Like Tree12Likes
Old 03-18-2010, 04:28 PM   #3376
Trader Rating: 22 (100%+)
Originally Posted by AGNO View Post
I happens in position 1 (0 ° timing) of AMTS.
It happened to me when I was running the timming at 4/11.25 deg.
It was impressive though just felt it could do with more punch on the bottom end (low RPM ) and more track time.
For the offroad guys this is what I ran with.
10.5 speedpassion version 2
1-1
2-2
3-4
4-8
5-3
6-4
7-1
8-1
9-4
10-1
11-1
12-9
13-4
14-6
15-6
Gearing 23/76 2.6 to1 gearbox, temps motor and speedy around the 60 deg celcius. 30 deg ambient temp
bjspinner is offline   Reply With Quote
Old 03-18-2010, 06:27 PM   #3377
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by abailey21 View Post
Yeah it should be fan friggin tastic, new car, new power system, crappy tires I can't wait!
what time are you gonna be there, were headed to Rick's on the river for lunch and I might not be able to drive after like noon
il be there bright and early with bells on around 7 to get a good spot
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 03-18-2010, 06:28 PM   #3378
Originally Posted by kschu View Post
Have 2 Unit LCD Professional Program Card in stock here
Just ordered the LCD Box. Cant wait to test the new software on my GT Pro esc.
anyone have advise for 13.5t running on small and technical track ??
Size around 120ft x65ft
Blame Yourself For Not Doing the Right Thing!
mjack is offline   Reply With Quote
Old 03-18-2010, 06:58 PM   #3379
defcone's Avatar
Trader Rating: 15 (100%+)
Lower supercharger level and lower AMTS, with higher DRRS and supercharger punch.
defcone is offline   Reply With Quote
Old 03-18-2010, 09:32 PM   #3380
smilekt's Avatar
GT2 Pro also can use super charge? with one better GT2pro with supercharge or GT2.1 stock to run stock motor ?
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 03-19-2010, 01:24 AM   #3381
lochness42's Avatar
Yes it can - I'm running GT2 Pro with new firmware.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 03-19-2010, 02:55 AM   #3382
altreyx's Avatar
Arrow Speedpassion Setup Sheet
Hello,
This should be the last update. Some setup has been fixed with the correct name.
Have fun.
Download Link: http://www.megaupload.com/?d=CTJQ3TLY
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 03-19-2010, 03:28 AM   #3383
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Originally Posted by altreyx View Post
Hello,
Have fun.
Ringraziarla il mio amico.
Here is what Adam's getting this weekend.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 03-19-2010, 04:35 AM   #3384
Send a message via MSN to geubes
Originally Posted by mharlow View Post
When adjusting below 7 on the start mode (#4) the ESC does not get full throttle. Has anyone else come across this?
Yeh, I dropped this to 6 for some more smoothness, but the car was like a snail! and barely hit half throttle - i tried resetting the end points and re-calibrating, but nothing. So I just put it back up to 7 and left it at that.
geubes is offline   Reply With Quote
Old 03-19-2010, 04:58 AM   #3385
Hello,
my Name is Oliver and i come from Germany. I drive a Xray T3 with Rubber Tires. I have Questions but my English is not so good.
I had load the new Beta Software with 231 but i donīt have drive with them. I tested on my table :-)
The RPM is very high on AMTS Timing 8, but i can not understand on #15 is 6 value but on the setup sheet it goes from:
Motor Hot Max
-1
-2
-3
-4
-5
-6
-7
Motor Cool Max
there are 9???
Is there a driver they had tested the Software with a Touring Car? with a 17,5 and a 13,5 Stock Engine?
What is the different about 230 and 231?
Olli
kiloolli is offline   Reply With Quote
Old 03-19-2010, 05:14 AM   #3386
altreyx's Avatar
Originally Posted by kiloolli View Post
Hello,
Motor Hot Max
-1
-2
-3
-4
-5
-6
-7
Motor Cool Max
there are 9???
Olli
Has been fixed the setup #15...i was following a previous guide where the max value was 9..and it was wrong
Orca-Gm120
Reedy-Lrp
Helios EX10
Old 03-19-2010, 05:21 AM   #3387
lochness42's Avatar
Hello,
Motor Hot Max
-1
-2
-3
-4
-5
-6
-7
Motor Cool Max
there are 9???
Olli
Well, at the moment there are only 6 values that you can choose.
I tried it with 13.5T v3 SP motor in TC.
230 is more agressive than 231 and produces slightly more power but I belive you'll have to keep an eye on temps more.
Pavel Balint
Old 03-19-2010, 06:06 AM   #3388
Send a message via MSN to Bigger Brother
Hi
Just a quick question - probably more aimed at Shaun/Adam but if anyone else knows the answer that would be great
I'm at a race meeting this weekend, but along with actually running the meeting I'll be fairly limited on time to work on my car! I was thinking of trying the new software, but I won't have (another!) laptop to use to re-program my speedo.
What I basically want to know is, if I install software 230 onto the speedo but don't get the time to play properly with it and get it adjusted to my liking, can I then put Setting 12 (Boost Level) to "1" (Off) - will this then effectivly disable settings 13, 14 and 15 and act in the same way as if I was running software 107??
Many thanks for any advice
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 03-19-2010, 06:20 AM   #3389
abailey21's Avatar
Trader Rating: 36 (100%+)
Is it a day race? I thought it was a night race
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 03-19-2010, 06:21 AM   #3390
abailey21's Avatar
Originally Posted by Bigger Brother View Post
Hi
Oli
Yeah by putting the setting to zero you wont be running it, so yeah in theory yes
K.C.C.O.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
