Like Tree12Likes
Old 06-28-2009, 12:43 AM   #286
caltek1's Avatar
Trader Rating: 35 (100%+)
Default 17.5
Perhaps this has been previously covered, however I ran 17.5 in TC on asphelt today, with stock settings, as comes in the speedie initailly and had serious cogging issues using a Hacker motor.
My rollout was 56mm and once the car was moving the thing was quick, but off the starting line I was run down by the complete grid, before the car would start to work.
Not sure if this is a common problem with this combination. The speedie is a PRO GT version 2.
Thank you,
regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 06-28-2009, 12:51 AM   #287
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Thank you,
regards,
Calvin.
I had the same problem with a losi motor(which is believed to be the same a a hacker). It ran fine with a SP motor, so it seems to be the motor not speedo. I have since moved the rotor closer to the sensors and it now seems ok.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 06-28-2009, 02:10 AM   #288
caltek1's Avatar
Pardon my ignorance, but how do you move the rotor closer to the sensors. Is this done by adding/subtracting shims???
Thank you,
Calvin
Old 06-28-2009, 02:29 AM   #289
Thank you,
Calvin
Usually thats what you do. But the Hacker/losi rotors don't use them so I put the rotor in my lathe and turned down the shoulder it bit then added shims on the other end. Before I did this there was around a 1.5mm gap between the sensors and rotor. It was ok like that with my LRP but not the GT2.0. I'll be back racing at windsor soon and can help you out if you want.
Paul H
Old 06-28-2009, 02:38 AM   #290
caltek1's Avatar
I'll take you up on the offer.
Thank you,
Calvin.
Old 06-29-2009, 02:57 PM   #291
Just got myself a v2 5.5t motor to sit next to my 4.5, and as i have compared sp motors with other it seems that the sp motors produce more rpm`s than the others? (looking at numbers, have not tried them on the track just yet)
and gearing, how much can i gear the 5.5 before it gets too high? (large outdoor track, with lipo)
cant wait to try them out on the track!
Hatebreed is offline   Reply With Quote
Old 06-29-2009, 03:07 PM   #292
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Sp 5.5 at default timing on a large track i would start at around a 7.8 and watch the temps.
Old 06-30-2009, 10:40 AM   #293
Trader Rating: 14 (100%+)
My LPF 2.0 is on the way. This is the first non TC spec i have had since the tc spec came out!
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.0 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 06-30-2009, 10:57 AM   #294
Danny-b23's Avatar
Does the 2.0 have "Turbo" timing?
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 06-30-2009, 07:31 PM   #295
bluephi1914's Avatar
Trader Rating: 34 (100%+)
I dont believe it has turbo timing or at least i dont see it in the menu...but it keeps up with any other ESC out there. I have personally raced with exact setups as other racers with the exception being the ESC ... and it keeps up.
Mr. 17.5 's Rides ----> T3 EU / T2 008 EU (Vintage)
** NEXUSRACING.COM **
** Team Xray - Team Novak - Proline - Sorex - KO Propo - Team Trinity **
bluephi1914 is offline   Reply With Quote
Old 06-30-2009, 09:57 PM   #296
Thank you,
regards,
Calvin.
It might also be an idea to throw some different software at it and see if that helps. I have tried quite a few versions and there is a big difference in the "feel" and a smaller difference in performance between all of them. If the software fixes the problem then you won't need to mod the next motor you buy.
As a note I suggest trying either the SP motor or the duo. They seem to be getting results.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-01-2009, 02:08 AM   #297
razzor's Avatar
At this last weekends nationals.
A buddy drove my 17.5 TOP Racing Scythe with a LPF 2.0 and SP 17.5 and he was flying. he qualified 4th in the a-mains and finished in 3rd.
We kept gearing up and found the 58mm roll out to be the sweet spot for us.
Updated the software to the suggest version Shawn gave 205C
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-01-2009, 12:55 PM   #298
I just realized i need a new 17.5. any suggestions other than the obvious? I had heard good thing about the Duo i thought
Old 07-01-2009, 02:02 PM   #299
caltek1's Avatar
razzor or Troy,
Where can I get a copy of the 205C software? Thinking about, it is most probably a better idea to get another motor. I will see if I can get a SP 17.5.
Thank you.
Calvin.
Old 07-01-2009, 02:06 PM   #300
razzor's Avatar
get a lcd programmer and download the latest software from the Speedpassion site under the apparel heading.
Casterracing ZX1.5R
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
