Old 05-15-2009, 09:42 AM   #211
razzor's Avatar
Played around with the software hooked up to the pc and see what you mean.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 05-15-2009, 02:45 PM   #212
s.nicholson's Avatar
Send a message via MSN to s.nicholson Send a message via Skype™ to s.nicholson
What is the difference between 90205G and 90205C? What would be better for LIPO 4.0 or 4.5
Team Yokomo/Panaracer/LRP/Xenon
Roche/Pro-Spec
Sanwa
s.nicholson is offline   Reply With Quote
Old 05-15-2009, 02:52 PM   #213
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
adam, plese check your pm...
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 05-15-2009, 03:08 PM   #214
abailey21's Avatar
Trader Rating: 35 (100%+)
No check yours lol
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 05-15-2009, 03:11 PM   #215
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Originally Posted by andrewdoherty View Post
Thanks Charlie_b for updating the title.
No Problem bud!
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 05-15-2009, 03:34 PM   #216
razzor's Avatar
possibly could we get a list of teh updates and what they are ??
Casterracing ZX1.5R
Old 05-15-2009, 04:08 PM   #217
Originally Posted by abailey21 View Post
No check yours lol
Adam can you please specify difference in softwares as im leaving for reedy race on monday
Roche/Pro-Spec
Sanwa
Old 05-16-2009, 08:25 AM   #218
razzor's Avatar
can anyone post a color/pin sequence for the sensor lead.
I just fitted a SP13.5 and 17.5 along with GT2.0 and a GT2.0 LPF.
I hooked up everything to my 17.5 and it wouldnt turn over unless i gave the spur gear a push and imediately stop. Took out sensor wire and it runs fine.
Took sensor wire from 13.5 and it runs fine. was worried i fried somthing or wired incorrectly as motor got hot and started smoking.
I cant check against the other lead as the sensor lead has black wires and the one in question is colored wires.
should the wires be the same sequence on both plugs ???
My plugs are as follows
red, blue, white, green, yellow, black
red, blue, green, white, yellow, black
Casterracing ZX1.5R
Old 05-16-2009, 11:37 AM   #219
tc3 racer sc's Avatar
Originally Posted by Jamesalex View Post
I am looking to get a new speed controller as I was wondering about the pro 2.0
how has it been running, I believe you can adjust timing is there also a turbo mode for this controller, it is between this the gm 120 and team wave rb50.
Cheers
well i hve a question i just got the pro 2.0 why the wire not aolider to the post like most esc on the market and the instruction seem hard to understand to a point im sure it good product it my thought to ask
tc3 racer sc is offline   Reply With Quote
Old 05-16-2009, 12:11 PM   #220
gregm's Avatar
Trader Rating: 57 (100%+)
Send a message via MSN to gregm
I have a lead with Red, Blue, Green, White, Orange, Black. HTH
Racing makes heroin addiction seem like a vague wish for something salty - Peter Egan
gregm is offline   Reply With Quote
Old 05-16-2009, 12:25 PM   #221
abailey21's Avatar
"In the US" I don't know of any sensor leads different, all brands have the same wiring order on the motors and ESC's
K.C.C.O.
Old 05-16-2009, 03:22 PM   #222
razzor's Avatar
Then most likely its a incorrectly assembled sensor lead !!!
so both plugs should have the same order correct !?!?
Thankfully it didnt stuff up the esc and motor just got the motor hot but its running fine now.
Casterracing ZX1.5R
Old 05-16-2009, 04:04 PM   #223
Adam can you please post an answer to my question that i have asked many times.
Roche/Pro-Spec
Sanwa
Old 05-16-2009, 06:45 PM   #224
smilekt's Avatar
Originally Posted by yeahyeah View Post
I also tried the speedy "not connected to the receiver" switched it back on after calibration it will still go into the default mode.(when you check the settings using the pad -its not in factory default mode)
Noting tho for the above :
Motor coggs it has very little or no brake - all braking options on speedy set to MAX.
try disconnet ur sensored cable .. try run on sesorelless .. my friend have done by disconnect sensored cable ... maybe the sensored cable got problem .. hope this help ..
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 05-18-2009, 08:12 AM   #225
xraysteve's Avatar
First I would like to say I am not that good with the computer. I have GT Pro 2.0. and I bought the lcd card also. I put the cd in and there are two links one on the left I can down load and save. The one on the right it just keeps going on the net and then ask me if it is ok to do so and over and over. Is that normal do I just need one of them. Also how or where do I get updates for it. Thank you. I know it is hard to understand what I am typing.
lazer speedway everything else is a parking lot
xraysteve is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
