Like Tree3Likes
Old 03-15-2010, 10:52 PM   #3256
Born2Run's Avatar
irgo you're right.Its v1.03_090704. It was a mistype,sorry.
An no irgo.As it works now i don't try to return to v1.02 firmware.There is no reason.
Originally Posted by irgo View Post
racingnazy , There is no v1.03_070904 for LCD, if you hear is from Born2Run.
and Born2Run, There is no v1.03_070904, it never exist,...
The true is There is version V1.03_090704, perhaps Born2Run typed it mistakenly.
and Born2Run are you sure LCD Firmware fix your drag brake issue ?
have you tried to return to v1.02 LCD Firmware after you fix the brake issue, and find it's wrong on v1.02 LCD Firmware ?
Whatever
Born2Run is offline   Reply With Quote
Old 03-15-2010, 11:33 PM   #3257
Originally Posted by skypilot View Post
did you plug in and turn on the esc?
yer i can adjust all the esc settings via the lcd pro box but can not update it on the pc. As soon as i plug it into the computer to update firmware it just says connecting pc and cant do anything to it.
rutter is offline   Reply With Quote
Old 03-15-2010, 11:49 PM   #3258
racerb's Avatar
Originally Posted by rutter View Post
yer i can adjust all the esc settings via the lcd box but can not update it on the pc. As soon as i plug it into the computer to update firmware it just says connecting pc and cant do anything to it.
same here... I am new to this... but thought I would be able to figure it out
racerb is offline   Reply With Quote
Old 03-16-2010, 12:04 AM   #3259
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by kriiiss View Post
anyone know who has a sp gt 2.0 blue esc in stock?
Here
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-16-2010, 12:27 AM   #3260
silverfrancis's Avatar
I was going to buy a range of pinion and spurs for my 12r5.1 I was wondering what range i should be aiming to buy if it is being used with a 17.5 turn brushless motor? Also what is the best ratio?
Another problem i have is what tires i should run. i will be using it outdoors on a asphalt track with paragon traction action. Any tips on which tires or range of tires i should get?
For Technology news visit: www.technific.com
silverfrancis is offline   Reply With Quote
Old 03-16-2010, 01:16 AM   #3261
racerb's Avatar
Default ....
hey all... finaly got the new S/w loaded on but got a couple of questions....
man where do I start with this
just kidding.... wondering where I should start with the motor timing ( sp 3.0 17.5R) right now on the motor it is maxed... it is a bit of a pain to change (okay alot of a pain!!! I have it on a tc4 LOL) so if it should be turned back a bit I want to do it now at home and not at the track wasting valuable track time....
other than that I am just looking for all feedback on settings like everyone else.....so keep em coming... I appreciate those who have put it out there... this is my first brushless system, so I am learning along the way.. so bare with me kidz
I have decided on the 230 version.... may chicken out before race day though hehe
Old 03-16-2010, 01:26 AM   #3262
Skitee's Avatar
Start with the motor timing at zero, let the ESC and software take care of the timing first. Once you've got the car running consistently fast and safely within the temperature range and you feel you might need something else then look at adding some motor timing.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 03-16-2010, 01:43 AM   #3263
racerb's Avatar
so do I slide the sensor part all the way back to the left side of the slot??? sorry NOOB
Old 03-16-2010, 01:46 AM   #3264
Skitee's Avatar
No set the timing to the middle of the slot.
Old 03-16-2010, 01:53 AM   #3265
racerb's Avatar
Default ...
duh.... thanks... can't believe i asked that
thanx for the help.....
hey charlie B... where are ya... hows the testing goin
Old 03-16-2010, 01:54 AM   #3266
Taman's Avatar
Trader Rating: 64 (100%+)
Here's one from an Aussie shop
http://www.rchobbies.com.au/store/pr...f01c7250254ea4
Taman is offline   Reply With Quote
Old 03-16-2010, 05:02 AM   #3267
ok so the program cards work with all my other speed passion 2.0 esc's except the one i bought 2nd hand which has had 110 software already installed and shows this on the interface. The problem is it wont let me change this 110 software to anything else(have tried every option just to see). I get this message "The current version (v1.1_100110STOCK) can not be updated to the version (V1.10_090205_T)!" Is there away i can delete the firmware manually or am i stuck with the 110?
Marcus
Old 03-16-2010, 05:45 AM   #3268
Marcus
Have you copied al files from the zip file to the software folder? I had this problem when only .db3 was copied over you need to replase the version control to.
chovden is offline   Reply With Quote
Old 03-16-2010, 05:49 AM   #3269
razzor's Avatar
rutter you need to use the pc software version before V1.32 to take it back.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-16-2010, 06:06 AM   #3270
Trader Rating: 92 (100%+)
Default Load twice
Thanks for the tip on loading it twice. When I first tried it was not impressed as it was not faster it kinda seemed like there was a lag then it would kick in while bench running. I had decided to try some of the other ones and loaded the 230. The lag was gone and sounded more like the other speedos while reving it . I'm going to try it at the track again tonight. But for others make sure and load it twice.
latemodel13 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Scrad
