Like Tree46Likes
Old 03-08-2010, 08:39 PM   #2926
irgo's Avatar
Default Speed Passion ESC Firmware Damaged Responded.
Originally Posted by Shawn Palmer View Post
Hi irgo,
My apologies if I an mistaken, but as I understand it, you have either:
A) Installed another brand of software (HobbyWing, Tekin, LRP) onto your Speed Passion ESC.
or
B) Disconnected your ESC during a PC Speed Passion software update.
Either way, unfortunately the outcome is the same and the repair process is the same:
The USA office does not have reflashing/ESC processor replacement capabilities. That Speed Passion ESC will need to be sent to our Hong Kong headquarters. Please email Mr Benny at: [email protected] for RMA and shipping instructions.
you are Correct, (B) accidentally Disconnected,
and then the ESC is only showing Green Light no blinking.
this meaning that ESC is Fail to Boot, or Hang.
Thanks Shawn Palmer, for your Suggestion.
I Believe You.
defcone:
The Supercharger software should be out for public beta soon. BUT - as before, please be careful with the settings, as this new software can overdrive and overheat a 10.5 quite easily.
Speed Passion Mac capability - I'll check on that and have an answer soon. There were no plans for it the last time Schumacher USA inquired, but you never know.
Superb .
Quark Force
irgo is offline   Reply With Quote
Old 03-08-2010, 09:18 PM   #2927
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Glad to hear your back Shawn and Adam, looking forward to seeing the new website
Irgo,
You just don't seem to let it go!!!
However I did something very close to your issue...
The way I fixed this and I not saying it will fix it but worth a try, sounds like you have nothing to loose.
Connect an external power supply normally comes with your Tx to the USB device connect to your PC and SP GT2 and see if that will allow you to update your software, my problems could have been diffrent from you as it just bleeped in a green light but this allowed me to reinstall 205g onto my GT2 and it now rip's up my local track again.
Otherwise dude think you need to send it to HK as I think 3 people have now told you.
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 03-08-2010, 09:41 PM   #2928
Trader Rating: 66 (100%+)
Has anyone tried the x-12 with the 107 software and if so how did you end up gearing it compaired to other 17.5's?
Gwoodrc is offline   Reply With Quote
Old 03-08-2010, 09:44 PM   #2929
defcone's Avatar
Trader Rating: 15 (100%+)
defcone:
The Supercharger software should be out for public beta soon. BUT - as before, please be careful with the settings, as this new software can overdrive and overheat a 10.5 quite easily. Speed Passion Mac capability - I'll check on that and have an answer soon. There were no plans for it the last time Schumacher USA inquired, but you never know.
ha i was just joking with how he said macs were superior when compared to pc. thanks i will be cseeful with the new software with 10.5
defcone is offline   Reply With Quote
Old 03-09-2010, 01:22 AM   #2930
irgo's Avatar
Default New Speed Passion Firmware Cases and Solution
Irgo,
For me Shawn Palmer Answer is Good enough for me, and thanks'
MrTyson,
And This kind of your Respond that we are looking for.
Your Suggested Case and Solution is about to try right now is Under Investigation.
Quark Force
Old 03-09-2010, 04:45 AM   #2931
Send a message via MSN to Bigger Brother
Hopefully just a quick question from me:
I've got a GT2.0 and I'm running in the 13.5 Touring class. I currently run a SP v3 motor with it, but am wanting to get another motor for the start of the outdoor season both as a 'spare' and perhaps to give a slightly different power band.
Can anyone recommend a 13.5 that works well with the Stock software in a TC?
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 03-09-2010, 05:38 AM   #2932
abailey21's Avatar
Trader Rating: 36 (100%+)
Originally Posted by defcone View Post
Does the speed passion software work on MACS? Do they support images and colors now?
I'm still begging them for that.
I run XP off a partition on my Mac (bootcamp)
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 03-09-2010, 05:53 AM   #2933
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Anyone else have the problem with the timing assembly being able to move in their motor when built (V3)? I have 4 of these motors, and a brand new 4 turn has this issue. The others are fine. The timing is able to be pushed from 0 to 10 degees with ease, i have rebuilt the motor and got it a bit better, but still not perfect. A friend also has the same problem with his 17.5. Any suggestions?
Thanks,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-09-2010, 06:03 AM   #2934
abailey21's Avatar
Thanks,
Antoni
We had a couple like that, Charlie B was making "decals" to put on the silicon rings to tighten the gap up that works great, not sure if he has any left
K.C.C.O.
Old 03-09-2010, 06:13 AM   #2935
Shawn Palmer's Avatar
Hi Antoni,
Another quick fix is to cut out a "washer" from a business card to snug up the fit.
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Old 03-09-2010, 07:00 AM   #2936
dameetz's Avatar
Whats the default timing on SP V3 motor (mine 11.5T)? Its in the middle now, i just don't know the value actually.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 03-09-2010, 07:02 AM   #2937
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
anyone got an ESC setup for 1/10 2wd buggy with a 13.5 motor (ballistic).
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 03-09-2010, 07:41 AM   #2938
dameetz: They are about +5deg in the middle.
Cain:
DRRS however you prefer the feel
Lower will feel softer in punch, but will allow faster gear.
Advance however you prefer the feel, and in direct conjunction with gearing for temps
On a low traction surface for 2wd, I personally the DRRS around 5-6, and the advance around 4-7 depending on exactly how slick it is. Then I gear for best laptimes.
On a high grip track, I like DRRS around 7-8, and then play around with both gearing and advance to give me the feel I want with the best laptimes.
Shawn Palmer
Old 03-09-2010, 07:55 AM   #2939
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Sean ygm
kwiksi is offline   Reply With Quote
Old 03-09-2010, 08:01 AM   #2940
Tech Legend
Cain's Avatar
Cain:
Thanks for the info! I am thinking of using the 110 software since that is supposed to be less punchy on the low end than the 107.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
