Like Tree12Likes
Old 03-12-2010, 11:37 AM   #3061
mutley001's Avatar
Originally Posted by abailey21 View Post
You need the LCD box
Yep got one of those, but how do i get the files I downloaded into the program to copy it to the speedo? - i guess i'm being thick
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 03-12-2010, 11:47 AM   #3062
Send a message via MSN to geubes
http://dl.dropbox.com/u/20730/Supercharger_Beta.zip
it will be there until 2morro.
geubes is offline   Reply With Quote
Old 03-12-2010, 11:49 AM   #3063
abailey21's Avatar
Trader Rating: 36 (100%+)
Copy the 2 files and paste them into this path
My Computer
C:
Program Files
Speed Passion V. 1.32
Basically those 2 files need to be in the speed passion folder located in your program files folder in your hard drive
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 03-12-2010, 11:52 AM   #3064
abailey21's Avatar
Originally Posted by christmasracing View Post
adam i dont have word on my laptop so i cant read the instructions i downloaded everything and cant do any thing with any of the three files
I have a copy I made into a .PDF other than that I can't help you
File Type: pdf New Stock Supercharger Instructions.pdf (77.7 KB, 284 views)
K.C.C.O.
Old 03-12-2010, 11:54 AM   #3065
mutley001's Avatar
My Computer
C:
Program Files
That's the bit I was missing - Cheers Adam
Thank you!
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 03-12-2010, 11:56 AM   #3066
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
My Computer
C:
Program Files
So your basically copying and pasting and replacing the files that were in the 1.32 software folder with the new ones you just downloaded.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 03-12-2010, 11:57 AM   #3067
abailey21's Avatar
yes
K.C.C.O.
Old 03-12-2010, 12:05 PM   #3068
Hello there, the new SW dosent show up! i have replaced the two files in the Sp v1.32 folder. but nothing..
417X Speed Passion reventon PRO / Sp MMM 5.5T
himura is offline   Reply With Quote
Old 03-12-2010, 12:11 PM   #3069
Born2Run's Avatar
http://rapidshare.com/files/36252343...rger__Beta.zip
Whatever
Born2Run is offline   Reply With Quote
Old 03-12-2010, 12:14 PM   #3070
razzor's Avatar
got it thanks Adam.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-12-2010, 12:20 PM   #3071
is it working for everybody?
Old 03-12-2010, 12:30 PM   #3072
Super Moderator
Awesome, Thanks!
Any suggestions on where to start for 17.5 or 13.5? Or be careful what you ask for....
Dave H is offline   Reply With Quote
Old 03-12-2010, 12:43 PM   #3073
mharlow's Avatar
Trader Rating: 27 (100%+)
OK am I do something wrong. I've downloaded the new firmware to the ESC but I can't find where you can adjust the new settings.
mharlow is offline   Reply With Quote
Old 03-12-2010, 12:47 PM   #3074
Same here.. what firmware are you using on your Sp LCD programmer?
Old 03-12-2010, 12:49 PM   #3075
Shawn Palmer's Avatar
New settings added:
12) Supercharger Boost Level: This sets the overall supercharger power level. High levels may increase speed, but always at the expense of motor heat.
13) Supercharger RPM Delay: This controls when the supercharger settings engage. When the motor RPM reaches this setting, the ESC will engage the supercharger.
14) Supercharger Full Throttle Delay: This setting delays the application of the supercharger function until after a set time has been reached while holding FULL Throttle.
15) Supercharger Punch: This setting controls timing advance at RPMs below the Start RPM setting. Lower settings decrease motor temps, and higher settings increase punch and motor temps. (note: low punch settings are high programming value #s, and high punch settings are low programming value #s)
Starting from scratch:
1) Start out with a slow FDR (7.0) gear ratio
2) Start with #14 off and #15 at value 8
3) For 13.5 start with #12 at stage 4, for 17.5 at stage 6
A) The first thing to set is the RPM delay/gearing for the straight. Run the car and adjust #13 to where the boost is kicking in where you want it, and you want to gear it to make sure the car is still barely digging (accelerating) a the end of the straight. You want it to where it just barely doesnít top out.
B) #14 works together with #13. Adjust #14 up from zero one value at a time until itís making the kick come in later than it was before Ė then back it down one value.
C) Now you can tune the punch (#15) for the infield. Leave it alone if youíve got enough rip already, or try the car going up one value at a time. This setting has a huge influence on overall motor heat, so monitor temps constantly when dialing in more punch!
D) At this point, you should be set to go, or fine tune:
Fine tuning tips:
1) Different winds of motors are going to have different tolerance levels for overall boost and punch. Itís easy to overboost a 13.5 at the max setting. Too much advance will make the motor slower on the straight and have less torque just like over gearing will. It will also dramatically increase motor heat just like over gearing. Once youíve completed the above, you can experiment with more overall boost. You will most likely find a boost level that does NOT get faster than the next one lower. Thatís the motorís breaking point for that gear/boost level. Back down the boost to the next lower setting.
2) Same process for punch Ė too much, and the motor will turn into a dog in the infield and overheat quickly Ė back the punch down.
3) For large sweeping tracks where you can actually use a little boost in parts of the infield, experiment up and down with both #13 and 14 to find the right values to give you a little kick where you want it, but NOT where you donít want it. For almost ALL tracks however - just have the boost engage on the straight.
IN ALL MATTERS OF TUNING/GEARING/SOFTWARE SETTINGS:
The one and only goal should be faster LAP TIMES, not whether you are getting pulled, or are able to pass everyone on the straight. Top speed on the straight alone doesn't always directly translate into faster lap times.
When you fine tune gearing and software settings, always use the clock alone to gauge what's better or worse!
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
