Try re calibrating.
defcone is offline   Reply With Quote
Old 03-21-2010, 04:58 AM   #3412
cherry2blost's Avatar
we had this, turned on the reverse, set reverse to 100% and brakes are so good now have them set to 75%.
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-21-2010, 08:33 AM   #3413
Hi TEM,
Please, no disrespect meant here at all, but this was put out as a completely brand new package. One of the goals (aside from dubugging and stability checks) was for the beta testers to come up with general starting points when the package moves to the public in a week or two. We can't drive every car on every track size and surface, so we take a look at all the beta testers setup sheets and draw up the recommendations for the public version from them. It's the beta guys' job to find what works best for them individually, and then we consolidate that into a guide for the public release.
Hi lochness,
I'll try to replicate that today, and then replicate the workaround from Cherry in order to let the engineers know where to look.
In the last 7 yrs of ESC software development and testing, I am continually amazed at the strange connections that pop up in software code. Change the throttle curve, and the brakes go away? Disable the LVC and the drag brake goes away? Set 100% brake strength and reverse doesn't work anymore? I've seen some strange stuff over the years, but luckily it's not only easily fixed, but usually ends up as another improvement down the road.
Shawn Palmer
Old 03-21-2010, 09:08 AM   #3414
Originally Posted by Shawn Palmer View Post
Hi TEM,
Hi lochness,
Hi Shawn
I try both 230 & 231 last night at a large track. both are powerful than 107 at straigh but poor at corner. my setting is
12-9
13-6
14-5
15-2
team powers 10.5T FDR at 6.9
temp 68C
how can I improve the corner speed(acce. rate?)
thank you very much
billbill4u is offline   Reply With Quote
Old 03-21-2010, 09:15 AM   #3415
Originally Posted by billbill4u View Post
Hi Shawn
12-9
13-6
14-5
15-2
temp 68C
thank you very much
Hi just my tuppence but I would have thought that setting 15 was a little too aggressive on that, where do you have your DDRS and AMTS set also any Mechanical timing?
Old 03-21-2010, 09:31 AM   #3416
Hi Cherry
I run zero Mechanical timing, DDRS-7 & AMTS-4, what do you think about my setting? is it better to run 15-6? I plan to try it again this wed, hope you can give me some opinion to improve my corner speed, thx!
Old 03-21-2010, 09:35 AM   #3417
Hi Cherry
How big is the track because at our club this was keeping up with the Tekins, and it was only my crappy driving slowing the car down at all..... even so gained a lap over what I normally get with 110.
We purposely started with everything set to minimums and have been gradually stepping the settings up one at a time.
Motor was warm enough to pick the car and carry it back to scrutineering by the motor, always a good guide to being cool, sorry but someone left the temp gauge turned on and I didn't have a spare 9v battery.
Old 03-21-2010, 11:54 AM   #3418
lochness42's Avatar
Hi lochness,
Thanks Shawn, btw without supercharger and with weaker brakes I managed to get 2nd place in our 10.5t class on nationals.
Pavel Balint
Old 03-21-2010, 01:12 PM   #3419
Trader Rating: 22 (100%+)
Hi Shawn
12-9
13-6
14-5
15-2
temp 68C
thank you very much
Turn the DRRS up it will give more punch on the bottom.
bjspinner is offline   Reply With Quote
Old 03-21-2010, 04:56 PM   #3420
My local track has 70m stright and many U turn, my best lap is faster compare with running 107 but overall is the same, and i feel the corner speed slower because all the other car can bite me(......).
Yes maybe the setting is ok just because I am not adapt it, let me try your setting again and report to you later. thank you for your opinion.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
