Like Tree3Likes
Old 02-04-2010, 06:45 PM   #2176
abailey21's Avatar
Trader Rating: 36 (100%+)
Originally Posted by charlie_b View Post
We all know money is no object for Adam...he can even afford Bahama's very best women. Check out this pic from his Bahamas trip last year. He even roll played!
this is So on my facebook right now!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-04-2010, 07:01 PM   #2177
dsyed1's Avatar
Hey Mark,
For the GT2.1 Stock, i believe the max motor you wanna run with that is 9.5 possbibly 8.5. Anything lower will blow the esc. If you want to run a 4.5, then the GT2.0 is the one you want. The LPF 2.0 can handle up to a 5.5 motor.
All three esc's allow you to run the latest software SP Provides. Remember, if you install the stock software, you can not run them with a mod motor.
i have been meaning to buy another gt 2.0 for a new car i just built... i was going to wait for the 2.1...
but from what you are saying the 2.0 will be able to run the same stock software that 2.1 will be coming with than it makes sense to just buy the 2.0 right now
am i understanding this correctly?
dsyed1 is offline   Reply With Quote
Old 02-04-2010, 07:14 PM   #2178
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
checkout this shop
maybe some1 might need it...
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-04-2010, 07:27 PM   #2179
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
That is correct. What the 2.1 offers is the smaller footprint and the billet aluminum case. So if space is an issue and you wont be running mod, then this is what you need. Otherwise, the GT or LPF 2.0 is the way to go.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 02-04-2010, 07:38 PM   #2180
The Hawaiian's Avatar
Trader Rating: 94 (100%+)
happy b-day Adam...here's a present...island style.
Justin "haole boy" Perry USCG (CGC Firebush)
NewRed Hobbies & Indoor Facility, da BEST clay off-road track in Florida.
!!Treat me the way you want to be Treated!!Race me the way you want to be Raced!!
The Hawaiian is offline   Reply With Quote
Old 02-04-2010, 07:41 PM   #2181
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Originally Posted by haywood View Post
Do any of the current speedo's more aggressive settings work on 3.7v or just 7.4v?I know my SPX does not work well on 3.7v?Thanks
Originally Posted by abailey21 View Post
I'm not sure it's going to be as aggressive as you may be looking for, but it works without issue
Check back 10 or 20 pages, TryHard and myself have discussed this at length!
Had my LHS call in a order for a 2.1 wed. this week, found out that it won't even be available (even backorder) till the end of March, our indoor season is over by then, oh well.........there's next season
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 02-04-2010, 07:41 PM   #2182
abailey21's Avatar
footprint is the same, I confirmed that earlier this week
K.C.C.O.
Old 02-04-2010, 08:35 PM   #2183
guinnes.s's Avatar
what are the benefit in jumping from sp gt v1.1 to the new v2.0?
are the v2.0 any puncher then the v1.1?
thanx
guinnes.s is offline   Reply With Quote
Old 02-04-2010, 08:58 PM   #2184
irgo's Avatar
Default Speed Passion GT 2.1 ProStock
Adam, What is GT2.1 Pro Stock is,
LPF or PRO (hardware meaning) ?
Quark Force
irgo is offline   Reply With Quote
Old 02-04-2010, 11:10 PM   #2185
Scrad's Avatar
Trader Rating: 15 (100%+)
Sorry if this has been asked before, but I just picked up a brand new GT V2.0 in trade and would like to use it in 17.5 touring car.
I've got a Corally Phi and run a 17.5 Duo, the original red one with a 5000 40c lipo. What timing should I use on the motor and what FDR do I need to run?
Also do I need to install a different profile in the speedo or just plug it in and go?
Thanks for any info.
Scrad is offline   Reply With Quote
Old 02-04-2010, 11:22 PM   #2186
CraigM's Avatar
Trader Rating: 34 (100%+)
so is there any performance benefit in having the 2.1 over the 2.0 pro or even the lpf for spec racing? I've always used lrp gear but was thinking of swiching to SP when the 2.1 comes out, but if I'll be able to run the same software on the 2.0 I'll get that instead
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-04-2010, 11:59 PM   #2187
That's settles it then SP GT PRO 2 it is then but are there
any plans to change the gt2 pro to the ally case as the stock 2.1 or upgrade it generally ?
mark williams is offline   Reply With Quote
Old 02-05-2010, 01:44 AM   #2188
irgo's Avatar
thanx
you might have more Puncher but look at this...
luckily you with SP GT v1.1 Build in
Allow us to run :
- Brushed Motor (Not Build in SP GT v2.0 software.)
- Brushless Motor Sensored
- Brushless Motor Sensoreless
- Incoming Slotless Brushless Motor Sensored
- Incoming Slotless Brushless Motor Sensoreless
Source :
Glimpse at the future of "STOCK" Racing?
Quark Force
Old 02-05-2010, 06:29 AM   #2189
tfrahm's Avatar
Send a message via AIM to tfrahm
Originally Posted by Airflow View Post
Hi, I want to try Speed Passion Competition 3 - 10.5R motor.
I have questions:
1. It has vent holes to help desipitate heat. But will it allow dust
and debris to enter the motor and damage it? Or the dirt wont reach the rotor
and the inside of the stator? or Im better off with the Sportsman range of
motors since it is more protected.
I've been watching the thread, and I don't think this guy ever got an answer to his question, and since I have the same concerns, I thought I'd bump it back up on the thread... I'm going to be running a v3 13.5 for the first time this weekend in my XXX-CR offroad, and dust, dirt, and debris are serious concerns. I suppose it would be possible to put tape over the holes in the can, but that would prevent the cooling the vents provide..? At times, we used to use 'vet-wrap' to wrap brushed motors to reduce dirt infiltration, but that, too reduced cooling. I currently plan to just run it "open" and see how it goes, but anyone with experience and advice would be MOST appreciated...?
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 02-05-2010, 06:41 AM   #2190
Super Moderator
charlie_b's Avatar
It all depends on what kind of dirt you will be running on. If it is packed clay, then you really don't have anything to worry about. But if it is dry, loose dirt, you might have some issues, but nothing compressed air won't fix.
Comparing the motor from On-road to Off-road, the Off-road motors do not get anywhere near the heat of my On-road cars. I think it is due to not being full throttle all the time and lot's of air will air-cool the motors. I think, if you blow off the motor and ur car for that matter, the dirt shouldn't be an issue. If you are racing, just blow it off after your race.
If you are bashing(7minutes or longer) then you probably will be more prone to getting dirt in the motor, so keep that in mind. I would keep your run times to every 5 mintues or close to it. Plus, shorter runs is less harsh on you equipment.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
