Like Tree46Likes
Old 03-13-2010, 02:50 PM   #3166
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by RC MARKET View Post
new firmware had 80% feel Tekin RS Pro .
What motor and settings were you running?
defcone is offline   Reply With Quote
Old 03-13-2010, 03:14 PM   #3167
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by Gwoodrc View Post
I hope others are having better luck than me with new s/w. I have geared from a 4.5-7.0 started with the recomended setting and ended up maxing it out. with it maxed out and geared to a 5.2 is the best lap times, but still not as good of lap times as the 107 with a 4.9 fdr. Any suggestions? Freespooling it on the bench it sounds VERY fast, but it just doesnt have it on the track. I went down a tooth and up on the motor timing, fixing to run the first heat now, will post after.
take out some timing and add some gear thats wat charlie b is sugesting
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 03-13-2010, 03:45 PM   #3168
AGNO's Avatar
Originally Posted by Solara View Post
If you are only getting 110stock software and no 230 and 231...that means your "settings.db3" and "version_control.ini" files are NOT using the latest one that Shawn forward.....now, go thru this with me.
(1) Go to your Speed Passion folder under your C:/Program Files, within the SP folders...what are the "DATES" of the above 2 files read? They must be some date after MARCH 8, 2010....the files Shawn fowarded were both dated March 8, depends on when you are you copying and overwriting, they must be March 8 or later...these 2 files must be replaced with the newer version in order for those who use the 230 and 231 software.
(2) If they are indeed March 8 or later...restart your computer and start the SP program and hook up the speedo...you should see the newer software.
If not...I am sorry, you should go buy Tekin instead. No Supercharger for you.....it is not WHAT you pick, it is WHO they pick (just kidding)...
Really, we has been doing this update since the 091231 version from King Golden...and I have never heard anyone of our team has troulbe uploading the new software.
BTW....I am a PC and I use Window XP cause I know it works.
Nothing to do not work, I have the same problems bjspinner, I followed your advice but the upgrade does not work in my computer, I too have Vista Home Premium is the problem?
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 03-13-2010, 04:16 PM   #3169
Yes vista can be a problem apparantly you need to copy them in "administrator" mode to get it to work, dont ask me how to do it just heard it needs to be done to get it to work on vista
chovden is offline   Reply With Quote
Old 03-13-2010, 04:39 PM   #3170
Trader Rating: 66 (100%+)
OK, I didn't like it at first but keep experimenting, it's fast. Maxxed out the motor timing and geared to 6.6 and its fast! Running 17.5 rubber tire med/high bite carpet 75ft straight.
Gwoodrc is offline   Reply With Quote
Old 03-13-2010, 05:05 PM   #3171
racerb's Avatar
Default ...
for all the other settings what did you use?? was it what shawn had said??? wayyyy back in his "starting out post" you sound like you are racing on a track very similar in size..... you can post or even pm that would be great
racerb is offline   Reply With Quote
Old 03-13-2010, 05:52 PM   #3172
1-1,2-4,3-6,4-9,5-3,6-4,7-1,8-1,9-8,10-1,11-1,12-9,13-1,14-1,15-1. 7.38 fdr using a ballistic 17.5 with timing on the + mark coming off at 170f. Still needs alittle more punch but overall has been .2 better on the lap times then the best I could get with the 107. Thanks SP! If anybody has any other suggestions please post.
Old 03-13-2010, 05:57 PM   #3173
racerb's Avatar
so is this better... above post you said you used 6.6 and it seemed very fast?? is this a little better..... sorry for all the questions... kinda a newbie at this as I only have my sp for about two weeks and before that i was brushed
Old 03-13-2010, 06:06 PM   #3174
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Hmm..you are really getting power with Timing at 26 and full boost? My tests showed that timing and boost both on the highest settings lost a lot of power testing on a 17.5 all around....interesting.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 03-13-2010, 06:13 PM   #3175
I didn't say it was the best setting, but this has yeilded the best speed and lap times so far tonight (.10 off TQ). Yes it got better with the 7.3fdr. Charlie, I'm open to any suggestions?
Old 03-13-2010, 06:17 PM   #3176
racerb's Avatar
thanks will leave you alone now
keep reporting thou... your a huge help for some of us
Old 03-13-2010, 06:41 PM   #3177
Super Moderator
charlie_b's Avatar
Ya know, im still testing..im actually surprised this SW was released to be honest. What i have for mine so far.
4/9
9/4
12/7
13/5
14/2
15/2
This is with a 96/40x2.16=5.1(Cyclone TC).
I am still not happy with the 1st 10-15' of acceleration, but tonight, if the track is still open, im gonna try 13/2 or 1.
This Software, im finding that it tends to work best when you don't gun it. Let the software do it's thing. If you go full throttle off the bat, it might lag a bit.
Im gonan try
4/9
9/3
12/7
13/2
15/2
15/1
tonight and see if i can get another .5 secs off my time. On Monday i got 11.0. Wednesday i got 10.7. Last week my fastest was 12.4 so i know im going in the right direction. Now, hopefully someone can see something i don't so i can get this SW optimized.
LMK how yours turns up..i'd love to compare notes.
Old 03-13-2010, 06:45 PM   #3178
I know there is alot more to learn with this s/w and these settings may be way off from where SP wants us to be, but it did allow me to qualify 2nd and finish 2nd on the same lap as our local fast guy and I have never been able to finish on the same lap as him (unless he broke). So for the first day with it I am happy, looking foward to learning more and getting it faster more efficient.
Old 03-13-2010, 06:52 PM   #3179
Charlie B., what motor are you running and where is the motor timing set? I have a ballistic and it was a snail till I increased the motor timing, but was the opposite with the 107, more timing was just more heat and not speed.
Old 03-13-2010, 07:10 PM   #3180
stokka's Avatar
In Vista/Windows 7 copy the files to the speedpassion folder as described.
First time you run the program right click the SpeedPassion program and choose "Run as administrator". Then the database would rebuild.
If everything seems under control, you're just not going fast enough. - Mario Andretti
stokka is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
