Like Tree46Likes
Old 05-18-2009, 01:02 PM   #226
razzor's Avatar
Ok bought 2 sensor leads with coloured wiring today.
They confirmed my suspicion.
The lead i recieved with my motor had a pair of pins swapped.
I managed to swap the two wires in question and its working perfectly.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 05-18-2009, 01:30 PM   #227
abailey21's Avatar
Trader Rating: 36 (100%+)
That's good to hear dude
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 05-20-2009, 09:43 PM   #228
Trader Rating: 22 (100%+)
Hey Adam
What version program do you recomend for the LPF2.0 for offroad 2wd mod.
bjspinner is offline   Reply With Quote
Old 05-21-2009, 05:49 AM   #229
I found a little glitch in the programming of my SP GT 2.0 Pro today. I had a jump start a few racemeets ago that was unintentional. I thought an easy solution would be to increase the neutral width. While running in a diff today I noticed that the throttle came on strong initially, like have a throttle punch. I looked through my radio settings but couldn't explain it. I then turned to the speedy and tried changing the neutral width down to minimum. Instantly the initial throttle was normal.
My conclusion is that instead of adjusting the nuetral width the speedy is simply ignoring the 1st % of throttle travel and then responding to it after that point. While this would have no real effect on spec racers a mod motor (like a 4.0) shows significant difference. I suggest that this be looked at for the next firmware update.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 05-21-2009, 05:55 AM   #230
razzor's Avatar
I had the same niggle initially but recalibrated the esc after i rebound my Spektrum and all is good now.
Casterracing ZX1.5R
Old 05-21-2009, 06:04 AM   #231
abailey21's Avatar
I found the 205C is by far the best thus far.
Originally Posted by bjspinner View Post
Hey Adam
K.C.C.O.
Old 05-21-2009, 06:46 AM   #232
Shawn Palmer's Avatar
Dragonfire:
Razzor is correct - after a neutral band change you'll need to recalibrate the ESC to the transmitter in order for it to work as expected.
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Old 05-21-2009, 06:51 AM   #233
S.Nicholson:
We like the "C" better than the "G" for stock, as the C has a little better top end and smoother throttle response.
For mod, the "G" has a tick more punch, but with mod motors you are not going to tell a big difference between them other than a little different "feel" on the throttle curve. Either one is fine.
Shawn Palmer
Old 05-21-2009, 11:10 AM   #234
hey guys,
can anyone point me in the direction of a manual for the LPF please ? I've lost mine Can't seem to see it on the speed passion website, or the schumacher website
Chris
CPD Racing
chris_dono is offline   Reply With Quote
Old 05-21-2009, 11:21 AM   #235
razzor's Avatar
Originally Posted by chris_dono View Post
hey guys,
Chris
What do you need to know ??
Casterracing ZX1.5R
Old 05-21-2009, 11:27 AM   #236
razzor's Avatar
What is the difference with 312a and 323a software update ???
Casterracing ZX1.5R
Old 05-21-2009, 11:52 AM   #237
The initial setup (neutral, throttle, brakes etc)
The card I'm not so fussed about
CPD Racing
Old 05-21-2009, 11:57 AM   #238
razzor's Avatar
OK
simple.
Switch on esc while pressing the set button on the switch.
esc will beep.
with radio in neutral position press button once. esc will beep.
then hold full throttle position and press button once. esc will beep.
then hold full reverse/brake position and press button once. esc will beep.
let go of throttle to neutral position and esc will beep and you should be good to go.
Casterracing ZX1.5R
Old 05-21-2009, 11:59 AM   #239
ok, neutral first, cool
CPD Racing
Old 05-23-2009, 10:13 PM   #240
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
disregard...
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
