Like Tree8Likes
Old 06-09-2009, 01:06 AM   #256
Originally Posted by charlie_b View Post
What kinda car ya running? Sedan? Buggy? 4wd Buggy? Truck? Mini?
since this is the onread section probably Sedan or mini
Rick Thomson is offline   Reply With Quote
Old 06-09-2009, 01:27 AM   #257
stacky150's Avatar
Trader Rating: 13 (94%+)
Default 4.0T motor fans
Whats the best way for getting the fan off the rotor for a 4.0T SP motor?
stacky150 is online now   Reply With Quote
Old 06-09-2009, 03:10 AM   #258
razzor's Avatar
why take it off ? no real benefit besides a few more rpm at the expense of more heat.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-09-2009, 02:10 PM   #259
SWTour's Avatar
Shawn,
This weekend is the first time we'll be back on the Encino Velodrome since the Allstar Shootour/ ISC "Insane Speed Run" weekend.
I'm hoping to get the GT-LPF Esc fired up and see how she runs!
I figure since we're pushing the 21.5 motors with it - I'll use FULL timing (Do these have the ability to add even MORE TIME with any kind of updates?)
It'll be fun to get back on the Big Ol "VELODROME" and see what this puppy will do in MY car!!
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 06-09-2009, 07:52 PM   #260
tc3 racer sc's Avatar
hotbodies tc
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 06-09-2009, 07:53 PM   #261
hotbodies cyclone tc
Old 06-14-2009, 08:28 PM   #262
HI_808's Avatar
I recently picked up a 17.5 Ultra Sportsman and paired it up with my old Novak GTB. I tried it out in the 17.5 class with a 4.2 FDR since that's the highest I could get the gear ratio with my current stock of gears. As I expected, it was quite undergeared and I'm thinking about going down to a 3.8-4.0. Is this a normal FDR to run in the 17.5 class with the Ultra Sportsman and an older BL ESC?
Thanks,
Ken
HI_808 is offline   Reply With Quote
Old 06-16-2009, 07:27 AM   #263
razzor's Avatar
question for Shawn or Adam or anyone clued up.
When rebuilding a 17.5 or 13.5 what should the gap be between the sensor and the rotor ???
Does a larger gap have a effect over a smaller gap ???
On any sensored brushless motor for that matter would it make a difference ?
Casterracing ZX1.5R
Old 06-16-2009, 08:19 AM   #264
Shawn Palmer's Avatar
razzor:
Use the shims at the back of the rotor to make sure the rotor doesn't actually hit the sensors on the sensor board as it rotates. About 1 mm is fairly standard spacing between the rotor and the sensors.
As far as spacing goes - yes, it can make a difference. the closer the proximity of the sensor to the rotor the stronger the signal is to the ESC. Although there is some convoluted instances where close and strong could be too close and too strong for some ESCs, being farther and farther away can in most cases start to degrade the signal and you potentially lose some accuracy.
Generally though within the space available in a motor - not much worry about too far away, just make sure you're not scraping the sensors with the rotor .
Ken - yes, that's pretty normal.
SWT:
Sweet! I've heard about the results and am really happy the SP speedos won and set at least one new track record! Give me a call if you need any more info on anything - I'm glad to help!
Stacky:
They're loctited on, and the most reliable way I've found for removing them is to use an old dead pinion on the shaft and clamp that into a vise. Then rotate the fan on the clamped down shaft to break the loctite bond. Basically you'll destroy the fan in the process, so you really have to want to run the motor without it, and not really have the option to put it back on without buying another rotor.
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Old 06-16-2009, 11:28 AM   #265
razzor's Avatar
Thanks Shawn
Casterracing ZX1.5R
Old 06-16-2009, 11:37 AM   #266
abailey21's Avatar
Trader Rating: 36 (100%+)
Thanks,
Ken
Yes, I was running a 3.25 at Vegas last year. I was however using the large LRP cooling heatsink with fan. and a GT 1.1 ESC
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 06-17-2009, 11:16 AM   #267
razzor's Avatar
Is there any developement being done software wise to compete with the SXX and Tekin RS ?
Casterracing ZX1.5R
Old 06-17-2009, 11:49 AM   #268
we've already been there from day one on the V2.0
But yes - of course it still continues for more punch and top speed.
Shawn Palmer
Old 06-17-2009, 01:31 PM   #269
Hebiki's Avatar
Trader Rating: 26 (100%+)
Shawn
any performance difference btw the GT and Exige escs?
- Chris
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-17-2009, 03:36 PM   #270
jdearhart's Avatar
Trader Rating: 15 (100%+)
I'm having some problems with a Speed Passion Inspire and Speed Passion JR motor. I think it is made by Hobbywing.
Here's my problem.... lots of stuttering and it backs up a little before going forward. It came with the programing box and I have changed a bunch of things but no luck. Any advice?
http://www.speedpassion.net/product.php?lang=&c=45
Specs- Speed Passion JR Motor
Speed Passion Inspire ESC
2S Lipo
3PK radio
jdearhart is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
