Like Tree46Likes
Old 05-12-2009, 08:32 PM   #196
kidsid99's Avatar
Trader Rating: 53 (100%+)
Originally Posted by andrewdoherty View Post
I'm running an LPF 2.0 in 12th and WGT with 13.5 and 17.5 motors with a 1 cell lipo.
FWD BL, no reverse
timing 26*
AMTS -9
no lipo cut off
heat protection enabled
6% neutral width
10% drag brake
initial brake set to drag brake.
I am running sp motors with this set up.
HTH
You using a voltage booster or receiver pack?? Thanks for the reply.
XRAY, RC America, Boca Bearings,
www.msra-racing.com
kidsid99 is offline   Reply With Quote
Old 05-12-2009, 11:50 PM   #197
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Those settings were with a 200 mah lipo receiver pack with no regulator. I have a novak booster wired up and everything is operational. I'll be testing any differece in lap times, mah's used etc this week and Sunday.
Old 05-12-2009, 11:50 PM   #198
Thanks Charlie_b for updating the title.
Old 05-13-2009, 04:34 AM   #199
Default gt 1.1
Question re: GT 1.1
I have some cogging problems (motor sp 10.5)
After going through calibration of TX and speedy etc to fix the cogging perhaps.
When you apply throttle the first time the red and green light will continually flash when TX is in neutral.
Reading the manual it indicates speedy is in default mode?????
yeahyeah is offline   Reply With Quote
Old 05-13-2009, 06:17 AM   #200
kidsid99's Avatar
Thanks Andrew. Could you let me know how that works out with the Novak booster after the weekend? Thanks
www.msra-racing.com
Old 05-14-2009, 10:28 AM   #201
smilekt's Avatar
Originally Posted by yeahyeah View Post
Question re: GT 1.1
my friend have same problem .... anyone can help?
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 05-14-2009, 08:47 PM   #202
Dadaman's Avatar
Trader Rating: 20 (100%+)
I just purchased a GT Pro 2.o. Has anyone else noticed that the red light is almost impossible to see when your are trying to calabrate the speedy with the transmitter?
Xray XB4 '16
Yokomo Dogfighter YZ-10 870c
Xray T4 '14
Dadaman is offline   Reply With Quote
Old 05-14-2009, 08:49 PM   #203
kidsid99's Avatar
Yes. It is easier to listen for the tones.
www.msra-racing.com
Old 05-14-2009, 09:21 PM   #204
Mike Haynes's Avatar
Question re: GT 1.1
Try with a different motor to be sure that isnt the issue, the 10.5 tend to cog when they get overheated.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-14-2009, 11:38 PM   #205
Default 1.1
I also tried the speedy "not connected to the receiver" switched it back on after calibration it will still go into the default mode.(when you check the settings using the pad -its not in factory default mode)
Noting tho for the above :
Motor coggs it has very little or no brake - all braking options on speedy set to MAX.
Old 05-15-2009, 04:26 AM   #206
razzor's Avatar
With the lcd programmer when you do a firmware update to te esc can you go back to the previous version or versions ???
With the GT 2.0 in mod and a GT 2.0LPF in 17.5 which is the best update to use.
Both using SP motors.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 05-15-2009, 04:41 AM   #207
abailey21's Avatar
Trader Rating: 36 (100%+)
205C is the best software I've seen for both mod and 17.5.
U can go back but you have to do it off the computer
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 05-15-2009, 05:07 AM   #208
razzor's Avatar
Can you explain "off the computer" !?!?
Casterracing ZX1.5R
Old 05-15-2009, 06:56 AM   #209
abailey21's Avatar
Well, when you update the software it doesn't save it in the LCD box automatically, you have to load it from the computer
K.C.C.O.
Old 05-15-2009, 09:41 AM   #210
Jamesalex's Avatar
I am looking to get a new speed controller as I was wondering about the pro 2.0
how has it been running, I believe you can adjust timing is there also a turbo mode for this controller, it is between this the gm 120 and team wave rb50.
Cheers
Jamesalex is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
