Like Tree12Likes
Old 02-16-2010, 05:34 PM   #2491
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Originally Posted by guinnes.s View Post
wile racing tonight my sp v1.1 started to respond very erratic when giving throttle,is not the first time that happens ,and when does happen i notice that the green and red leds on the esc are flashing very quick together . they will go back to normal only if switch off and back on.
help please,what would that mean???
ok ,do you know the reason of the leds flashing very quick? would it be a specific problem?
It went "sensorless".........check the sensor wire first, then check the sensor itself. If it is a SP motor, the sensors can be very delicate to the abuses of banging boards and plain old crashes.
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 02-16-2010, 06:42 PM   #2492
guinnes.s's Avatar
thanx for the help,
btw on the new v3 13.5t motors the stock timing at the back comes with the sensor plug in between 0 and 10. what timing would this been? and i noticed that i get the led flashing problem when i run the motor with the sensor plug moved all to the left to 0.
guinnes.s is offline   Reply With Quote
Old 02-16-2010, 09:50 PM   #2493
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
does Schumacher sell any GM Double Sided Tape?
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-16-2010, 09:53 PM   #2494
niznai's Avatar
Default SP V3 timing
Does anyone know what the actual timing is on the V3 motors? Is zero on the motor indeed zero degrees of timing?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 02-16-2010, 10:00 PM   #2495
Skitee's Avatar
I tried searching but couldn't find it again so I may be a little off, either Shawn or Adam posted a while back saying that the V3 had the same timing at zero as the V2 motors so that is 12 or 14 degrees.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 02-16-2010, 10:07 PM   #2496
niznai's Avatar
Thank you Skitee. Even if I don't know exactly how much it is, it is helpful to know it is not exactly zero.
Team Greasy Weasel
Old 02-16-2010, 11:53 PM   #2497
So after having cooked 2 motors in quick succession, can anyone please assist with a good ESC setup for 13.5 sp motor using SP GT2.0 pro esc.
Car is Schumacher Mi3.5
I do not have the LCD programmer just the standard one that came with the ESC.
I dont know why my motors are cooking so easily but I never had issues with my old novak GTB using the first motor. It cooked on 2nd run with SP ESC so purchased new ultrasport SP motor and that cooked too on the 2nd run. So either im doing something completely wrong or i just have really bad luck. ESC settings are currently standard as they came from the factory, car drivetrain is very free running.
Any assistance is greatly appreciated as i have my countries national champs this weekend and really dont want more motors turning to junk.
Originally Posted by dfiantii View Post
Post your esc settings. Basic does not tell us anything at the same time I suspect that it could be the gearing your using.
1. Running mode = Forward with brake
2. Drag Brake force = 20%
3. Low voltage cutoff = none (i changed this to 3v per cell)
4. DRRS Start mode = Level IX (9)
5. Brake force = 75%
6. Reverse force = 25%
7. Initial brake force = 20%
8. Neutral range = 6%
9. AMTS Timing = 15deg
10. Over-heat protection = Enable
Final drive ratio = 5.25 as suggested by the motor sheet.
my4ari is offline   Reply With Quote
Old 02-16-2010, 11:58 PM   #2498
Drillit's Avatar
thanx for the help,
I have had the same issue with the v3 sensors.......I have 3 (2 17.5s and 1 13.5) v3s of which I have lost 2 to sensor mechanical failures....the male pins are easily pulled from their mount on the board. You need to be very careful how you move the connector when adjusting the timing. I resoldered 1 successfully, the other, not so good, it's hard to get a good solder on such a small area.
You may also find that the sensor interferes with the stator windings! I have disassembled several of these to find the windings won't allow normal range of timing adjustment. Carefully, Very Carefully push the windings outwardly to gain more clearance for the sensor.
On the motor timing degree thing: It Is What It Is. The best advice I have seen and believe in is this: leave it in the middle, gear for temp/lap-time, drop a tooth, then use motor timing to adjust temp. NOW for U I enstine types, this is for non-ramp-up-non-turbo type speedos like the Speedpassion 1.1 that we are talking about here. Settings on the 1.1...stock...super stock.... Max drrs and timing per Adam way back when this thread 'reappeared'. Drag brake also adds heat.
Hope some of this helps
Mark Tilley
Old 02-17-2010, 12:40 AM   #2499
Hi guys. The software of the new SP Gt 2,1 is the same that is already avalaible for the Gt 2,0 ( the "107" and the "110" ) ?
The "upgrade system" will be the same for the Gt 2,1 and the Gt 2,0 ?
Thank you
ilkispios is offline   Reply With Quote
Old 02-17-2010, 01:14 AM   #2500
dfiantii's Avatar
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Turn your DRRS down to 6 or 7. At 9 your pushing to aggressive and by turning it down you maybe able to get some speed when you increase timing. I am sure one of the many gurus will be on here shortly to correct me if my interpretation of your setting is off.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 02-17-2010, 02:24 AM   #2501
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Thank you
Where did you hear this? It is my understanding there is a new update which should be on the website round the 19th
As yet there is no confirmation as to what this update will include..
Hope you know something new
Alex
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 02-17-2010, 07:31 AM   #2502
Glowster21's Avatar
Trader Rating: 116 (100%+)
Hey all! Anyone know if the Hobbywing LCD Programming Bob, which looks identical to the Speedpassion Box, will work on the Speedpassion ESC's? Pretty sure I know the answer but wanted to verify.
Glowster21 is offline   Reply With Quote
Old 02-17-2010, 07:36 AM   #2503
Tech Legend
Cain's Avatar
Trader Rating: 232 (100%+)
From what has been posted on here, it is a Try at Your Own Risk proposition that some have reported does work, others, it can brick your ESC depending on what you do.
I would say I would just wait for the SP branded unit. I beleive there are a few for sale on RCtech right now.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 02-17-2010, 07:52 AM   #2504
qcrc's Avatar
I just want to say that there is nothing wrong with the Speed Passion ESC. I put my Mi4 in the A main last weekend running against Tekins and LRP's. There was only .3 of a second between fast laps and a one lap difference from first to last after 6 min. of racing. I can't wait to try out the new 2.1 software.
Schumacher Cars
Speed Passion Powered
qcrc is offline   Reply With Quote
Old 02-17-2010, 07:58 AM   #2505
Solara's Avatar
I was there to second his performance...good run anyway.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
