Like Tree46Likes
Old 02-05-2010, 01:56 PM   #2206
Trader Rating: 43 (100%+)
Send a message via AIM to SlaminRC17
Anyone know how much timing adjustment is on the V3 motors? Thanx, Kevin
SlaminRC17 is offline   Reply With Quote
Old 02-05-2010, 02:08 PM   #2207
Stein Tumert's Avatar
Originally Posted by irgo View Post
downgrade too much.
Not sure what you mean, can you write clear english?
If you mean that the 2.0 lfp cannot run brushed motors that is not an issue as noone is running brushed motors anymore.
Also, you can run the new stock software on the 2.0 lfp which will give you what you want/need...more speed compared to the 1.1...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 02-05-2010, 02:29 PM   #2208
Trader Rating: 16 (100%+)
Originally Posted by guinnes.s View Post
are you suggesting that i would be better not update to the new 2.0??
I have 3 Version GTV1.1 for sale....I think they are ALOT better then GT2.0 (I am saying that so you would buy all my old dusted V1.1 speedo from me....).
GTV1.1 is not even close to GT2 by any standard.....
Old 02-05-2010, 02:33 PM   #2209
Originally Posted by PinkFloyd View Post
For anybody that may have run it (not sure if it's out yet)
Would it be worth me buying the new GT2.1 Prostock speed control over the slightly older GT2.0 Pro Brushless ESC.
For touring car btw
I noticed Marc running the older 2.0 at the ETS.. was this just his prefered choise or not yet recieved the 2.1?
Cheers
GT2.1 stock spec is for STOCK motor racing (mostly used for 10.5T and slower)....Marc R is running MOD, he has to use the GT2.0 PRO in order for him to use the mod motor.
As far as a WC like Marc does...there is no way he did not receive the 2.1 on time for the race...infact, he might be testing the SP GT V6.53 already....
Old 02-05-2010, 03:54 PM   #2210
pmc
Hello
i have same questions.
The esc speed passion 2.1 pro stock is superior of LRP SPX , SXX stockspec??
Anyone have compared to LRP escīs??
The esc GT2.0 can be updated to the version 2.1 and have the same performance of the esc 2.1 pro stock.
if help the motor i chose is a speed passion 9,5T V3.0
Thanks in advance.
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 02-05-2010, 04:01 PM   #2211
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Originally Posted by pmc View Post
Hello
Thanks in advance.
Best regards:
Pedro Silva
Pedro, non of us has tested the 2.1 yet. we are waiting for it to get into our hands so we can not compare it to an LRP. However, The GT and LPF 2.0's will have the same performance for stock as the 2.1.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 02-05-2010, 04:51 PM   #2212
dsyed1's Avatar
do we know when the 2.1 stock software be available for the gt 2.0 guys?
dsyed1 is offline   Reply With Quote
Old 02-05-2010, 05:49 PM   #2213
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Originally Posted by Scrad View Post
Can anyone answer my previous question about gearing and timing for a 17.5 in TC.
Also I can't figure out if the v2.0 is 1s lipo capable for use in 12th scale.
12th 1s, yes it is, for 17.5 you will have to get the "312"program, for 13.5 I run both the 312 and 323 programs. If you are running mod, 323 or 205. I think you are the 5th person in the world to use these speedos in 12th
hint: use a rec. pack (your choice).
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 02-05-2010, 06:24 PM   #2214
irgo's Avatar
once again i am not saying just brushed motor.
now you are comparing it incorrectly, i know 2.0 is better
but if replacing SP GT 1.1 PRO with SP GT 2.0 LPF now that's big difference,
i will show you why then,
there is 2 SP GT 1.1 LPF and SP GT 1.1 PRO
there is 2 SP GT 2.0 LPF and SP GT 2.0 PRO
compare
SP GT 1.1 Pro is 120A to 720A
SP GT 2.0 LPF is 80A to 440A
That's what meant downgrade.
Quark Force
irgo is offline   Reply With Quote
Old 02-05-2010, 08:39 PM   #2215
compare
irgo, based on the numbers yes it is downgrade. BUT... when you are racing a spec motor, that numbers is not important.
GT 2.0 LPF at 80 to 440A is adequate enough for stock spec motor.
and the new algorithm in the version 2.0 is the important thing that affects the speed.
BTW, what do you race? onroad/offroad? stock or modified class?
TOP Racing
krat is offline   Reply With Quote
Old 02-05-2010, 11:00 PM   #2216
Scrad's Avatar
Trader Rating: 15 (100%+)
Well I got one in trade and decided to put it into my touring car for 17.5. But I was thinking about using one for 12th scale, but I ended up ordering a Havok 1s.
Scrad is offline   Reply With Quote
Old 02-06-2010, 12:11 AM   #2217
Default 2.1 settings
GT2.1 Prostock - Blue Edition : Program Card Setting Content
SP has published the settings for the new 2.1 speedo
PS! How do you guys publish pictures directly in this window?
Stein Tumert
Old 02-06-2010, 12:16 AM   #2218
Super Moderator
Speedpassion GT2.0 Got Lot's more Power abilities Inside compare to GT1.xx.
I agree.
Dave H is offline   Reply With Quote
Old 02-06-2010, 12:27 AM   #2219
razzor's Avatar
In stock there is no comparison but in mod there is not much of a difference and the V1.1 is still a super smooth mod esc.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 02-06-2010, 12:31 AM   #2220
razzor's Avatar
Use Photobucket to store your pics and then copy the "img" tab and paste it on the forum.
Casterracing ZX1.5R
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
