Like Tree46Likes
Old 03-14-2010, 05:54 PM   #3211
Trader Rating: 22 (100%+)
Originally Posted by mutley001 View Post
I run windows vista home premium too and had the same issues, after doing everything as instructed.
To get this to work all I did was to right click the speed passion application icon in C:\program files\speed passion v1.32 and go to compatibility tab and select run in compatibility mode for win xp and also check the box to run as administrator. All the new softwares are then available to view in the speed passion installer
HIH
Paul
Thanks mutley001.
This is what got it to work in the end, run as administrator. I didn't have to run for win xp though.
bjspinner is offline   Reply With Quote
Old 03-14-2010, 06:17 PM   #3212
irgo's Avatar
Originally Posted by kriiiss View Post
Does anyone know the motor limit on the 2.1 gt esc?
kriiiss, 2.1GT Prostock Limit is 9.5T for 2S, because it carry Stock Software
but if you are using Mod Software, it equal to no limit ex: 2.5T for 2S
Like Shawn say it is the Pro ones, not the Lpf.
http://www.speedpassion.net/en/productDetails.asp?p=104
Quark Force
irgo is offline   Reply With Quote
Old 03-14-2010, 09:40 PM   #3213
Hi
Just got my lcd program box, i can change all the settings on the esc fine but as soon as i go to upgrade firmware or connect it to the computer it says connecting PC and just stays on that screen.
What am i doing wrong?
Marcus
rutter is offline   Reply With Quote
Old 03-14-2010, 09:54 PM   #3214
Trader Rating: 26 (100%+)
Send a message via AIM to kriiiss
Originally Posted by issac51 View Post
I also did this but becouse i didn't switch on the esc all that burnt out was the capacitor. I replaced this with a novak one ( as i couldn't get a new speed passion one ) and it works fine.
did u ever try turning on the esc with the stock capacitor after it shorted out?
idk whats gonna happen if i turn it on after i shorted it out
kriiiss is offline   Reply With Quote
Old 03-14-2010, 10:41 PM   #3215
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by rutter View Post
Hi
Marcus
nothing, when you open the speedpassion file, in the window that opens, click devices, then you will see, esc, lcd and motor checker ? click on lcd, then you can upgrade or change to then different softwares.
you'll see the little green lite flash in the lower left corner while upgrading in happening then a pop up window will tell you update complete
hope this helps
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 03-15-2010, 01:04 AM   #3216
Born2Run's Avatar
Is anybody having problems with the new software on the drag brakes or im the only one?
Whatever
Born2Run is offline   Reply With Quote
Old 03-15-2010, 01:27 AM   #3217
defcone's Avatar
Trader Rating: 15 (100%+)
It comes with 10% drag brakes when you first load up the software, wat problems are you having?
defcone is offline   Reply With Quote
Old 03-15-2010, 01:35 AM   #3218
Born2Run's Avatar
I have set the drag brakes on 20% but i don't get the same drag brake force ammount when i leave the throtle off.More drag brake when i leave the throtle when the supercharger has engaged and almost no drag brake when i leave it earlier
Whatever
Old 03-15-2010, 02:12 AM   #3219
defcone's Avatar
That's really weird, I had massive drag brakes when it was originally set to 10%, just wanted to try it out but didn't like it so set it back to 0% and the massive drag brakes went away.
Old 03-15-2010, 02:28 AM   #3220
Born2Run's Avatar
Realy weird but is a fact.
Whatever
Old 03-15-2010, 02:34 AM   #3221
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
sp 2.1 instock here...
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-15-2010, 03:33 AM   #3222
hope this helps
Hmm it freezes on the connecting pc screen and when i click update nothing happens it says this firmware can not be updated. im trying to change stock110 software to mod.
Marcus
Old 03-15-2010, 04:16 AM   #3223
razzor's Avatar
try recalibrating radio and also someone has suggested rolling back the firmware and then reload new firmware.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-15-2010, 04:33 AM   #3224
Born2Run's Avatar
razzor have you upgrade your LCD program box to the newest firmware v1.03_070904 or you still use the v1.02? I still use the v1.02.Could this cause this issue with the drag brakes?
Whatever
Old 03-15-2010, 05:52 AM   #3225
razzor's Avatar
i updated to the newer firmware for the lcd. didnt try it with the older version.
Was supposed to run at tehregionals but had some errands i had to do in the morning so pitched up late to run race control. Havent run yet but hope to this weekend.
Casterracing ZX1.5R
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
